Sony XBR-65A8F Just Dead
  • pdsterns
    • Oct 2022
    • 28
    Hi there, rookie here
    Sony worked fine then died, I opened up and ohmed out the fuses and checked standby voltage and all fine, does this point right to the MB or is there something else I should do next
    burns
  • pdsterns
    • Oct 2022
    • 28
    Re: Sony XBR-65A8F Just Dead
    Sony worked fine then died, sometimes is has a standby light and sometimes not. I opened up and ohmed out the fuses and checked standby voltage and all fine. I then checked out the voltages on the second connector on the PS and everything there is dead, TCON 12v and EVDD 24v. So does this mean the PS is bad or the MB is not turning it on?
    burns
    • ajshoe
      ajshoe
      • Dec 2012
      • 477
      • usa
      if you want help - post pics of back of set with each board. nice close up pics.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4543
        • Italy - Milan
        I don't know oleds but you can try to activate panel self test by detaching main board, doing the 3 jumpers on PSB that feeds power to the panel, first get an external source of 3v or 5v, a battery is enough, then post a picture of the connector signals legends on the power board..
        • thstuff
          Sony OLED XR-77A80J - Initially dead, now 4 Flashes
          by thstuff
          A) TV initially dead
          B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
          C) Was able to perform a Reset from Settings menu and completed out of box configuration.
          D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
          E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
          12-26-2024, 09:10 PM
        • bohaboha
          SONY KDL-46R473A ALMOST DEAD NO STB
          by bohaboha
          Hello to everyone in this wonderful forum.
          I have this SONY LCD TV KDL_46R473a
          PSU GL5 APS350 :1-888-122- 12
          MAINBOARD FY13_EU IP-012C101-4010
          black screen ,no STB no life almost death.
          on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
          Also 3,5,and 12v are on.
          nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
          don't know what to do next all suggestions and advice are very welcome​...
          04-24-2025, 04:40 PM
        • Talyn
          Sony 55W905 dead
          by Talyn
          My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
          I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
          Any advice? Thanks!
          04-15-2024, 08:14 AM
        • mrsith
          Sony KDL-55W755C - Dead
          by mrsith
          Hello again lifesavers.
          I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
          I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
          11-28-2022, 12:42 PM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
