Stumped this weird G4 power supply problem
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Stumped this weird G4 power supply problem
    what brands did you order?
    sigpic
    (Insert witty quote here)
    • JOHNBOY
      • May 2010
      • 78
      #102
      I ordered the ones from capking. samxon and rubycon low esr. Now I only need the 2700@6.3v , 680@35V and a couple of the tiny ones.
      • JOHNBOY
        • May 2010
        • 78
        #103
        What's the difference between low esr and low impedance ?
        • Toasty
          • Jul 2007
          • 4171
          #104
          None. Just different manufacturer's ways of saying the same thing.
          veritas odium parit
          • JOHNBOY
            • May 2010
            • 78
            #105
            I'm having a hard time finding low ESR for the small likes .47uf and 47uf .. Does ESR matter on these ones too ? Can anyone recommend a good brand and series for these last two.
            47uf 25v
            .47uf 50v
              master hoarder
              • May 2008
              • 12175
              #106
              The 0.47uF ones I won't bother with.
              As for the 47uF caps, you can use either PW, HE, and PM from Nichicon, FC and FM from Panasonic, KY, KZE, and LXZ from United Chemicon, or Rubycon ZL (and maybe even YXG if they make them with those specs).
              Both Mouser and Digikey should have PW and FC for sure. Mouser also has PM in ammo packs which are pretty cheap.
              • JOHNBOY
                • May 2010
                • 78
                #107
                Digikey is no good for canada. They charge $20 to ship 2 caps.
                A couple of websites have some listed but they are sold out.
                Ebay is mostly flakes and garbage stock
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #108
                  Actually it is $8USD shipping from ca.digikey.com.
                  For Canada, try your local MRO store. The one that I contacted custom ordered two United Chemicon caps and didn't charge me anything extra. Of course the caps were $1.50 CDN each versus the 50 cents online, but it saved me shipping.
                  --- begin sig file ---
                  --- end sig file ---
                  • JOHNBOY
                    • May 2010
                    • 78
                    #109
                    What is a MRO ?
                      03-31-2024, 02:12 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • ashan000
                      yx-305d bench power supply decreasing voltage problem
                      by ashan000
                      This power supply is 30v 5amp. Problem is when turned on after about 3 minutes voltage starting to decrease slowly. (like - 5.8 > 5.7 > 5.6 > 5.5) can't see any damaged component or dry solder joints. Checked main 2 transistors with multimeter. Reading seems ok. Tried changing potentiometers(both coarse and fine) still the same situation. Can any one help me to troubleshoot? What voltages to check? Any ideas helps to fix this. thank you.!
                      07-12-2025, 08:43 PM
                    • chaos-theory
                      Nitro rx580 very weird problem, VCORE and EN
                      by chaos-theory
                      Hello!
                      I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
                      All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
                      08-17-2024, 04:56 PM
                      07-01-2024, 06:34 AM
