Sony XBR 55 x800e
  • thekidtmac73
    • Jan 2022
    • 7
    Sony XBR 55 x800e
    I have 3.3 volt standby on the flowers Provo power supply board until I plug it into the main board but then it fluctuates the point .3 to.5 please help
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Sony XBR 55 x800e
    What's the resistance to ground on the 3.3v pin on the mainboard?
    Decent photos always help. I suspect a shorted component, possibly a capacitor.
    • R_J
      • 9551
      If you have about an 8Ω ~ 10Ω 1watt resistor, disconnect the main board and connect it between the power supply 3.3vstby and ground and see if the 3.3v stays up.
      This should tell you if the power supply is providing enough current or if the main board is loading it down.
      • thekidtmac73
        • Jan 2022
        • 7
        This I what I have video attached
        • thekidtmac73
          • Jan 2022
          • 7
          I disconnected the main board from the power board and when I test the rating on a standby voltage it is still the same as when it is plugged in
          • thekidtmac73
            • Jan 2022
            • 7
            This with main board connected
            • thekidtmac73
              • Jan 2022
              • 7
              This is with that main board no connected
              • CapLeaker
                Leaking Member
                • 8195
                I’d say first off we need straight shot high resolution pictures of your PSU and the main board. Then do that what already has been asked.
                • thekidtmac73
                  • Jan 2022
                  • 7
                  Where am I looking for the 8Ω ~ 10Ω 1watt resistor? I'm new at this.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • delpiero3
                    Sony Vaio SVS MBX-261 board failure
                    by delpiero3
                    Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                    Nevertheless, let's say, i don't come as a total beginner.
                    I have this old laptop, which suit perfectly my needs, with the...
                    10-29-2024, 06:16 AM
