K.i.s.s.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: K.i.s.s.
    Originally posted by c_hegge
    Disagree. I see lots of PSUs with failed teapo. .
    Ok. How old were these psu's? I only really see failed teapo in psu's about 6-8 years old, mostly hipros and lower end FSP.
    • c_hegge
      • Sep 2009
      • 5219
      Re: K.i.s.s.
      3 years roughly, but a good cap like a rubycon will last much longer than that. I have seen ancient psu's where none of the caps had failed.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Re: K.i.s.s.
        Interesting thread...
        How would you rate the following capacitors from better to worse?
        Teapo, Ost, Jun Fu, Capxon, G-Luxon, Choyo
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Re: K.i.s.s.
          Best to worst:
          Teapo, G-luxon (teapo rebranded), Ost, Capxon, G-luxon, Jun Fu (rebranded Fuhjiyyu?), Choyo
          G-luxon, it all depends. G-luxon is now owned by teapo, and new ones are simply rebranded teapo. You can tell these because they will have the teapo vent.
          • Scenic
            o.O
            • Sep 2007
            • 2642
            Re: K.i.s.s.
            so Teapo = Yageo = G-Luxon now?! o.O
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Re: K.i.s.s.
              Yes
              • c_hegge
                • Sep 2009
                • 5219
                Re: K.i.s.s.
                I would have said OST and teapo are tied for the best, Capxon in the middle and the others tied for worst.
                • mur
                  • 21
                  #28
                  Re: K.i.s.s.
                  Where would you put Jamicon between those?
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Re: K.i.s.s.
                    With the bottom ones. I recently opened an AOpen branded PSU made by FSP and the Jamicons were bloated but the fuhjyyu were not. Any brand that is outlasted by fuhjyyu is very very bad IMHO.
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      Re: K.i.s.s.
                      funny thing that i noticed is that the capxon series which fail a lot seem to be the same ones where samxon fails.
                      Capxon GL -> Samxon GL for example..
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5038
                        • New Zealand
                        #31
                        Re: K.i.s.s.
                        But did you measure ESR? They could still have gone bad without showing it...
                        -David VanHorn
                          master hoarder
                          • May 2008
                          • 12175
                          #32
                          Re: K.i.s.s.
                          You also need to take into account the overall design of the PSU and where the caps were sitting. For example, if those Fuhjyyus that c_hegge was talking about were sitting near the vents while the Jamicons were next to a hot dummy-load resistor, then it would make sense why they failed faster. (This is why you see Delta-made PSUs with L-Tec caps last so long - because they are well-designed). And then there's the question which rail was loaded the most and which caps handled that particular rail.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Re: K.i.s.s.
                            The Fuhjyyu and jamicons were all near each other (ie. very little if any temperature difference), although I didn't think of the other possibilities at the time like the fuhjyyu drying up without bulging or the load on the rails. In any case, though, I still believe the jamicon to be junk, since they would have lasted longer than they did if they were half decent.
                            • sirpsychol
                              Antec Earthwatts EA-380 smd element type/value
                              by sirpsychol
                              While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                              09-03-2023, 07:58 PM
                            • Crystaleyes
                              TV standby to power_on circuitry theory and operation
                              by Crystaleyes
                              Although it is far from my main field of interest, people here keep asking me to fix their flat screen TV's.
                              So far, the problems have generally been on the PSU, the T-Con or the backlights, all of which have been relatively straightforward.
                              As far as the main board, or SSB, is concerned, the only real issues I've encountered have been bad caps and fucked BGA soldering.
                              It has also become clear that 'stuck in standby' is a common problem, and something which I no experience with yet could waste lots of time on without an understanding of how the 3v3 is sent to trigger...
                              07-11-2023, 08:34 AM
                            • ajdrenter
                              Picking caps for Antec SU-380
                              by ajdrenter
                              In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                              https://www.badcaps.net/forum/showthread.php?t=14159
                              It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                              05-13-2023, 10:40 AM
                            • CWEastwood
                              Antec Smart Power SL300S capacitor replacement.
                              by CWEastwood
                              I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                              The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                              I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                              Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                              03-25-2023, 12:18 PM
                            • s_henya
                              Antec VP-600P and NE550M dead
                              by s_henya
                              Got in these 2 nice PSUs, both died after power surge.
                              Both seems to be suffering from the same fault.
                              Blown main fuse
                              Shorted N mosfet 550v
                              VP-600P: 5R280CE short between GDS
                              NE550M: MDF18N50 short between GDS
                              In terns of board layout these seems pretty identical.
                              From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                              I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                              Is it worth to try and replace the mosfets? is there a chance that the...
                              12-03-2024, 10:00 PM
