9v super basic wall wart issue
  • jayjr1105
    • 281
    This is one of those worthless and time wasting repairs but it's bugging me and I want to figure it out. Simple 9v 1a SMPS wall wart and it's bouncing between 8.2 and 9.4v without load. I've pulled out every single cap and all tested fine. I've replaced the opto and same exact issue. All diodes are testing fine. I'm not sure if the IC can cause this or if the IC had issues you wouldn't get anything at all on output.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8707
    Re: 9v super basic wall wart issue
    power supplies tend to have minimum load, does it surge with some load?
    • jayjr1105
      • 281
      I'll check later tonight
      Ryzen 3600x
      FX-8802 Iron
      • R_J
        • 9623
        Replace that small electrolytic C3
        • CapLeaker
          Leaking Member
          • 8351
          Look if C3 has something to with the feedback and change it.
          • R_J
            • 9623
            I wonder if C3 might be the issue
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              The 431 may be hunting.
              Try a 150-1k resistor across the IR LED in the opto.
              Points are marked in attached image.
              Change the small cap on pri side to 22u/50v or 47u/50v.
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • jayjr1105
                • 281
                I pulled all caps one by one and they all checked out. I can replace it anyway but don't know what good it will do
                Ryzen 3600x
                FX-8802 Iron
                • jayjr1105
                  • 281
                  9.21v stable. How do I know which one fixed it? Replacing C3 or adding a 330ohm resistor to the opto?
                  Ok, pulled the resistor off and it's still good. Pulled C3 which was a 10uf 50v cap and replaced with a Panasonic FC 47uf 50v.
                  Ryzen 3600x
                  FX-8802 Iron
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    Soldering heat from R&R'ing C3 may have temporarily "woken" it up.
                    The 431 seems to need a minimum load; when an unbypassed opto LED is the sole source of current to the 431, the latter can hunt.
                    Leading to voltage "bounce" at no load.
                    Perhaps it was C3.
                    With the original C3 in place, leave it out in the cold a while- it'll probably act up afterwards= cap(s) is/were suspect.
                    In similar SMPS wall warts, I've used 22-47u/50v caps, PW/HE/FC, for C3.
                    If a new C3 keeps it stable, even cold, you can probably leave the opto LED unbypassed.
                    EOL it...
                    • jayjr1105
                      • 281
                      Perhaps it was C3.
                      The 431 is the small voltage reference SOT23 part?
                      Ryzen 3600x
                      FX-8802 Iron
                      • jayjr1105
                        • 281
                        BTW, got home and still tested very stable around 9.2v.
                        Ryzen 3600x
                        FX-8802 Iron
                        • CapLeaker
                          Leaking Member
                          • 8351
                          glad you got it fixed! I ran into a similar issue before on a different power supply where it only supplied half of the voltage.
                          • MORETTIGIAN
                            Capacitor detached from PCB – RTX 2070 Super Founders Edition
                            by MORETTIGIAN
                            Title:
                            Description:
                            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                            I did not notice it detaching, so I am unsure of its original location on the PCB.
                            Procedure performed:
                            - Removed backplate
                            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                            - Reapplied thermal compound
                            - Reassembled card
                            Observed behavior after reassembly:
                            - GPU powers on and operates normally under...
                            09-18-2025, 12:14 PM
                          • hayezy09
                            Asus rog ally, no charge issue relating to the ite super io chip
                            by hayezy09
                            Hows it going just wandering if anyone has had any luck repairing rog ally’s no charge issue relating to the ite super io chip, swapped out two of these chips i bought off two different sellers on aliexpress and still no luck, both devices power on from battery but will not charge, cant find any kind of definitive answer online on wether they need to be programmed or not, either they do need to be programmed or the chips i have are no good was just wandering about anyone else’s experiences with repairing this paticular problem, cheers.
                            10-09-2025, 12:12 PM
                          • ugamazing
                            820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                            by ugamazing
                            So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                            1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                            2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                            04-10-2024, 08:06 AM
                          • Nikan.e
                            Alienware 13 R3 repair - power issue or bad super-IO?
                            by Nikan.e
                            Greetings and Salutations!
                            I have BAP00 board in front of me, which does not want to turn on. Nothing except for the AC power is connected.
                            +3VLP - present
                            RTC power - present // no battery connected
                            * +3VALW - present
                            * +5VALW - present
                            * +LAN_IO - 0.00V
                            * +3V_PCH - 0.05V
                            * +1VALW - 0.00V
                            * +1V_PCH_PRIM - 0.00V // same rail as +1VALW
                            Note : ON* means that this power plane is ON only with AC power available, otherwise it is OFF
                            +1VALW - 47Ohms
                            +3V_PCH - MOhm range
                            +LAN_IO - 100KOhm...
                            11-07-2024, 03:51 PM
                          • rounin
                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                            by rounin
                            🛠 Original Issue
                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                            04-19-2025, 01:18 AM
