CAPXON replacement caps for PS
  • SnakeBite
    • Jun 2010
    • 4
    I'm new in this forum.
    i a CAPXON caps in my creative s750 speakers power supply and i want to replace them tio a beter one.
    the spec of the caps are CAPXON 470UF 200V , VENT , 22MM diameter (0.86") , snap in. i added a picture.
    I searched in digikey and found a few that fit please help me choose (i add a picture).
    if you find a beter one in mouser or ebay that fine .
    thanks
    Ido
  • etnietering
    • Apr 2009
    • 379
    Re: CAPXON replacement caps for PS
    I've used the Panasonic TS-ED series on several occasions, and haven't had any problems.
    • acstech
      GrumpyModerator
      • Jul 2007
      • 1432
      I'd either get 'em here through TC, or get Digikey part number P11613-ND.
      A man convinced against his will is of the same opinion still.
      • robert
        • Jan 2008
        • 69
        Pretty much any of the capacitors in your list are okay.
        I would just pick the TS-ED, since the price is okay and these are well known high quality parts.
        Since audio equipment doesnt operate at high average power levels, stress isnt that great (CapXon doesnt need any to fail, time is enough). If its running very hot, 105° rated capacitors would be a good idea, otherwise any good quality 85° unit will be sufficient.
          • 31067
          good quality 85' ?
          LOL
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            kze is a good example. if you keep temps in spec, they are great. the reason they are bad on motherboards is they are misused- the temps can co over 85C...
            sigpic
            (Insert witty quote here)
            • robert
              • Jan 2008
              • 69
              Good quality 85° as in, for example:
              BHC ALC10
              BC 050,053
              Epcos B43511
              Hitachi HP3
              Nichicon LGU, LLC
              Panasonic TS-UP, TS-UQ
              and a lot more. Also, most large screw terminal capacitors are rated for 85°, too. And all these last very long...
              • SnakeBite
                • Jun 2010
                • 4
                thanks for you all. i have two more caps of capxon that i need to replace:
                Capxon 330uf 100v 85c 12mm dia.
                i have this list i'm thinking to replace it with 105c cap is this ok?
                i add the list from digikey
                what whink about the UHE2A331MHT-ND (second the list) ??
                thanks
                ido
                • robert
                  • Jan 2008
                  • 69
                  Yes, Nichicon HE is all right. Long life and known good quality.
