Samsung un70nu6900 power supply issue
  • yankys
    yanky
    • Feb 2012
    • 139
    HI, everyone needing a little help I have a 70 inc tv that has the turning on and back off issue. changed the main board no luck, checking the power supply and JP819 is only showing 4v i have 12.90 standby voltage can i assume that the power supply needs replacing. any help will be greatly appreciated.
  • lotas
    • Jan 2016
    • 4649
    • Russia
    Re: Samsung un70nu6900 power supply issue
    You have to check that. And disconnect the cable that goes to the motherboard and plug it into a power outlet, the backlight should light up.
    • yankys
      yanky
      • Feb 2012
      • 139
      yes, and the back light comes on and stay on as long as the cable is disconnected from main board.
      • lotas
        • Jan 2016
        • 4649
        • Russia
        Well, it means the power supply is working, or you also purchased a non-working board, or you do not have a working panel.
        Now try to connect it back to the motherboard, but disconnect the cables that go to the panel and check it will turn on from the remote control.
        • yankys
          yanky
          • Feb 2012
          • 139
          In the image your showing check jp821 to ground for voltage it shows 12.91.
          • yankys
            yanky
            • Feb 2012
            • 139
            With the cable to main board plugged in and the 2 ribbon cables unplugged tv will turn on with remote but turns off after a second or 2.
            • lotas
              • Jan 2016
              • 4649
              • Russia
              Nothing to worry about, no load (MB didn't start)
              • yankys
                yanky
                • Feb 2012
                • 139
                I'm not sure that I'm getting the 12v power on voltage.
                • lotas
                  • Jan 2016
                  • 4649
                  • Russia
                  Connect one at a time (first one cable, check, disconnect the first, connect the second and also check.
                  • lotas
                    • Jan 2016
                    • 4649
                    • Russia
                    You wrote above that you received 12.91v
                    • yankys
                      yanky
                      • Feb 2012
                      • 139
                      yes, 12.91 at the jumper in the image you sent but not at pin 8 in the plug that go to the main board, and when I do the cables, it turns on with remote and back of with in a second unless I unplug the main power cable to the main board then it will stay on.
                      • lotas
                        • Jan 2016
                        • 4649
                        • Russia
                        On 8 pin. should not be 12v, this is POWER ON (there is a signal to turn on the operating mode from the motherboard, and the jumpers are also connected to the 3-5-7-9 (12v) connector.
                        • yankys
                          yanky
                          • Feb 2012
                          • 139
                          If voltage is 12.91 at the jumper shown in the image does this mean power supply is good.
                          • lotas
                            • Jan 2016
                            • 4649
                            • Russia
                            Yes, if the unit were not working, then these 12.91v would not exist and the backlight would not light up.
                            • yankys
                              yanky
                              • Feb 2012
                              • 139
                              what should i check to further diagnose this issue?
                              • lotas
                                • Jan 2016
                                • 4649
                                • Russia
                                Try disconnecting these cables connecting the brackets, one at a time and with different motherboards (from your own and the one you bought).
                                • lotas
                                  • Jan 2016
                                  • 4649
                                  • Russia
                                  In these models (NU series), the panels (the matrix itself) die very often.
                                  • yankys
                                    yanky
                                    • Feb 2012
                                    • 139
                                    with disconnecting these one at a time am I looking to see if the tv stays on?
                                    • lotas
                                      • Jan 2016
                                      • 4649
                                      • Russia
                                      Yes
                                      Here is a video that can help determine the malfunction (and all the malfunctions of these models are panels).
                                      https://www.youtube.com/watch?v=atNmhu7HMj0
                                      https://www.youtube.com/watch?v=zGAVbMQrSek
                                      • lotas
                                        • Jan 2016
                                        • 4649
                                        • Russia
                                        And if possible, then disable the WI-FI module to check.
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
                                        • lp20th
                                          Samsung Plasma TV Power Supply Issue
                                          by lp20th
                                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                          11-28-2023, 10:28 AM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
