Need firmware for Sony KDL-48W600B
  • JohnCT
    Lurker
    • Apr 2018
    • 32
    • US
    Sony apparently deleted this from their support page.. Thanks.
    John
  • lotas
    • Jan 2016
    • 4805
    • Russia
    Re: Need firmware for Sony KDL-48W600B
    sony_tvupdate_2014_3003_gaa_auth
    https://drive.google.com/file/d/1W_7...pcWc8Tai2/view
    • JohnCT
      Lurker
      • Apr 2018
      • 32
      • US
      Originally posted by lotas
      Thanks sir.
      The file is only about 250M, most Sony bins are like 1.5G??
      John
      • Louis82
        • Feb 2012
        • 240
        I'm also looking for the file that works with flash drive. The only file around in the internet is 221Mb with extension BIN and it doesn't work. Does ANYONE have the file - FIRMWARE - SOFTWARE UPDATE?
        • lotas
          • Jan 2016
          • 4805
          • Russia
          Latest software version PKG3.004AAA.
          In the root directory of the usb flash drive there should be a folder named sony_dtv0FA40A06A0A6_00003301, and in the bin folder there should be a file, and not all flash drives will pick up the update, look for old flash drives of 1-2Gb.
          https://drive.google.com/file/d/1G21...DOBaTW/view​
          • Louis82
            • Feb 2012
            • 240
            Hi Lotas. Are you telling me that you have tried a software update on this tv model with the folder on the root and that it has worked for you? Thanks for replying
            • mateuszdg
              • Dec 2022
              • 16
              • United Kingdom
              Yeah, I have same problem with my KDL-50W756C. The Sony v5.457 software has been terminated on Sony website. Any chance someone may have that FW to share ?
              • lotas
                • Jan 2016
                • 4805
                • Russia
                v5.457
                https://disk.yandex.ru/d/Tau0sq1P2s-rOg
                • jjchico
                  • Sep 2025
                  • 3
                  • Spain
                  Hi!
                  I am trying to update the firmware of my Sony KDL-40W808C to v5.457, the last published by Sony but not available any more from their site.
                  I have tried your file with different USB drives. It detects the drive has a firmware update file but it keeps saying something like "I cannot update from that USB drive".
                  Should I try yet another USB drive? Or may be it is not the right file? Is there a file specific to my model?
                  Thanks in advance.
                  jorge.
                    • 12307
                    • U.S.
                    Maybe make sure the usb is formatted to mbr, Diah enlightened us on why a bunch of the usb drives were not working, THANKS Diah. Post 74 there: https://www.badcaps.net/forum/troubl...e-update/page4
                    • lotas
                      • Jan 2016
                      • 4805
                      • Russia
                      Originally posted by jjchico
                      Hi!
                      jorge.
                      I have two firmware versions: sony_tvupdate_2015_5457_eua_auth and sony_tvupdate_2015_5457_eub_auth. Which one do you have? There's no 40-inch version in this series, maybe a 43-inch version?
                      • jjchico
                        • Sep 2025
                        • 3
                        • Spain
                        Hi!
                        Thanks for your prompt replay. It is the KDL-50W808C, sorry.
                        I was able to download sony_tvupdate_2015_5457_eua_auth.zip from:
                        https://tv.update.sony.net/OND/0000/...7_eua_auth.zip
                        and it worked. "...eub..." did not work.
                        So I confirm the firmware in the link works for the KDL-50W808C, and probably many others in this series.
                        1. Unzip file.
                        2. Copy the .pkg file to the root of a FAT32 formatted pen drive.
                        3. Insert the pen drive into any TV's USB port.
                        4. The update should start, if not, unplug and plug your TV while your
                        pen drive is in.
                        Best!
                        • lotas
                          • Jan 2016
                          • 4805
                          • Russia
                          Hi!
                          1. Unzip file.
                          pen drive is in.
                          Best!
                          Ok! v 5.457
                          • dkneyle
                            Sony KDL-46HX850 Can't upgrade/update firmware
                            by dkneyle
                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                            09-25-2024, 10:44 PM
                          • joby91
                            SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                            by joby91
                            I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                            I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                            I found one chat about firmware on ************** forum but i cannot read the comments.
                            https://**************/forum/108-114100-1#880537
                            09-04-2024, 01:34 PM
                          • jason123
                            Sony Firmware for XBR-70X850B
                            by jason123
                            Hello
                            Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
                            I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
                            Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
                            Much appreciated.
                            05-17-2022, 12:42 PM
                          • AlexWhat
                            SONY KDL-65w850c need latest firmware 6.827
                            by AlexWhat
                            In 2022 SONY did "Termination of TV Software Update" for this model.
                            I did find older firmware but it can't be installed over newer one (rolled back)
                            Yes, got boot loop during android load so if that will not work then EMMC has to be replaced, I think.
                            12-15-2024, 11:32 PM
                          • cheeky2
                            Help with Sony firmware KDL-40W5500 v1.752EA
                            by cheeky2
                            Unfortunately Sony Have taken all there old TV firmwares down from there website last year. So it isn't available to download. Does someone have the firmware available please? It is used for a whole range of the KDL range of TV's including the following models :
                            KDL-22E5300, KDL-22E5310, KDL-32E5500, KDL-32E5510, KDL-32E5520, KDL-32V5500, KDL-32V5610, KDL-32W5500, KDL-32W5710, KDL-32W5720, KDL-32W5730, KDL-32W5740, KDL-37V5500, KDL-37V5610, KDL-37W5500, KDL-37W5710, KDL-37W5720, KDL-37W5730, KDL-37W5740, KDL-40E5500, KDL-40E5510, KDL-40E5520, KDL-40V5500, KDL-40V5610, KDL-40W5500, KDL-40W5710,...
                            01-28-2023, 06:13 PM
