Problem finding chip "AWVAAH" on hp 15-cs003 | Board: DA0G7BMB6D0
  • david04pt
    • Jun 2018
    • 4
    • portugal
    Hello guys, I'm trying to fix this laptop hp 15-cs003, which when i removed the battery it suddenly stoped turning on and even the led, which indicates that's charging isn't turning on.
    I am trying to fix it, and i found a problem with this chip "AWVAAH", which I can't find on the internet or AliExpress, anything...
    I found some chips that look like that, but nothing equal.
    Can someone please help me find this "AWVAAH", i will show a picture of him.
    Thanks a lot for the help!
    • 21620
    Here it is -> https://www.badcaps.net/forum/troubl...12#post1538202
    • david04pt
      • Jun 2018
      • 4
      • portugal
      Originally posted by SMDFlea
      Thanks for the answer!
      I have found this "AWV5T6" it looks like what im trying to find which is "AWVAAH". You think they are the same / it works is i replace with that?
        SMDFlea commented
        Editing a comment
        The last 3 digits are a date code it could be anything AWV*** .If the part is SY8286BRAC it is the right one
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • pengamat_hebat
      Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
      by pengamat_hebat
      I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
      Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
      However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
      I also tried applying 3.3V to pin 3, but it still didn't work.
      I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
      03-25-2025, 04:13 AM
    • gusto
      How do I remove the chip from the board
      by gusto
      I am new to hot air soldering. I need to remove one chip from the board. I have a hot air solder and I set the temperature to 350°C. I slowly started heating the chip, but the solder didn't melt. I heated it for about 5 minutes, but the solder still wouldn't melt. I increased the temperature to 450˚C and still nothing. After a while, the board started to change color, but the solder still didn't melt.
      Fortunately, I'm testing it on old network switches to see how it works.
      What am I doing wrong?
      I've seen a lot of videos on youtube and everyone got the solder melted and the...
      10-08-2024, 10:55 AM
    • Rayblaster
      HP RP7 RP7800 from 2012/2013 worst fault - has "character"
      by Rayblaster
      Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
      I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
      12-30-2024, 06:28 PM
