Hitachi DV-PF4E VCR/DVD Combo - no power
  • R_J
    • Jun 2012
    • 9607
    Re: Hitachi DV-PF4E VCR/DVD Combo - no power
    The main filter capacitor may also be bad, and check each diode in the bridge circuit, one might be bad as in open. You should have around 340vdc ACROSS the main filter capacitor.
    I suspect you are using chassis ground to check the main filters voltage and not hot ground and that is why the reading is low
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      03-31-2024, 02:12 PM
    • navagator
      Hitachi Power Supply Unit Interchangeability
      by navagator
      I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
      Does anyone know if these 2 power supply boards are interchangeable?
      Thanks.
      01-08-2024, 07:53 PM
