PC Restarting/ Shutting off abruptly.
  • bhvm
    • Mar 2010
    • 52
    • India
    #61
    Re: PC Restarting/ Shutting off abruptly.
    370, (is that pentium 3 socket 370?)
    There are no Shunts like that. But personally I can confirm it has OCP. I mistakenly touched +12v to case when installing some Lights, the SMPS shut down instantly. It came back after a-unplug-the-cord-plug-it-again song.
    also,
    Look again at the pics here-
    https://www.badcaps.net/forum/showpo...1&postcount=18
    Can you show here is the PPFC? The big blue transformer sitting adjacent to the fan?
    • Scenic
      o.O
      • Sep 2007
      • 2642
      http://i59.photobucket.com/albums/g3...S/IMG_3949.jpg
      that's the (passive) PFC
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Yeah.
        But anyways,
        Shorting the 12v to ground (the case) is just short circuit protection, all psu's have that.
        Yes, that big inductor next to the fan and primary caps is the PPFC inductor.
        • bhvm
          • Mar 2010
          • 52
          • India
          #64
          Originally posted by Scenic
          yeah thats what I thought. The big blue one near the fan.
          How much PF improvement can it bring? In range of (effective PF) 0.7~0.8?
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            It'll bring it up to anywhere from .7 to .75.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Originally posted by Newbie2
              The efficiency of a power supply and its PF (power factor) are two different things, I feel they should not be directly compared like they are in this argument.
              YES
              Every time I talk about one or the other 'someone' mixes them together.
              They are related only because to calculate efficiency you need the watts input - and PFC screws with watt input measurements.
              The overall efficiency of a power supply may drop due to having more parts for the PFC, however it is probably small
              Exactly the same magnitude as that one PSU's effect to the power companies equipment.
              the engineer or engineers who designed the power supply would've implemented more efficient parts elsewhere to help offset the efficiency loss caused by the PFC.
              But those more efficient parts can be used without PFC as well making the PSU even more efficient.
              If you wanna have some real fun calculate the efficiencies all the way back to the oil, coal, or nuclear fuel at your power plant.
              For instance calculate how much U-235 [or oil or whatever] you waste if you leave your PC on for year.
              Mann-Made Global Warming.
              - Dr Seuss
              • bhvm
                • Mar 2010
                • 52
                • India
                #67
                Thanks mate, you taught me a lot today.
                By the way one observation, If I put Lights and RAID array on the same Channel, I can see Lights flickering during spin-ups and Seek. And thats where the problems happen.
                With Lights (and the DVD...And fans..) On different channel, The flickering is still preset, but far less.
                Upon reading some data sheets at the Seagates, they say each HDD takes 2.8 Amps for spin up (not sure if thats combined 12v+5v) and with more HDDs it gets serious.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Originally posted by bhvm
                  Wow folks,
                  Did I mis some battle?
                  We are only nice to new people.
                  Once you hit 100 posts you'd better bring your boxing gloves.
                  - Dr Seuss
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    That's the coil for it.
                    Is the rest mounted under the coil?
                    - Dr Seuss
                    • bhvm
                      • Mar 2010
                      • 52
                      • India
                      #70
                      Originally posted by PCBONEZ
                      YES
                      Thats damm bad!
                      We're already starving for electricity over here. The 6 hour power cut will painfully increase to 8 or 10 in summers.
                      I have a laptop for all the 'light' tasks such as surfing, chatting, downloading and music. I only fire up this beast when I need to edit Videos/photos ( I do HDRs) or enjoy some game.
                      And yeah, does Ghost sniper look completely Captivating on the 9800GT or what!?
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        that clearly doesn't sound good
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          May be a cheap logisys or other brand inverter being used for those CCFL's.
                          • Oklahoma Wolf
                            • Dec 2005
                            • 353
                            #73
                            The dirty little secert about those reviews is both the 4-1850 and the Kill-A-Watt they used don't check Power Factor
                            Sorry, but this is not correct. They both do. I don't test for PF, but that doesn't mean I can't
                            The units that can actually fool them are few and far between. I've had only two in three years I think. Usually when the efficiency numbers are off in comparison to the 80 Plus test results, it means I have a test equipment failure to go find.
                            Had it happen not long ago when the Diablotek "1050W" unit blew out on the primary side. It fried the current measuring shunt resistor inside the Brand. From there on out, everything read light until I replaced the resistor. The KAW was ok... it has a beefier shunt.
                            That said, these aren't the most accurate meters in creation (5% for the KAW, 2% for the Brand), which is why I'm upgrading soon. The Brand is currently more accurate than ever, but it's still not quite the caliber of test equipment I need. Especially now that I'm using the Tektronix scope.
