Burning smell from PSU but no visible problems!
  • Tom41
    • Oct 2005
    • 336
    • England
    This evening I went into my computer room to find a strong 'burning plastic' smell. After shutting down my secondary PC (which I'd left on to share the Internet using the Nintendo Wifi USB connector), I had a sniff around and found what I believe to be the source of the smell, the PSU on my secondary PC.
    I opened up the PC to check for any visible signs of damage. There is nothing on the motherboard or any other device that looks burnt, and all the capacitors (Rubycon!) are nice and flat-topped. All vents on the PC and PSU were clear, not blocked by anything and relatively free of dust.
    I also opened up the PSU. Again, there's nothing visibly wrong - no charring, burning or melting was visible. The capacitors are all Samxon, and show no signs of bulging.
    Then again, it did only have one input capacitor and wimpy heatsinks, but this PSU has served me well for a long time. The PC is not showing any bad cap symptoms yet (random reboots, POST errors and such), but I dare not keep it switched on for extended periods of time any more.
    One thing I did notice - when I opened up the PSU, a tiny metal fragment fell out, that looked rather like an end of component lead with a bit of solder on the end. Could a component have come loose and started arcing? Surely there would be some physical evidence if that were the case, though...
    This particular PC gets much less use than the other one in the computer room, so it's also possible that dust settled inside the PSU and made the smell when the heatsinks got hot. What do you guys think?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Burning smell from PSU but no visible problems!
    Remove the pcb from the psu case and check for bad solder joints. Clean all the dust out.
    Samxon...single input cap, sounds like a APFC CWT unit (if the samxon is from the factory)
      • 31011
      use your nose to find the source of burning.
      • Tom41
        • Oct 2005
        • 336
        • England
        Today I finally found the source of the burning smell - inside the PSU, as I feared. The PSU is a Jean Tech, 350W.
        Upon closer inspection, I found that one of the coils inside felt very loose to the touch, and the glue between it and the input capacitor had broken. I'm guessing the coil developed a 'hot spot', melting the glue and causing it to move out of place, touching another heat sink. The smell was definitely coming from the vicinity of the coil.
        I've attached two photos of the coil and capacitor - what do you guys think? Perhaps the combined heat from the hot spot and the heat sink caused the 'paper' on the coil to start making a smell?
        • Agent24
          I see dead caps
          • Oct 2007
          • 4951
          • New Zealand
          Shorted coil or something else short causing high current through it?
          -David VanHorn
          • smalltownguy
            • 127
            • US
            What's the name of that coil? I've got another power supply with the same symptoms. There's charring on that coil. I'll replace it, if I can find a cheap replacement.
            • Stefan Payne
              • 1267
              or just a faulty coil...
              • howardc64
                LG 65UQ8000AUB no backlight burning smell
                by howardc64
                Only 3 years old. Owner said backlight went out and burning smell. Didn't bother plugging in to check if had power LED. Just opened the TV rear and found shorted bridge rectifier diode on the backlight circuit on the PSU. SF26G (400V 2A super fast recovery rectifier link ) diode replace with SF26 (what I had on hand) Google AI said G = Green Components.
                Burn looked pretty bad on the board but just was blackened carbon coating material. Scraped and cleaned off quite well and clean solder pad for the new diode.
                06-07-2025, 10:38 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • RetroComputingGrotto
                IBM LTO 7 Tape Drive - Dust Sensors??
                by RetroComputingGrotto
                I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                09-19-2024, 01:54 AM
              • jean luc ferre
                laptop hp g72 b52sf screen problems
                by jean luc ferre
                on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                06-07-2025, 03:27 PM
              • beetle1303
                Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                by beetle1303
                I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                01-13-2025, 08:49 PM
