K.i.s.s.
  • Elitist
    • Apr 2006
    • 159
    K.i.s.s.
    Do not believe all you read on the InterWeb! Got an expensive Antec PSU here. State of the art design, stuffed out with chokes, varistors, all the things demanded in the textbooks on theory. They've fitted Fuji-haha caps, which, guess what, have failed.
    DO NOT WASTE YOUR DOSH. El cheapo Chinese power units with all the design corners cut, weighing in at a few ounces (remember those?), no or minimal protective circuitry - mostly still running perfectly on PCs from Cx300 all the way up to 2Ghz 939 s. Yes, same 300W units on all of these machines; mostly you do not need 600W blockbusters unless you have exotic video cards and are a power gamer. Even CAD/CAM doesn't need oodles of power. When one of the budget supplies goes bad, quick, cheap and easy to swap out the caps, plus maybe a fuse, rarely a varistor.
    There's theory, then there's reality.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: K.i.s.s.
    Then probably not state of the art. A lot of advancements in psu technology with the efficiency craze, if this is old enough to be a CWT built antec then it is far from state of the art. More of a beefed up AT psu with a 5vsb and 3.3v.
    • c_hegge
      • Sep 2009
      • 5219
      Re: K.i.s.s.
      I no longer trust Antec (other than the high end series like signature). I've seen that many with bad caps not that it's not funny.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4963
        • New Zealand
        Re: K.i.s.s.
        I never liked Antec despite so many people claiming they are the best ever made
        I don't like anyone who uses Fuhjyyu, end of story.
        I read on the internet where a few years ago people started complaining about the abysmal capacitors and Antec started getting better and I think even offering repairs but now it looks like they've gone back again.
        Friend of mine bought an Antec Basiq recently, I took a look through the ventilation holes - Fuhjyyu! And this is not a well-cooled PSU either, it's got one 80mm fan and not many air vents.
        I know Basiq line is low end but they could have gone with something better. Samxon would have been cheap too but I'm sure far better.
        In saying that, I think that the PSUs themselves are OK, just let down by the capacitors, If you were to replace all the capacitors you'd have a pretty decent PSU in most cases.
        -David VanHorn
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Re: K.i.s.s.
          even Teapos would be high-end compared to the fuhjyuhyhjhjyjhzgzifgkfaödf crap antec keeps using..
          i'm quite happy with my NeoPower/NeoHE 430 though.. reason being: its a seasonic OEM
          • Agent24
            I see dead caps
            • Oct 2007
            • 4963
            • New Zealand
            Re: K.i.s.s.
            I can't say I'd be happy with Teapo either. I think there may have been some Teapo in the Basiq as well though (can't really remember though and he wouldn't like me opening it due to warranty)
            What brand capacitors does your NeoPower use?
            -David VanHorn
            • Elitist
              • Apr 2006
              • 159
              Re: K.i.s.s.
              Twin-fan, SmartPower. With the difficult-to-access input-side varistors blown, this may not be worth repairing? Has there been front-side silicon damage, too? Even the exploding wire failed to explode. This is a bad design, badly executed. No excuses. Sinocheapware wins every time. Let's all stop using expensive boxes as bragging rights (rites?) and filling the pockets of charlatans. An wholesale shift to Linux might also help on the hardware side, although not necessarily with PSUs.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4963
                • New Zealand
                Re: K.i.s.s.
                You can say what you like about how good cheap PSUs are but I can tell you they are still bad.
                I've got a system here, Sempron 2800+ Socket 754 - It's had a Colorsit and some other no-name brand PSU, both started causing lockups and now I've finally replaced it with a Corsair CX400 and guess what? No more lockups.
                These PSUs both using ultra cheap capacitors (the ones with LOW ESR written on them) - If you have to say your capacitor is a Low ESR then it isn't. Or if it is, it won't be for very long
                I've also got 2 machines running Enermax, I recommended Enermax to all my friends, guess what? They have no problems.
                On the other hand, I have loads of crappy Hyena (Deer) PSU which all run great in Pentium 3 rigs but all have bulging capacitors.
                Only one I've actually seen fail was one in a Pentium 4 machine where the capacitors were so bad the computer wouldn't complete POST. Put in a new PSU and guess what? Worked fine.
                -David VanHorn
                • Elitist
                  • Apr 2006
                  • 159
                  Re: K.i.s.s.
                  Yes, they are not all tinged with gold. Deer and Color-anything are definitely ones to avoid, although Deer units with the critical caps (I'm sure readers of this column know exactly which ones!) replaced seem to run satisfactorily in perpetuity. Suntek (nominally US), Seventeam (nom. Taiwan) and SCL (nom. UK) have been especially robust in my armoury. Are these actually made in China? Probably, yes. The smoking gun doesn't point at the PRC, they just do the biding of the greedy Westerners who should know better!
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4963
                    • New Zealand
                    Re: K.i.s.s.
                    Yeah it's pretty stupid, everyone wants the cheapest thing but they expect it to never break as well... but then when someone makes something decent they complain that it costs too much
                    -David VanHorn
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Re: K.i.s.s.
