Stumped this weird G4 power supply problem
  • Khron
    • Sep 2006
    • 1350
    • Finland
    #81
    Re: Stumped this weird G4 power supply problem
    More often than not, electrolytics are specced with a tolerance of +/-20% (code letter M, on some).
    Aaaand you might wanna check the FAQ Preferably ALL of it (well, the first 11 posts, at least)
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • JOHNBOY
      • May 2010
      • 78
      #82
      I put a one of the low ESR caps in the pic to tease you guys.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        #83
        It would be nice if we could actually SEE something there, too
        • JOHNBOY
          • May 2010
          • 78
          #84
          What's the problem with it. The pic looks fine to me. I know its low res but I took it on my nokia with no flash.
          • Khron
            • Sep 2006
            • 1350
            • Finland
            #85
            Well, a better look at that "low esr" cap, for instance? Or maybe i just missed the object of the "tease"
            • JOHNBOY
              • May 2010
              • 78
              #86
              This was my original intention before you guys set me straight. The upper left with the gold is the ultra low ESR, right below it in blue is 'forever' and some other unknowns, some of the littles ones are rubycon and samxon, the little ones on the strip are IT or ITT. My good ones are coming next week.
              • JOHNBOY
                • May 2010
                • 78
                #87
                Looking at it now altogether and it does look like a ghetto recap.
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  i wouldnt even bother soldering that crap in o.O
                  the only useful (quality) caps are the nippon chemicon (the brown one) and the panasonic above of it. both not low ESR though..
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #89
                    I'm still learning about DMMs, but how is this cap tester from ebay different from a DMM that has capacitance tester built in (other than min/max range)?
                    BTW, for the Canadians, I see that Canadian Tire has their full autoranging DMM on sale for $20 (regular $60). This one has a capacitor test included.
                    See (Product #52-0052-2)
                    http://www.canadiantire.ca/AST/brows....jsp?locale=en
                    Manual is at
                    http://sitebuilder.tradeeasy.com/sho.../52-0052EN.doc
                    Manual says 40nF to 100uF which would be limited use for LCD monitor testing as many the caps that I see bloated are 470uF, 680uF, and 1000uF.
                    And yes, I have been to eevblog and watched Dave Jones' multimeter shootouts with facisination.
                    --- begin sig file ---
                    --- end sig file ---
                    • JOHNBOY
                      • May 2010
                      • 78
                      #90
                      It isn't any different in function except that those ones included in a multimeter generally have a smaller range. The ones built in to a DMM are 200uf to 400uf. I'm sure there are better ones but the $50 range is all under 400uf. So I get up to 20mf with this and I already have a good DMM so I didn't want a cheap 2 in 1. Some on ebay went to 2000uf , even that isn't good enough for a G4 as the trouble caps are 2200/2700/3300.
                      Where do you see a capacitor tester in the CT model ? That seems like a big sale but really that DMM is usually $20-$25 from the stores I go to without a sale.. It isn't bad for $20, if someone needs a first model this is a good buy.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #91
                        The cap function is just right of the off button on the DMM. The cap probe jack is the same as the volt/ohm. It is also documented in the manual for this DMM.
                        I see that some LCD and plasma TVs use 3300uF caps.
                        • JOHNBOY
                          • May 2010
                          • 78
                          #92
                          I see now.. but only up to a 100uF
                          • Khron
                            • Sep 2006
                            • 1350
                            • Finland
                            #93
                            JOHNBOY, i think you'd be best off checking the BadCaps stock (on the home page) and place an order here. At least you'd be sure to get quality low-esr caps.
                            Disclaimer: I have no business interest, i only believe it would be the simplest way out for all parties involved
                            • JOHNBOY
                              • May 2010
                              • 78
                              #94
                              I contacted the guy who sells them. He never replied, I contacted him again 2 weeks later, he replied this time but never replied to the order request. Waste of time.
                              • JOHNBOY
                                • May 2010
                                • 78
                                #95
                                Which series are acceptable out of these for my power supply ?
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3112
                                  You don't have to email him with your order, just go to his store on the main site and start shopping.
                                  https://www.badcaps.net/pages.php?vid=22
                                  https://www.badcaps.net/pages.php?vid=24
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    yeah, go shop and have fun... use the store...
                                    sigpic
                                    (Insert witty quote here)
                                    • JOHNBOY
                                      • May 2010
                                      • 78
                                      #98
                                      No good. He only has about half of them required and out of that half several are out of stock.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        didgikey or mouser then...
                                        sigpic
                                        • JOHNBOY
                                          • May 2010
                                          • 78
                                          #100
                                          I'm fine. I already ordered most of them, just need to know what works out of those rubycons for the last few.
                                            03-31-2024, 02:12 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • ashan000
                                            yx-305d bench power supply decreasing voltage problem
                                            by ashan000
                                            This power supply is 30v 5amp. Problem is when turned on after about 3 minutes voltage starting to decrease slowly. (like - 5.8 > 5.7 > 5.6 > 5.5) can't see any damaged component or dry solder joints. Checked main 2 transistors with multimeter. Reading seems ok. Tried changing potentiometers(both coarse and fine) still the same situation. Can any one help me to troubleshoot? What voltages to check? Any ideas helps to fix this. thank you.!
                                            07-12-2025, 08:43 PM
                                          • chaos-theory
                                            Nitro rx580 very weird problem, VCORE and EN
                                            by chaos-theory
                                            Hello!
                                            I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
                                            All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
                                            08-17-2024, 04:56 PM
                                            07-01-2024, 06:34 AM
