Hitachi DV-PF4E VCR/DVD Combo - no power
  • Markie76
    • 81
    • United Kingdom - the land of 240v!
    I have a Hitachi DV-PF4E VCR/DVD Combo unit which is dead - no power.
    Last used and working ok about a year ago.
    Then it has stood unused in the tv cabinet unplugged from the mains.
    I went to use it this week, plugged it in and nothing happens, no display/lights, no response when pressing standby button.
    Opened to check and fuse ok, ac supply ok, caps all look ok, other components & pcb look ok with no trauma visible.
    Any cause for it to just go 'bad' by not being used for a year?
    Thanks,
    Mark
    • 31070
    Re: Hitachi DV-PF4E VCR/DVD Combo - no power
    startup capacitor in the psu is dead
    it will be small - 10uf > 47uf usually
    post a foto
    • Markie76
      • 81
      post a foto
      Thank you for your reply.
      There are three which fit the range;
      10uF 50v
      22uF 50v
      10uF 16v
      See 3rd attached pic with capacitor values shown.
      Thanks,
      Mark
      • vinceroger69
        • Mar 2012
        • 6714
        no 3 picture top right cap have you checked or changed that
        • Markie76
          • 81
          No I haven't done anything except for an AC & visual check.
          What is the best way to check/test it?
          Thanks,
          Mark
          • R_J
            • 9552
            Your power supply is slightly different than the one in the service manual, I'm not sure if the designations are the same as yours.
            Look for C1032, Likely the (10µf/16v), replace it, then check the two resistors R1011 (1.3Ω/1w) off the source pin of the mosfet and R1043 (2.7Ω/1w) between the + of the 100µf/400v cap. and the transformer, if the resistors are ok, it is likely the power supply is just not starting up.
            Also check if you have any voltages on the two plugs, CL051A and CL052A, There is also a zener diodes (D017) in the secondary, check that it is not shorted.
              • 31070
              probably the 10uf cap next to the big 400v one,
              i cant see a chip - got any underside photo's ?
              • Markie76
                • 81
                A number on the pcb which looks like a P/N: BH951 0F01 02
                C1032 is the small cap in top right as mentioned by vinceroger69 & stj - it is 10uF 16v.
                I'll try to test it out later or tomorrow.
                Yes the small cap next to the 400v one is the 10uF 16v one.
                No chips on it just transistors, large mosfets (?) and a 4 pin rectangular thing - see pics.
                Thanks.
                • lotas
                  • Jan 2016
                  • 4638
                  • Russia
                  Diagram of your power supply page 38
                  • Markie76
                    • 81
                    I've finally done some testing.
                    Capacitor C1032 - top right - 10uF 16v removed and in my multimeter;
                    Starts at 8.88 and reduces settling at 8.68uF;
                    Resistor R1011 (brown|orange|gold|gold) shows a changing value in the 2000k range - 1557k, 1605k...
                    Resistor R1043 (red|purple|gold|gold) shows 02.7 ohms.
                    Diode D017 shows .155 one way and OL the other way;
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      the capacitor could of failed esr wise the resistor r1011 are you sure of the colours as the calculator here says 1.3 ohms
                      https://www.digikey.co.uk/en/resourc...tor-color-code
                      • Markie76
                        • 81
                        Yes, close up pics below.
                        R1011: brown - orange - gold - gold = 1.3
                        R1043: red - purple - gold - gold = 2.7
                        It has what looks like a couple of cracks on the body;
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          in post 10 you say Resistor R1011 (brown|orange|gold|gold) shows a changing value in the 2000k range - 1557k, 1605k...it should be 1.3 ohms
                          • Markie76
                            • 81
                            • Markie76
                              • 81
                              Sorry my mistake I mixed them up!
                              I've probed them again and getting yet different readings
                              I'm going to remove them from the pcb to test.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                for odd readings i just the part best way really if they all test ok put all parts back in heat the psu up with a hair dryer and see if the player now works (some times heating bad capacitors up lowers the esr tempory and allows it too work)
                                • R_J
                                  • 9552
                                  It looks like R1011 is open, So I suspect Q1001 (2sk3566) is shorted, if it is shorted, Q1003 is likely bad as and likely more components in that circuit
                                  R1043 (2.7Ω) is ok. C1032 is BAD
                                  With the circuit not working, the main filter cap can remain charged to around 300vdc, this capacitor should be discharged (using a resistor or incandescent lamp can work) If it is not discharged, resistance readings in the rest of the circuit can be effected, not to mention getting a shock or the risk of damaging the power supply
                                  These power supplies are difficult to repair at the best of times, if any component is out of tolerance the circuit won't oscillate
                                  • Markie76
                                    • 81
                                    Thanks for the tip. I tried it but didn't make any difference.
                                    Oh, doesn't sound encouraging.
                                    BTW when I tried the hairdryer I measured the big 400v cap and plugged in it was only reading 209/210v.
                                    When unplugged it wasn't holding a residual charge - just showed up as 90-100ma 20 seconds after unplugging it. Does that mean it's dried up/bad?
                                    • Markie76
                                      • 81
                                      Thank you - I will have a look.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        i would do as rj suggests first, replace thet small capacitor remove and re test r1011
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • navagator
                                          Hitachi Power Supply Unit Interchangeability
                                          by navagator
                                          I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
                                          Does anyone know if these 2 power supply boards are interchangeable?
                                          Thanks.
                                          01-08-2024, 07:53 PM
