Fish Tank LED Power Supply Gets Hot then shuts down
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Re: Fish Tank LED Power Supply Gets Hot then shuts down
    Originally posted by stj
    yes, run it a see how much current is flowing
    and recap that psu starting with the output caps and the small stuff
    I think it's going to be cheaper for me to just replace it. And since I'm doing that, I think it might be even better to try and replace both of them with a single PSU.
    sigpic
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      So, with just one power supply connected, and turned on, the 5V line is drawing 5.6 amps.
      sigpic
        • 31190
        thats a hell of a lot - i wonder what it's driving!
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          Yeah, I thought so too ... I dunno what it's driving, but I do know that this very product put them out of business because someone else got a patent on whatever is inside of the lightbox ... but I couldn't begin to speculate on what's so special about these almost $2,000 (at the time) fish tank lights nor why they were so popular.
          So at this point, I'm looking for a 1,000 watt ATX power supply that can supply 15 amps on the +5 and 20 to 25 on the +12 minimum. They aren't cheap though.
          sigpic
            • 31190
            i read that they got put out of business by a bogus patent for " a light fixture containing leds that mounts on top of an aquarium enclosure"
            thats almost as bad as the bullshit between apple and samsung over "rectangular casing with rounded corners"
            and "progress bar to indicate remaining time for software to complete a task" or some shit like that.
            Putin needs to bomb your patent offices!
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              Well, The patent office would never grant a patent purely on such a vague description. And from what I read, it was about the technology inside the light that was at issue. I don't know why it's so special ...
              What really concerns me about the whole patent thing is that this company was manufacturing and selling these lights long before the other company got its patent. And I would tend to think that they would have been exempt from any liability given that being true ... I mean what's to stop someone from stealing an idea, getting a patent on it then screwing the inventor? Just doesn't seem right to me.
              But what are your thoughts on using a single 1000-watt ATX for these lights? You think it will work?
              sigpic
                • 31190
                i think you need to check the current on the 12v line.
                it could be mostly using 5v,
                those old AT psu's had mostly 5v output, the 12v was only for the harddrives.
                in that case an ATX is useless because their main output is 12v
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  My meter will bust a fuse after 10 amps and those fuses aren't cheap.
                  OK, so I read it with this shunt resistor
                  And I read 44mV when it settled down ... initially it was over 50 but that didn't last more than half a second or so.
                  Not sure how to calculate the current based on what I have here...
                  I photoshopped the lettering on the shunt so its easier to see.
                  Also, the red circles are where the wire was connected and I took the reading at the green circles.
                  After doing some Googling, I think what I'm seeing here is that there is 8.8 Amps on the 12V side.
                  And if that is the case, then if I double the amps, that would be roughly 16 to 20 amps on 12 and about 10 to 15 amps on 5 ... wouldn't an ATX work in this situation if I got one rated for 1,000 Watts that could handle 25A on 12V and 15A on 5V as a minimum requirement?
                  sigpic
                    • 31190
                    20A on each rail is under 500w i'm sure.
                    tempting to use 2 chinese psu's - one for each voltage.
                    or a meanwell dual output - if they have a compatable one
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Take the lamp apart and see how it's wired. Using that much +5 when +12 is available is kind of weird.
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        Are you thinking that might have been a possible cause for the one power supply dying?
                        sigpic
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          No, I'm curious why it's drawing 28W on the 5V line
                            • 31190
                            dont you have a DC clamp-meter btw?
                            i thought everybody got one when uni-T released the cheap one!
                              • Jul 2011
                              • 6063
                              I had one but I did not think it was that cheap but it only lasted a couple of years and then it would not read any dc current anymore
                              I just have not bought another one yet but plan on doing this again when I need to have one for something that I can not use my meter for
                                • 31190
                                maybe the opamp died - easy to diagnose the fault in them.
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  I don't have a clamp meter ... got a recommendation?
                                  sigpic
                                    • 31190
                                    UT210e
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8326
                                      Uni-T, Bside, Extech, Fluke…
                                      The only thing about Uni-T is that you have to make tripple sure it’s the meter you want. Some are doing only DC, not AC, etc. Your better off to go to the official Uni-T website and see what you want, then look for that specific model. Then compare pics etc.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #59
                                        Yeah, another vote for the UT210e from me.
                                        • EasyGoing1
                                          Shock Therapist
                                          • Sep 2016
                                          • 977
                                          UT210e
                                          Could this meter replace my MESR-100 ESR meter? Does it have ESR capability? If so, I could send this one I just bought back and get the UT210E almost at a straight swap - cost wise.
                                          sigpic
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
                                          • bouny56
                                            Lenovo E15 Nm-c421 usb-c work only in one side
                                            by bouny56
                                            ​Hello
                                            Laptop E15 I5 10gen
                                            Mb nm-c421
                                            I have a problem with the usb-c power dc.
                                            The motherboard start only in one side of the usb-c
                                            Replace the usb-c port 2 times same problem
                                            With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
                                            Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
                                            Can the pd controler be the fault ? Or something else maybe ?
                                            Thx
                                            02-11-2025, 03:15 AM
                                          • huzo
                                            HP Omen shuts down when loading OS
                                            by huzo
                                            The model is 15ec-1061nm
                                            Board number is DAG3EDMB8D0​
                                            SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                            10-29-2024, 12:05 AM
                                          • brav1ez
                                            ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
                                            by brav1ez
                                            I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
                                            I’ve tried:
                                            - CMOS reset
                                            - Removing the SSD/HDD
                                            - Reseating RAM (removing each stick individually stops boot completely)
                                            - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
                                            With...
                                            09-07-2025, 10:47 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
