Are the primaries used on 240V power lines?
  • c_hegge
    • Sep 2009
    • 5219
    After reading the HardwareSecrets PSU anatomy, it seems like the voltage doubler (where the two primary caps are) is only used when the PSU is set to 120V. If that is the case why have I seen them bloat before on 240V? (e.g. here in my post on ratdude's PSU carnage thread)
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Are the primaries used on 240V power lines?
    The voltage doubler is not used, the caps in it are but the voltage isn't doubled.
    Mann-Made Global Warming.
    - Dr Seuss
    • severach
      • Aug 2007
      • 1055
      120v AC rectified produces 160v DC.
      When the voltage doubler is used 160v is placed across one cap and the voltage doubler makes 160v appear across the other cap. The 320v across the two caps in series is sent to the switchers.
      When the voltage doubler is off 320v is placed across both caps providing 160v for each. The voltage across the two caps in series is again 320v.
      Ether way both caps see the same voltage when the switch is set properly. When wrong the power supply shuts down constantly or lets out the magic smoke.
      sig files are for morons
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Here
        - Dr Seuss
        • c_hegge
          • Sep 2009
          • 5219
          OK Got it. The way Hardwaresecrets put it made it seem like that part of the PSU was bypassed altogether when set to 240V.
          • Wizard
            • Mar 2008
            • 2296
            That diagram is incorrect.
            110V mode puts both capacitors in doubler mode via pair of extra diodes to get appox 300V. In 240V mode, the doubler circuit is switched out and put across both capacitors and yet get about 300V or so due to rectifier's peaks is higher than average voltage.
            Cheers, Wizard
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Cheers, Wizard
              Then fix it.
              - Dr Seuss
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Please tell the author of the article so he can fix it
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Not going to happen.
                  Dunno where it came from.
                  - Dr Seuss
                    • 31280
                    that's one fucking ancient diagram,
                    it has NEON spark-gaps across the input and to earth!!!
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Probably. I just snagged the first one I saw.
                      - Dr Seuss
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • Stanley1843
                        by Stanley1843
                        06-29-2024, 11:54 AM
                      • jeyoung12
                        Samsung QN50Q60t lines on screen
                        by jeyoung12
                        Hi all
                        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                        So....i don't know what end of the C ribbon to work with...
                        02-26-2024, 10:38 AM
                      • pni
                        LG 49uf695v vertical coloured lines
                        by pni
                        Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                        Today, 03:15 AM
                      • Rubenlily
                        Samsung QE50Q67TAU - horizontal lines
                        by Rubenlily
                        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                        I'm no expert but I've done the tape...
                        08-16-2023, 01:12 PM
