Lg oled65b9dla
  • Proserot
    • Mar 2022
    • 19
    • Deutschland
    Lg oled65b9dla
    ive got an OLED65B9DLA here which isnt showing any picture. When turned on, the PSU delivers appropriate Power, as soon as 20V to T-CON is due, it ramps up to 20V then immediately stops, going back to 0V.
    When removing the ribbon cables from TCON to Mainboard, it doesnt do this.
    The red standby Led is on the whole time.
    Sound isnt working either when connected to a Laptop, it does show up as the correct device tho.
    I have a service remote but cannot actually make use of it as the TV wont turn on (i think?).
    Before investing in the rather expensive Power boards, id like to make sure, or at least increase the odds, of knowing its not the panel which went over the rainbow bridge
  • Diah
    • Feb 2013
    • 6376
    Re: Lg oled65b9dla
    start with upload photo of yours PCB and other close to pin chart of the socket which goes to MB at PCB side.. so we can tell you how to test the power boards as stand alone.
    • Proserot
      • Mar 2022
      • 19
      • Deutschland
      Re: Lg oled65b9dla
      HTML Code:
      https://imgur.com/a/ZTqivD3
      Ive done some blind testing as im pretty new to TV fixing.
      DRV_ON for example in 0V in OFF, jumps to 1.5v when pressing power button and returns to 0v. This might explain the absence of 22v for the Panel
      • Diah
        • Feb 2013
        • 6376
        Re: Lg oled65b9dla
        the socket P251 on PCB it go to T-CON driver boards as 2 sockets 1= 12V and other 22V. the 22V socket at T-CON driver boards disconnect it from T-CON side and turn on the TV.... keep your eyes on the MB and Optic audio socket it lid red and how many LED indicator on the MB will turn on and remain on.
        • Proserot
          • Mar 2022
          • 19
          • Deutschland
          Re: Lg oled65b9dla
          If I remove the 22v Socket from TCON no change. Only once did the SPDIF connector light up for a second. Couldn't replicate at will.
          With both 22v and 12v disconnected, its the same behavior.
          Only if I remove the LVDS cables from MB to TCON is when the SPDIF lights and stays on.
          I cannot see any other LEDs on the MB. Shall there be some?
          • KYBOSH
            • Oct 2011
            • 581
            • Unknown
            Re: Lg oled65b9dla
            MBs rarely have LED indicators. That's usually on the t-con boards.
            The only real sign of life a MB has is the fiber optical cable light.
            • Proserot
              • Mar 2022
              • 19
              • Deutschland
              Re: Lg oled65b9dla
              What i thought. Ive seen (on service manuals) that some MBs have LEDs but cant make out any on mine.
              • Diah
                • Feb 2013
                • 6376
                Re: Lg oled65b9dla
                dont spend money on it..Panel cells shorted.
                • Proserot
                  • Mar 2022
                  • 19
                  • Deutschland
                  Re: Lg oled65b9dla
                  Thanks! Could you elaborate how you can conclude this? Still new to the TV scene and at least want to learn something from all of this
                  What's responsible for telling the MB to shut off because theres shorted cells?
                  Any measurement point to "see" the short with a multimeter?
                  • Diah
                    • Feb 2013
                    • 6376
                    Re: Lg oled65b9dla
                    you have on T-CON LVDS sockt 1 pins " Panel SOS" this deliver signal to MB Micom to turn off PCB and let it stay at STB. if you cut off this pin on T-CON side,, the Panel will light up. but you need to have ready fire extinguish close to you as the Panel 99.9% catch fire.
                    • Proserot
                      • Mar 2022
                      • 19
                      • Deutschland
                      Re: Lg oled65b9dla
                      Damn
                      Would I be able to measure that signal? Sounds like an easier way to know about a short than pulling cables ;D
                      And is it like one row, one cell or all cells shorted?
                      How can this occur? The TV was wall mounted for 2 yrs then just turned off while gaming and voilà.
                      Can I somehow test the power board and TCON for function so I can safely give them away?
                      • Diah
                        • Feb 2013
                        • 6376
                        Re: Lg oled65b9dla
                        1- will be one row or more shorted...
                        2- calculated yours 2 years use as how many hours was the TV on. and be sure LED / OLED Diode have limited life circle
                        3-at time you had disconnected the LVDS and the optical port remain red,,, mean
                        you have on PCB 12 , 20 V to MB and 22V 12V to T-con
                        4- if you put every things back as original and disconnect the 22V on T-CON ( be sure the 22V socket) when you plug it in wall the Optical will come Red and then off... you need to push RC power on or at service RC power only.
                        • Proserot
                          • Mar 2022
                          • 19
                          • Deutschland
                          Re: Lg oled65b9dla
                          The optical won't come on when 22v disconnected from TCon. Will only come on if I unplug the 51pin LVDS.
                          I've read about some jumpers on the MB connector on Power board side, is this something which is applicable here? Anyways, what'd be the goal to achieve? Have the expected voltages on the pins to proceeded boot up procedure?
                          And many thanks for your explanations. I've read many posts from your, old ones too and you're like a TV god
                          • Proserot
                            • Mar 2022
                            • 19
                            • Deutschland
                            Re: Lg oled65b9dla
                            Oh and: The TV really has not a lot of hours on its back. Maybe 1 to 2 Hrs per day, gaming after work, if I'm not on PC Monitor.
                            Sometimes a whole week not one Minute of operating time...
                            • Diah
                              • Feb 2013
                              • 6376
                              Re: Lg oled65b9dla
                              above my point 3.. do it again and with yours DMM V DC negative refrence to TV chasis .. messure the 12 V and 22V on T-CON you have 2 Fuse F need to messure the voltage each on both side
                              • Proserot
                                • Mar 2022
                                • 19
                                • Deutschland
                                Re: Lg oled65b9dla
                                Yeah, they both 21.8v
                                • Diah
                                  • Feb 2013
                                  • 6376
                                  Re: Lg oled65b9dla
                                  Pcb ok.. T-con ok mb ok.
                                  • Proserot
                                    • Mar 2022
                                    • 19
                                    • Deutschland
                                    Re: Lg oled65b9dla
                                    Thx!
                                    Now when i was playing a bit i clipped in the LVDS while the optical port was red (MB running, connected to laptop via HDMI 1).
                                    The TV didnt go to STDBY immediately this time. While i still got no sound, it usually just turns off on the spot when i did this in the past.
                                    I couldnt check if i got any picture as its lying face down on the floor rn...
                                    Is there a way to get it to display Test pictures? The Red green blue white things you do for driver board test?
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      Re: Lg oled65b9dla
                                      if you have Fire insurance to yours house... Man stop playing with it regards to your safety.
                                      this why there are "Panel SOS" signal.
                                      • nomoresonys
                                        • 12199
                                        • U.S.
                                        Re: Lg oled65b9dla
                                        how about some pictures of all of this?
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • alltvrepairs
                                          Lg TCon test pins for screen test
                                          by alltvrepairs
                                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                          Appreciate your help....
                                          06-13-2025, 06:33 AM
