Dell DPS 1200MB A pinout
  • fpsousa
    • Dec 2015
    • 29
    • Portugal
    Hello
    I have this power source to repair, but don´t know the pinout to get it ON.
    Somebody can help?
    Thank you.
    master hoarder
    • May 2008
    • 12164
    • Bulgaria
    Re: Dell DPS 1200MB A pinout
    Check the voltage on the pins on the left side relative to ground.
    One of them should have about 12V with the PSU plugged in. This is likely the 12V Standby (+12Vsb) rail.
    And if this PSU uses active-low line for the PS-ON signal, then another of those small pins should show about 3-5V on it. If so, connect this pin to ground (via 100-1000 Ohm resistor, just to be safe) and the PSU should turn On.
    But since I don't have this PSU and I am not 100% familiar with it, I suggest making a diagram to show which pin shows what voltage when the PSU is plugged into the wall. Then post the diagram here.
    On that note, please use the forum's built-in image attachment function, so images don't get lost over time.
    • fpsousa
      • Dec 2015
      • 29
      • Portugal
      Thank you
      I send 2 fotos position down and the voltages on the two sides.
      • fpsousa
        • Dec 2015
        • 29
        • Portugal
        another photo side down.
        • lotas
          • Jan 2016
          • 4466
          • Russia
          Photo from the Internet.
          • PeteS in CA
            • Aug 2005
            • 3578
            • USA, Unsure of Planet
            That's a Delta Products CRPS type power supply (CRPS = Common Redundant Power Supply). Here is a pin-out chart:
            Pins B24 and B25 are "NC" on a Delta webpage print-out I have. Pins B19 and B20 are SMB address pins that use 3.3V logic levels. Grounding pin A21 should enable the power supply.
            PeteS in CA
            • fpsousa
              • Dec 2015
              • 29
              • Portugal
              Thank you for the help.
              I´ve put a resistor of 220 Ohms betwin these 3 pins and the psu goes ON.
              • sergiosergio
                • Nov 2022
                • spain
                Hello everyone! First of all I would like to thank you for the useful information that you are posting regarding the DPS 1200MB.
                I have the same model and I managed to start with an output of 12V. I need to increase it to 14V and I am asking for your help if any one can help me with pictures or an advice.
                Thank you in advance!
                • newgenrepair
                  • Nov 2022
                  Quick question on this topic, is anybody ever tried to run these 110V instead 220?
                  I have few of those and would like to use them with my Lipo Chargers, they output significant current which is perfect for high output chargers.
                  Only issue is they only works 220v, I couldn't find the schematics to further investigate this though. Thank you.
                  • PeteS in CA
                    • Aug 2005
                    • 3578
                    The P/S is rated for 200-277 VAC. Since modern server-grade power supplies are typically controlled by microcontrollers, you might or might not get 12VSB, and the main 12V may be kept disabled due to the low-line condition.
                    PeteS in CA