                      Quite interesting power supply i have here. It's a R-senda EPSpower-660, a 80plus sample so yes it should be safe to use to it's rated wattage, but it has Fuhjiyyu on the secondary with a twist.
                      BTW, if you buy a brand new antec, you will not get Fuhjiyyu's. Seasonic and delta do not use Fuhjiyyu/asia-x. Only CWT DID. CWT now uses samxon and UCC.
                      The worst you will get in a Antec now is OST in a seasonic made.
                      • seanc
                        • Nov 2008
                        • 1319
                        Re: K.i.s.s.
                        Aye, the 2006/2007 era Antec Earthwatts I'm repairing are Seasonic built with OST & Teapo. All work fine after a recap.
                        My Seasonic S12 of the same era uses exactly the same PCB, just with better caps, even a polymer!
                        Newer Earthwatts seem to be using (at least one) UCC, as you mentioned.
                        The Basiq models I've looked in (through the vents) seemed to have Capxon, could be wrong though.
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          Re: K.i.s.s.
                          Hitachi grain silo on the primary side, OSTs on the secondary side. with lots of airflow though.
                          which isnt really a problem as those seasonic built PSUs usually have very good airflow.
                          my Neopower/NeoHE 430 is in my main computer since feb. 2009 now (bought it used, resoldered some not-so-good-looking joints, fan oiled). no probs at all so far.
                          edit: and never opened up again since then.. it's about time.. dusty as hell.. lol
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Re: K.i.s.s.
                            I see new CWT-built PSUs with cheapo Teapo in them. The ThermalTake Toughpower series claim to have Japanese caps, but on opening them up, they are full of teapo.
                            As for the seasonic-OEM antecs, the single 80mm temp controlled fan doesn't cool them well enough IMHO. I've had a couple of them with bad caps. The PC that is powering this post has a re-capped SU-380.
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              Re: K.i.s.s.
                              Teapo is actually pretty good in psu's. PC P&C has been using them for quite a while, so has many server grade OEM's like Etasis, CWT, Enhance, AcBel, Andyson, Sirtec, ATNG, FSP/sparkle, etc...
                              • Scenic
                                o.O
                                • Sep 2007
                                • 2642
                                Re: K.i.s.s.
                                the Antec TruePower 550EPS i've got here to fix up had fuhjyyuhhju's everywhere, except for the secondary side on the 12V rail.
                                2x 3300uF 16V Teapo SC there.
                                guess which 2 caps were the only ones that were *not* bulging/leaking.. ?
                                i'll replace them anyways.. not bulging but probably baked dry. if that's not the case, they've most likely degraded a lot (being 6years old)
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Re: K.i.s.s.
                                  Disagree. I see lots of PSUs with failed teapo. If I get my hands on a PSU with teapo, I always re-cap it if I intend to use/sell it. They are definately better than Fuhjyyu and G-Luxon, though.
                                  • Elitist
                                    • Apr 2006
                                    • 159
                                    Re: K.i.s.s.
                                    OST - nothing but trouble. I always replace them. As bad as GLuxon and Fujihaha.
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      Re: K.i.s.s.
                                      I concur. Teapo PSUs will give you only a few years, if you're lucky. And I prefer OST in PSUs to Teapo.
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        Re: K.i.s.s.
                                        OST = Teapo for quality. I find both about as reliable as each other.
                                        • sirpsychol
                                          Antec Earthwatts EA-380 smd element type/value
                                          by sirpsychol
                                          While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                          09-03-2023, 07:58 PM
                                        • Crystaleyes
                                          TV standby to power_on circuitry theory and operation
                                          by Crystaleyes
                                          Although it is far from my main field of interest, people here keep asking me to fix their flat screen TV's.
                                          So far, the problems have generally been on the PSU, the T-Con or the backlights, all of which have been relatively straightforward.
                                          As far as the main board, or SSB, is concerned, the only real issues I've encountered have been bad caps and fucked BGA soldering.
                                          It has also become clear that 'stuck in standby' is a common problem, and something which I no experience with yet could waste lots of time on without an understanding of how the 3v3 is sent to trigger...
                                          07-11-2023, 08:34 AM
                                        • ajdrenter
                                          Picking caps for Antec SU-380
                                          by ajdrenter
                                          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                          https://www.badcaps.net/forum/showthread.php?t=14159
                                          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                          05-13-2023, 10:40 AM
                                        • CWEastwood
                                          Antec Smart Power SL300S capacitor replacement.
                                          by CWEastwood
                                          I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                          The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                          I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                          Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                          03-25-2023, 12:18 PM
                                        • s_henya
                                          Antec VP-600P and NE550M dead
                                          by s_henya
                                          Got in these 2 nice PSUs, both died after power surge.
                                          Both seems to be suffering from the same fault.
                                          Blown main fuse
                                          Shorted N mosfet 550v
                                          VP-600P: 5R280CE short between GDS
                                          NE550M: MDF18N50 short between GDS
                                          In terns of board layout these seems pretty identical.
                                          From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                                          I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                                          Is it worth to try and replace the mosfets? is there a chance that the...
                                          12-03-2024, 10:00 PM