                            • Behemot
                              • 4845
                              • CZ
                              #74
                              PFC allows the power companies to MOVE the heat losses in their equipment into their consumers equipment.
                              - Does that save any energy --- NOPE!
                              - Is that Green --- NOPE!
                              Man I see it now, you either don't have a clue about energetic industry or you're totaly insane.
                              It's not only heat loses. The electricity which is not used, I mean the passive power, has to flow back to power plant. It means even hundreds of thousands kilometers of wires!! The loses are far worse, PFC could add what, 1 % extra heat? Loses in energetic distribution grid are up to 15 %.
                              So I'd rather pay few extra cents per year for PFC than several extra cents per every kW if distributors had to build far more robust grids!!
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                other parts of the psu's are much more efficient and put out much less heat than old designs
                                OLD NEWS - That was already one of my points here.
                                - Good god I must have said that in 20 threads by now..
                                Newer PSUs are more efficient due to improvements THAT DON'T HAVE SQUAT TO DO WITH PFC.
                                Newer PSUs are ~NOT~ more efficient due to PFC.
                                -- That claim by manufacturers is an outright LIE.
                                > PFC wastes heat > in YOUR house
                                > and YOU use more AC to take that heat back out of your house.
                                -- In the summer it's a double whammy..
                                You not only get to pay for the power companies heat losses,,,
                                you get to pay some more to dissipate the heat from it.
                                [How does that save consumers anything,,, except maybe in winter..]
                                - Dr Seuss
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3112
                                  I was never ever talking about PFC directly related to increased efficiency.
                                  I simply agreed that newer designs are more efficient due to new topologies and lower loss parts.
                                  Yes, I agree manufacturers should not say that APFC makes psu's more efficient. Many of them do.
                                  What I was talking about is apparent power vs active power, and having a higher pf simply saves the power companies money and makes psu's a little less efficient (and expensive)
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I must be insane then.
                                    I'm a retired nuc plant operator.
                                    Also been an electric plant operator on a 2 Gigawatt 4160v grid.
                                    The stuff you see in ads is bull shit.
                                    You see it so many times you believe it.
                                    Guess what.
                                    SATA 3.0 doesn't any faster than SATA 1.5.
                                    [Except for maybe the first 4-5 milliseconds.]
                                    Same thing.
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      That's who you worded it bro...
                                      - Dr Seuss
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3112
                                        Show me the example of when I did that. I want to see this.
                                        • mur
                                          • 21
                                          #80
                                          New PSUs WITH APFC nowadays go up to 90% efficiency.
                                          And if APFC were so inefficient the rest of PSU would need to be over 100% efficient to cover it up for APFC and to still achieve 90% as a whole PSU (probably even to get 80%).
                                          Also, most of people here agreed that with you 20 or more posts before. No need to say it again.
                                          • rumpumpel1
                                            ThinkPad T460p keeps restarting instead of shutting down
                                            by rumpumpel1
                                            I have a ThinkPad T460p that keeps restarting instead of shutting down. The culprit is the LAN: if it is disabled in the BIOS, the problem is solved. I have already replaced the LAN chip (WGI219LM) twice, done CleanME, flashed another BIOS. Unfortunately all without success. What else can I check?
                                            04-28-2024, 12:26 PM
                                          • Maniackk
                                            Yoga 530-14ARR NM-B781 Ryzen 3 2200 – overheating and shutting down under load
                                            by Maniackk
                                            I’ve got a stubborn patient here. The laptop powers on and works, all components like the screen, keyboard, touchpad, etc. are functional. The issue is that it heats up very quickly under load (within a few minutes up to 95°C) and then shuts down shortly after. Subsequent attempts to turn it back on right after a “hot shutdown” result in it shutting off within a few seconds. Interestingly, if I enter the BIOS, it can stay there for 2 days without shutting down (most likely due to low CPU load and low temperatures).
                                            The cooling system has been cleaned, thermal...
                                            09-03-2025, 09:32 AM
                                          • dkneyle
                                            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                            by dkneyle
                                            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                            02-01-2022, 02:08 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • abhishekkumar1902
                                            Huntkey HK340-72FP SMPS shut on load above 2 amps
                                            by abhishekkumar1902
                                            I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                                            I have checked the following:
                                            1. All output caps are OK, and all output rails read correct voltages at no load
                                            2. All output diodes are OK
                                            3. NTC is ok
                                            4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                                            5. No short in main switching MOSFET
                                            6. All other components...
                                            12-18-2022, 09:52 AM
