Sony XBR-65x900F troubleshooting unresponsive TV
  • yavqq
    • Feb 2023
    • US
    This all started a few days ago when out of no where the TV appeared unresponsive. Pushing the power button did not do anything and there was no standby light active. However, holding the power and volume up button while plugging in the AC power did show a steady solid green light. Still no display and no further activity from there.
    After some research I did some measuring of the common voltage points..
    Main Board Connector
    Pin 02 "BL_ON": 0.00V
    Pin 03 "POWER_ON": 3.47V
    Pin 05 "STBY 3.3V": 3.50V
    Pin 26 "TCON_ON": 0.00V
    After noticing the power_on and STBY are 3.5V I'm assuming the power board is okay. Since BL_ON and TCON_ON have no voltage led me to believe this could be the mainboard since research showed this signal comes from the mainboard.
    I tried re-sitting all of the mainboard cables with no luck. But after removing all of the cables and only connecting the power -> mainboard and plugging in the power cord I noticed some more light activity on the LED driver board which was a good sign.
    I unplugged the power cord and plugged back in all of the connections and low and behold the TV started up normally with working screen and sound! I didn't think much of this and figured could have been a loose cable somewhere.
    Since then I've had the TV on maybe 30 minutes or so but not streaming or watching anything and everything seemed fine. Finally decided to watch a movie and about 10-15 minutes in some horizontal black bands and lines appeared for 5 seconds or so before finally the image freezes on a previous frame but no longer any horizontal lines. There was still sound but just a frozen picture.
    After unplugging the power we were back to step one. The TV is now unresponsive again with the power button not doing anything and resetting the power also does nothing.
    My first guess was this could be a mainboard issue maybe the EMMC chip but since the TV briefly worked for a short time this had me confused.
    Any ideas what could be going on here? I'm unsure if this could be the mainboard or maybe the TCON board. Is there any other voltage tests I can take to narrow the problem. I don't necessarily have the gear to jump any pins but again the brief time the TV was working makes me think the backlight and LCD are okay.
  • nomoresonys
    • 12326
    • U.S.
    Re: Sony XBR-65x900F troubleshooting unresponsive TV
    heat the tcon board with a hairdryer for a couple minutes and retry the tv, don't wait til it cools down, try it while its still hot, see if theres any change.
    • yavqq
      • Feb 2023
      • US
      I have not tried the hairdryer on the tcon board yet.
      After leaving the TV unplugged for about 24 hours, the TV started up and displayed the Sony logo then a black screen. The standby light is on and displaying a white color.
      The power button does not seem to turn off the TV at this point. The standby light does flash a brighter white when issuing commands via the remote.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4529
        • Italy - Milan
        I think much probably CPU has soldering problems..
        • yavqq
          • Feb 2023
          • US
          Update to this thread.
          I ended up replacing the main board. After updating the software with a USB the TV was up and working again.
          I'm assuming this was some sort of solder problem like previously mentioned.
          Thanks everyone for the help.
          • jason123
            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
            by jason123
            Hi there,
            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
            I see 2 posts that are relevant:
            https://www.badcaps.net/forum/troubl...j-oled-5-blink
            https://www.badcaps.net/forum/troubl...g-hardware-dev...
            10-29-2025, 02:01 PM
          • mmartell
            Sony KDL-65W850C is this a Mainboard issue ??
            by mmartell
            This sat around for quite some time after the backlights died with the six blink error code. I bought replacement strips and eventually swapped them in.
            Backlights appear to be working fine now. However the tv only powers on with the "Sony" logo for about two seconds after which it goes away and the panel with backlights stay powered for about twenty more seconds then it shuts off. Tv can only be powered again after power cycling at the outlet.
            It will not program via usb, the stick flashes but there is never any indication that it has entered programming...
            11-19-2023, 10:27 AM
          • TerraPhantm
            Sony A8H to A80J mainboard upgrade possible?
            by TerraPhantm
            I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
            So I decided I'd experiment a little bit.
            I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
            When...
            08-15-2023, 08:10 AM
          • noinimod
            Sony 55X900E no standby light, no power. Replaced mainboard already
            by noinimod
            No standby red light, nothing
            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
            Disconnected JK3 power board from main board, checked voltages on all the pin outs
            At a few pins I can see the power supply providing 19.5V to the main board
            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
            12-22-2021, 12:58 AM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
