Corsair TX-750 problem with finding component
  • johnis82
    • Apr 2016
    • 22
    • Greece
    Hello guys i have opened a dead Corsair psu and i found a burned ic with 7 pins. Because i can't find any schematics for this PSU ,I said to ask a question here. Thanks in advanced!
  • victorcas
    • Oct 2021
    • 12
    • España
    Re: Corsair TX-750 problem with finding component
    I have a Corsair CS750M and it uses a TNY278pn. Im not sure if its the same. Maybe you can check the datasheet and see if it fits.
    Usually, when those components explode, it means there is something in short...
    On the side of the big capacitor there is a resistor that seems to be broken. Did you checked that?
    • johnis82
      • Apr 2016
      • 22
      • Greece
      First of all thanks for the fast reply, i appreciate that! No i did not see that but i needed to find first the ic and then watch around the board for other component defects. Hmm you mean the little one next to the rectifier capacitor?(big one) do you know the value for this too?
      • johnis82
        • Apr 2016
        • 22
        • Greece
        victorcas Do you have a schematic diagram for your PSU?
        • R_J
          • 9633
          The top of the ic was likely still in the case somewhere, did you check? Check the trace side of the board, if it is a TNY278pn, pins 5~8 (source) are connected together.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            IIRC, I have a later TX (TX850M) with much better cap choices.
            IIRC, that one doesn't look better than a later CX, cap-wise.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • victorcas
              • Oct 2021
              • 12
              • España
              No, I have no idea... It seems to be a 1/2W resistor with a 1% tolerance. It may be used for current measurement. The value is impossible to read. It looks something like "green - brown - ? - ? - brown". You can check it with a multimeter to see if it is actually broken.
              No. It is almost impossible to find a schematic of a modern power supply, especially the Corsair ones. I think the only way to find out the broken components is to compare it to another Corsair PSU.
              That power supply seems to have a single layer PCB, so you can follow the traces and try to draw a schematic. With that, you might be able to find compatible components.
              • johnis82
                • Apr 2016
                • 22
                • Greece
                Thanks for the info guys i'll open it again and see if i can find anything.
                Thanks again for your time
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • david04pt
                  Problem finding chip "AWVAAH" on hp 15-cs003 | Board: DA0G7BMB6D0
                  by david04pt
                  Hello guys, I'm trying to fix this laptop hp 15-cs003, which when i removed the battery it suddenly stoped turning on and even the led, which indicates that's charging isn't turning on.
                  I am trying to fix it, and i found a problem with this chip "AWVAAH", which I can't find on the internet or AliExpress, anything...
                  I found some chips that look like that, but nothing equal.
                  Can someone please help me find this "AWVAAH", i will show a picture of him.
                  Thanks a lot for the help!...
                  01-30-2024, 04:02 PM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • loko
                  Tesla 13.7 body sculpt repair problem, need help with finding the thyristor marking.
                  by loko
                  Hello everyone.
                  I have a device that is used to shape the human body muscels and burns fat. Works on the principle of electromagnetic impulses. One thyristor in side is shorted which has only this unknown mark on it ( QC230301 ). I can't find any information about it anywhere on the Internet. I tried to replace that thyristor with one of 1.6kv 800A and after 5min. of work he has burned out again, which means that he is probably weak. There is no schematic diagram on the internet, but that didn't suprise me because all the transistors and chips that are on the boards have their markings...
                  10-27-2024, 11:31 AM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
