Samsung UN65H6203BF
  • otis11
    • Jan 2023
    • 27
    • us
    #41
    Re: Samsung UN65H6203BF
    Is this common to not have nothing showing on screen as in no graphics or video at all? if so iam going to strip the set and sell it for parts. thanks for all that has helped.I think i will stay away from back light instillation for a long while.
    • todor
      • Feb 2023
      • 16
      • България
      #42
      Originally posted by otis11
      This is a 100% broken display. No suction cups are used to lift screens, you have to push a thin and strong plastic board from the bottom and top of the screen that reaches almost the entire length and push it in very carefully, then lift both parts at the same time, thus avoiding bending of the panel and its damage
      • otis11
        • Jan 2023
        • 27
        • us
        #43
        So the boards are probably good? I would'nt want to sell anyone a bad board. Just wanted to recoup my money that was spent. However I would refund money for a bad board. Yes i did use suction cups, wow how easy that was, the whole set is flimsy just setting on the stand and to think it was loaded in the back of a pick up truck. no more of those for me. i wonder how a tv repair shop can make money with this sorta thing happening? you know the factory could and should put those in a sliding hinge. lights go bad slide out the panel and replace the lights without damage to the set, slide back in. easy peasy, that might make someone rich to come up with that idea?? "please share if you get rich on this". I never knew it when it happened.Thanks
        • alfatv
          • Sep 2020
          • 353
          You can crack it this way as even small pressure on the edge can cause it to crack. Suction cups are safer.
          On these Samsungs the tricky part is putting bezel back. Small misalignment and this is it.
            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
            I am comparing them to a brand new one that I installed
            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
            I going to let it run for several days before I remount back on the wall next to the...
            09-05-2024, 06:48 PM
            09-07-2024, 05:50 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • JohnML1975
            Samsung UA50TU8000W no picture and no sound
            by JohnML1975
            Hello All
            have seen posts on this model in here but my problem sounded different so thought i would create a thread
            TV will not turn on
            There is no standby light
            When I press ON button for remote the red standby light does flash but no picture and no sound
            From the back of the TV I can see the red light on the back of the mother board
            Holding torch to the screen I cannot see a picture
            I removed the back cover
            Observing the boards I cannot see any damage
            I disconnected the main board from the power supply
            the back...
            08-30-2025, 09:40 PM
          • Kaar3l
            Samsung QLED QE65Q7FNAT only standby light
            by Kaar3l
            TV: Samsung QLED QE65Q7FNAT
            PSU: BN4400940A
            MB: BN94-12832K
            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
            09-24-2024, 01:35 PM
