Help identifying resistor?
  • mrkmpn
    • Apr 2022
    • 62
    This resistor is on a small board the fan connects to in a Brother MFC L5900DW. The fan does not work, and when testing this resistor it shows no reading all the way from 4M ohms, down the a continuity test, so appears to have failed open.
    I've tried using a coupld of resistor calculators online, but I'm not sure which end is which on the resistor, and going both directions on the calculators I run into a value that doesn't have the correct color as an option.
    I, believe the colors are black gold violet black orange, but maybe I'm mistaken on one of them?
  • R_J
    • 9623
    Re: Help identifying resistor?
    I think it is 300Meg (or 30Meg if 3rd band blue) and is basically to discharge any static charge to ground
    This seems to be the toner sensor board.
    The board has no control over the fan, it is just a pass through board for the connection to the fan
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      it's a 5 bands resistor , where the 4th digit is the multiplier , so if it's gold like you say , then it's 30.7 ohms , but frankly , I see it silver and if so , it's 3.07 ohms .
      • R_J
        • 9623
        Its a 4 band resistor with the last band likely indicating non-inductive, look at the back of the board.
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          R_J ; I'm treating the resistor as standards apply ; We know there could be exceptions , but I don't have this specific schema of Brother , neither the back image , although i have plenty. if you do , i'll take a look .
          • R_J
            • 9623
            The resistor goes from what is likely the negative trace to the screw mounting hole, without the mounting screw the resistor does nothing. So this is not likely the original posters problem
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              Yes R_J ; Absolutely convincing . This R1 sounds like , literally a dumper diode ,or noise reduction , i don't know for sure . It's definitely not the problem , and maybe the fan was clogged or age ended , so it triggered a protection circuit (hopefully) .
              I trust now it's non inductive also .
              • gica69
                Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                by gica69
                I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                Resistor shows orange range silver gold and green lines.
                Thanks in adv...
                07-21-2025, 09:49 PM
              • Baste
                What are the pro's and cons of replacing a 1/4 with a 1/2 resistor same ohms?
                by Baste
                As the title says. I bought a cheap Asus ROG Strix 750-watt PSU, which was posted as defective. Cables are complete, and the entire PSU is in good condition, of course, aside from being faulty. Long story short, upon checking, there is no +5VSB. Looking at the components, I found a blown resistor. I swear, looking at the bands, the color is pink, pink, gold, gold. I dunno if I'm color blind or this is the way resistors are coded.
                Please help, did I decode it correctly at 2.2 ohms (red, red, gold, gold), or what could a pink, pink, gold gold value be? I bought a...
                10-30-2025, 11:51 PM
              • ugamazing
                Assistance with identifying resistor value on 820-02918 A2992 board?
                by ugamazing
                Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
                I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
                09-06-2024, 08:33 AM
              • dutchgaucho
                Need help identifying resistor on Asus FA507RC DA0NJNMBAD0 schematic
                by dutchgaucho
                Hi colleagues,
                Looking for a schematic DA0NJNMBAD0 or the MP2845A 6-phase PWM controller.
                Working here on a DA0NJNMBAD0 rev D motherboard (Asus FA507RC) with liquid damage. Board has some tiny corrosion around the MP2845A controller and one resistor is missing. I need to know the value of the resistor, but no schematics are available. Not even for the MP chip or anything similar (this is a 6 phase PWM controller).
                On one side of the pad 20V is present. The other side connects to a cap and to pin 16 of the MP2845A. Resistor seems too small for VCC...
                11-09-2023, 11:27 AM
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
