Samsung UN65H6203BF
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4537
    • Italy - Milan
    Re: Samsung UN65H6203BF
    Ok but lets speek technically, this is the reason i am here, after i hope you can return board, now try to fix the broken one, have you ever fixed an lcd tv? How many? I have told you my diagnosis, are you able to understand it? i'm unable to locate the shunt regulator, it's smd under the board, post a magnified view of the portion of the 4 optocouplers so i can locate it
    • otis11
      • Jan 2023
      • 27
      • us
      Yes I have done board level repairs on old things. I have not repaired SMD at all. I have pulled a few SMD chips and replaced in satellite boxes and cable boxes and I have put some in smart card readers. I don't have any schooling in electronics. I don't know the electronic term Shunt. Now getting back to the set. I replaced the PSB and that never fixed it. Someone mentioned the burnt looking places on the board. Yes that sorta through me. I guess the question is now. Where is the cheapest good quality place to buy the back lights and where is the best instruction video to change the back lights in a Samsung UN65H6203? Don't forget with the black lights plunged in the stand by lights goes out . Its not any different with new board. I think I missed a question. Have i repaired any flat screen Tv's and the answered is no. I only attempted one before this one and ordered the PSB for it as well, needless to say that didn't fix it. I did replace the back lights only to put bubbles/crack looking places in it and it finally lit up. So the answer is I haven't fixed a flat screen. Thanks.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4537
        • Italy - Milan
        I see that you are following your own road if its really a road and not following my advices, so for now i salute you....
        • otis11
          • Jan 2023
          • 27
          • us
          DAVI.D I'am sorry if I have offended you. What do you want me to say or do? I think I explained my level of expertise in previous reply's. Now the only thing I know to do is replace the thing that has a short I guess. Why repair boards that have SMD on it when you can't see or don't have a microscope not to mention the solder equipment you would need and most boards are under a 100 bucks and in some cases 150 for all to repair a 1000 dollar TV. I may know the answer. Some that have there own businesses don't want other people fixing things and I can somewhat understand that. When I was licensed I spent many hours on the phone trying to help folks instead of making money off of them, it will come back to you in the long run.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4537
            • Italy - Milan
            not offended.. only a bit annoyed, in the sense i always hope to save a device and on top of all learn..
            • CapLeaker
              Leaking Member
              • 8351
              Go to shopjmmy.com and see what they have... They may have a complete sub for your backlights and other things. Even us Canadians buy there. Large LCD's are always a pain to fix. Sometimes you need a second person (depending on size of the TV). Shopjimmy also has instructional videos. It may not be exactly your TV, but a lot of them are the same.
              • otis11
                • Jan 2023
                • 27
                • us
                #27
                Thanks capleaker. they did have a good video on the exact tv.
                • otis11
                  • Jan 2023
                  • 27
                  • us
                  #28
                  I'am trying to get face frame of now, haven't started with the four piece frame yet. Tv back was pretty hard to get off. i ruined the last one tcl55 trying to get the four piece frame off, pulled a bubble and cracks between the glass and film. How does repair shops quote a price not knowing if they are going to separate the glass and film without damage? Is there some sorta trick to this? Do they make tools to get these things apart? Your help is appreciated.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4537
                    • Italy - Milan
                    #29
                    You have bad power board!
                    If you aren't able to change a small component why don't you give the board to a service technician?
                      • 12330
                      • U.S.
                      #30
                      you can try this, you have 2 powerboards right? now as per CapLeakers advice in post #2, do you get the backlights on with either board with cable from powerboard to mainboard unhooked, if no, first easy checks are start on top of board with diodes and resistors, check all solder joints on bottom of board, there are also transistors and diodes on heatsinks that need testing, what voltage do you have on jumper JP804 both in standby and after you hit power on, youtube is a friend for how to test if needed, examples of bad joints: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
                        • 12330
                        • U.S.
                        #31
                        can you post a good focused picture of the legend/map next to CNM803 and a good picture of the whole back as to see how everything is connected, I think the next thing to do is try to power up the powerboard as stand alone WITHOUT cable from powerboard to mainboard hooked up.
                        • otis11
                          • Jan 2023
                          • 27
                          • us
                          #32
                          Ok, I got it all apart. I tested all back light strips with a tester. I had over 50 led's not lighting up on all strips, some of them looks burnt. i'am replacing all strips with new one's. Should I try the old PSB after installing new back light or just leave the new one in? Don't know if I should chance damaging anything else as bad as that old board looks.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4537
                            • Italy - Milan
                            #33
                            Don't you have told in first post to have tested backlight and was ok?
                              • 12330
                              • U.S.
                              #34
                              sure, use the new power board.
                                • 12330
                                • U.S.
                                #35
                                thats why the test in post #2 is good for a lot of samsungs, if you don't get the backlights on, the problem is powerboard or backlight/backlight circuit.
                                • otis11
                                  • Jan 2023
                                  • 27
                                  • us
                                  #36
                                  at this point i wasn't really sure, also from the looks of that board i thought it was bad. back lights never worked at all.
                                  • otis11
                                    • Jan 2023
                                    • 27
                                    • us
                                    #37
                                    Update, replaced all back lights. set comes up with dark screen with splotches on the screen.
                                    so i guess that means cracked screen. BUMMER.
                                    • otis11
                                      • Jan 2023
                                      • 27
                                      • us
                                      #38
                                      • otis11
                                        • Jan 2023
                                        • 27
                                        • us
                                        #39
                                        wonder why it shows no graphics, i guess i will trash this one and have second thoughts about doing another. i did use suction cups to lift.
                                          • 12330
                                          • U.S.
                                          #40
                                          wow, surprised you couldnt see that bad cracking just by looking closely, thought you said you used a backlight tester and they lit up, unless maybe it got broken in the repair process.
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            09-07-2024, 05:50 AM
                                          • JohnML1975
                                            Samsung UA50TU8000W no picture and no sound
                                            by JohnML1975
                                            Hello All
                                            have seen posts on this model in here but my problem sounded different so thought i would create a thread
                                            TV will not turn on
                                            There is no standby light
                                            When I press ON button for remote the red standby light does flash but no picture and no sound
                                            From the back of the TV I can see the red light on the back of the mother board
                                            Holding torch to the screen I cannot see a picture
                                            I removed the back cover
                                            Observing the boards I cannot see any damage
                                            I disconnected the main board from the power supply
                                            the back...
                                            08-30-2025, 09:40 PM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
