Help figure out burnt up resister values after fireworks(:
  • sdinelli
    Sdinelli
    • Aug 2014
    • 152
    Hello all
    fun times here tinking with the electronics.
    Minifridge PSU blew up. i replaced a diode bridge rectifier and one mosfet that was shorted. a blown fuse and the varistor.
    ( yes i know i should have replaced both mosfets. Im learning)
    i didnt really find anything else wrong so i plugged in and got some high pitch sounds and after 5 secs fireworks went off.
    Two resistors fried.
    trying to figure out the values of them. No way to tell but hoping someone can give me a general safe bet based on knowledge of switching PSU's.
    ive also found a 4.7cap measuring only 2.3uf, shorted zener diode and out of spec 10ohm(i think) resistor attached to that rail.
    The other diodes in teh area are measuring OK
    See picture. ive circles all the components red.
    please let me know what you think happened and what the values could be. and anything else to check.
    Thank you in advance
  • CapLeaker
    Leaking Member
    • 8178
    Re: Help figure out burnt up resister values after fireworks(:
    So what are the markings on the Mosfet? Specifically the one with the burnt resistors. If the Mosfet is shorted to the gate, you also have to look at the whole gate drive circuit!
    • sdinelli
      Sdinelli
      • Aug 2014
      • 152
      Base and collector shorted on the fet
      pins 1 &2
      the diodes in the bridge rectifier are testing fine, caps look ok.
      im afraid the resistors in there might be fried. i have to pull them to test.
      not getting a proper reading.
      • sdinelli
        Sdinelli
        • Aug 2014
        • 152
        They were two 150k resistors. tested good
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          I’ve had good luck cutting burnt resistors in half that are open and then doubling the resistance of whatever I can test ��
          • sdinelli
            Sdinelli
            • Aug 2014
            • 152
            well as is, one measured 375ohm and the other 2.4kohm
            i cut the 2.4ohm in half not really sure how to test now lol
            • R_J
              • 9547
              The resistors have location numbers, which are you looking for? ie: R04 = 10Ω, D10 should be the same as D12 (1N4148)
              R36 2.7K, Can you read any of the colors on R35? R35 could be 2Ω
              • sdinelli
                Sdinelli
                • Aug 2014
                • 152
                R35 & R36 are the burnt ones.
                Was unable to read anything, the whole outer was burnt away
                How did you know that was D12's part number???
                • lotas
                  • Jan 2016
                  • 4611
                  • Russia
                  Here is a better photo, you can see. https://4chanarchives.com/board/diy/thread/931526
                  https://i.imgur.com/pjvEuZ5.jpg
                  • R_J
                    • 9547
                    D12's number is clear in your picture. Check this thread, it may help https://www.badcaps.net/forum/showth...ghlight=cd-110
                    • sdinelli
                      Sdinelli
                      • Aug 2014
                      • 152
                      wow thanks alot
                      ill see what parts i can scavenge and let you know how it turns out.
                      • CapLeaker
                        Leaking Member
                        • 8178
                        Originally posted by ReeceyBurger123
                        I've had good luck cutting burnt resistors in half that are open and then doubling the resistance of whatever I can test ��
                        Interesting idea… I got to try that! Thanks buddy!
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          It's worked for me lots of times haha, nothing I've done this too yet when I've been stuck has blown up major
                          • sdinelli
                            Sdinelli
                            • Aug 2014
                            • 152
                            how much amp fuse should i put in there?
                            i pulled out a 3A but i may have replaced it wrong the first time.
                            i have 3A and 15A in stock.
                            I was able to scavenge the 10ohm resister and teh zener diode.
                            i have the extra mosfets left over from last time. (in case i failed the first)
                            Just need to get the burnt resistors. May have to just order them.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              3A should do the trick.
                              Just make sure to use a series incandescent bulb in series with the PSU after you have replaced all of the parts and are ready to test it. Like this:
                              https://www.badcaps.net/forum/showpo...4&postcount=70
                              This should prevent you from blowing fuses and other parts again if the PSU still has issues.
                              Just one note about the above circuit: you cannot test the PSU with any load. In some cases, a 40-60W bulb may be inadequate to make the PSU start up. In such cases, you might have to go up to 100W... which can be hard find nowadays, due to incandescent bulbs being phased out. But 40W appliance / "decorative" incandescent bulbs can still be found in most hardware stores. If that's all you have, you can parallel 2-3 40W bulbs (which would be equivalent to a 80W or 120W bulb.)
                              • sdinelli
                                Sdinelli
                                • Aug 2014
                                • 152
                                i just wanted to say thank you for all your help.
                                i ended up replacing the two Fets, two burnt up resistors, a diode, capacitor and
                                IT WORKS!
                                I first tested with the light bulb contraption. got nervous because it was making a whine. but bulb didnt light up. so i measured voltage and was getting all of them so i connected it normally and success... been working all week.
                                THANKS!
                                  • Jul 2011
                                  • 6040
                                  Good work
                                  One more item that does not end up in a landfill
                                    • Jul 2011
                                    • 6040
                                    IT WORKS!
                                    THANKS!
                                    Sometimes you have to use a higher wattage light bulb for it work more like it would plugged directly into the wall
                                    Here is a post where I used the light bulb contraption ( instead of the fuse ) to troubleshoot a machine that was blowing fuses starting on post #9
                                    https://www.badcaps.net/forum/showth...ht=sam_sam_sam
                                    I use this light bulb contraption when I have a device that has blown fuse in it so I can see how bright the light bulb is so I know just how much of a possible short it might have
                                    • proxneo
                                      Recapping Sony ICF-SW55 - verifying cap values
                                      by proxneo
                                      Dear reader
                                      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                      At the moment, I have selected replacements based on the following list of values:
                                      3 x 470uF 10VDC
                                      3 x 4.7uF 35VDC
                                      4 x 47uF 50VDC
                                      8 x 22uF 6.3 VDC
                                      1 x 220uF 6.3VDC
                                      5 x 100uF 6.3VDC
                                      Which...
                                      06-21-2023, 12:38 AM
                                    • Prolog
                                      RTX 3080 FE Identifying capacitor
                                      by Prolog
                                      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                      I hope these photos make it clear which component I am referring to:
                                      (yes, the soldering is a bit botched from removing the blown one, I know)
                                      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                      12-01-2024, 08:27 PM
                                    • rashidjafar
                                      Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                                      by rashidjafar
                                      I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                                      Values for :-
                                      PC43 : Capacitor [3x1.5mm]
                                      PL7 : Inductor [2x1mm]
                                      PC39 : Capacitor [1x0.5mm]
                                      Any ideas would be appreciated.
                                      I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                                      08-07-2025, 05:10 PM
                                    • Kobok
                                      Different (lower) resistor values on PCB?
                                      by Kobok
                                      Dear Alls,
                                      For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                                      09-19-2022, 07:30 AM
                                    • dicky96
                                      Zotac GTX 260 burnt component - can anyone identify?
                                      by dicky96
                                      Hi guys
                                      This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                                      This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                                      Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                                      I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                                      The good phase...
                                      12-01-2021, 01:02 PM
