I have an LG LCD tv (47LC7DF-UK) the picture only comes up after numerous times turning the set on and off. I hear buzzing coming from the SAMWHA capacitors (450WV 150uF) and wonder if these are snap-in capacitors. The name is confusing and I think that I can replace them by pulling them out and pushing new ones in. However I looked at the back and see the soldered parts and wonder if I am just delusional. Does anyone have any input? Thank you!
Snap in Capacitors
Re: Snap in Capacitors
caps are almost always soldered. samwha's are bad anyway, so solder in new ones. DO NOT PULL!
pics would come in handy (see the "manage attachments" section in the new post page.sigpic
(Insert witty quote here) -
Snap in caps feet are bent like a claw so they can be pushed down and snapped into the holes on the PCB. This allows them to stay on the board so you can flip it over to solder.
The same thing is accomplished by bending the legs sideways on regular leaded caps.
Solder makes the permanent connection there is no way you could just snap in a line voltage cap the effects of arcing if it didn't make perfect contact would be disastrous.Elements of the past and the future combining to make something not quite as good as either.Comment
Here is a picture of the capacitors. Are SAMWHA capacitors okay to buy and put back in or should I buy something different? Anywhere good to get them or just go on Ebay? Also, can anyone send a link of how it is best to solder. I soldered back when I was a Boy Scout but that was quite a while to go. Thanks again!Comment
FAQ on recap (excellent pictures and explanation) right here at
https://www.badcaps.net/forum/showthread.php?t=485
I like this solder video at
http://www.youtube.com/watch?v=I_NU2ruzyc4
Originally posted by mwturtle1Here is a picture of the capacitors. Are SAMWHA capacitors okay to buy and put back in or should I buy something different? Anywhere good to get them or just go on Ebay? Also, can anyone send a link of how it is best to solder. I soldered back when I was a Boy Scout but that was quite a while to go. Thanks again!--- begin sig file ---
--- end sig file ---Comment
Thank you very much. One more question, I think. I should discharge the energy from the capacitor since it hasn't exploded or bulged yet, so what do I do. Allow the uninstalled board to sit out of the tv for an hour or use something to discharge the energy? Thank you.Comment
It is best to wait about an hour for the uninstalled board to discharge, then measure the voltage on the 450V capacitors (and any capacitors over 35V) to confirm it is safe to handle.
For replacements for the Samwha LP Series, I recommend Nippon Chemi-Con KMH (or the more compact KMM) Series.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Thank you for the replacement capacitor ideas. I've been thinking, "is this problem the capacitors?" I hear the buzzing/whirring from what I think is the large capacitors, but could it be something else from what my first post explained? I also have other smaller capacitors that look to be blowing their tops, but the actual noises are coming from the two larger capacitors that I sent a picture of? Very confusing for a newbie? Thank you.Comment
the 1st picture shows 450v 150uf x2, outputting 300uf. I believe parallel caps have a longer lifespan compared to a single cap. I see nothing wrong.
the second picture shows at least 3 bloated caps. This is the problem when they bloat; they lose capacitance and gets high resistance. Then they make the semiconductors take in more current than usual.Comment
The caps in the second picture are most likely to be your problem. replace them first.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Replace the smaller capacitors first, if the tops of the big capacitors feel flat, leave them alone for now.
In this photo:https://www.badcaps.net/forum/attach...chmentid=16217 it looks like there is one in the top left hand corner which is actually open.
You could test the big caps with an ESR/capacitance meter.Last edited by seanc; 06-13-2010, 08:10 AM.Comment
Discharging is simple. First measure, then, if theres significant voltage on it, use a power resistor like 10kOhm 10W (with old multimeter test leads connected to it) to discharge safely, then re-check for voltage.
For your actual problem, replace all of the smaller capacitors, Samwha is known to be trash, and on your pics several of them are faulty, and these that are not yet burst open, will fail soon.
I would use United Chemicon KY or LXY, Nichicon PW, Rubycon YXF or ZL, Panasonic FC,FK or FM series as replacement.
If you want to do a good job and the device is worth it, replace the larger Samwha capacitors too, with 105° long-life parts from Panasonic, Rubycon, Nichicon, Chemicon, BC Components or Epcos.
Digi-Key or Farnell is a good source for replacement parts, Ebay or local electronics stores are NOT.Comment
In the top left corner of the first photo, a(nother) vented cap is visible (not sure if it's in the second photo as well). If that's buzzing, could it be close enough to those snap-ins to make it seem like they're making sounds?Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
The placement is pretty different, but maybe the vented caps are causing the sound to come from the larger caps because they have to work harder maybe. I bought plenty of each and will most likely replace all with rubycon caps in order get rid of the samwha caps. Thank you.Comment
FYI-
About an hour ago, I was running my Samsung lcd tv with the back off to see what was hissing before the picture went out. I heard the hissing start and leaned closer to the power board to pinpoint the source. One of those 450v 150uF caps jumped and then exploded into flames! Scared the crap out of me, to say the least. Earlier, I had changed out the 2200uf caps like everyone else and that didn't fix my problem so I had to do something more drastic and this definitely showed me which caps are bad! Now I know what the inside of a capacitor looks like, lol. Good luck with your replacement!
P.S. My big caps had looked bulging but I read that those don't usually go bad. Live and learn. I also wondered about the snap-in aspect of the caps I ordered so I'm glad you asked.Last edited by lauriloo; 06-21-2010, 08:21 PM.Comment
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
Channel: General Capacitor Questions & Issues
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
by ctroxtellI picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
- Loading...
