EG465-VE PSU NTC thermistor
  • User
    • May 2007
    • 36
    NTC thermistor (Part #SCK0510) has cracked near one of the leads.
    Will it cause any problems? If so, what part would you recommend? Any advice would be much appreciated.
  • Toasty
    • Jul 2007
    • 4171
    Re: EG465-VE PSU NTC thermistor
    Should not be a problem. Thermal stress likely cracked the ceramic.
    Specs: NTC thermistor SCK-0510
    10 amp max
    20mm diameter
    5Ω at room temperature (25°C)
    Closest value in stock at Digikey is 570-1055-ND
    7Ω / 10A / 20mm
    veritas odium parit
    • User
      • May 2007
      • 36
      Thank you very much Toasty.
      • nmbb
        Can not find Model/Value of Thermistor.
        by nmbb
        Machine: Autoclave.
        Brand/Model: SANYO MLS-3780
        Manual: (Sorry search option not working on this PDF)
        Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
        06-02-2022, 05:55 PM
      • Use2bavolvo
        Magic chef oven - thermistor ref voltage issue
        by Use2bavolvo
        I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
        Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
        01-19-2023, 01:32 AM
      • jean luc ferre
        acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
        by jean luc ferre
        on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
        i tried the hard reset, cmos reset, changing the ram without results.
        in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
        The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
        but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
        11-22-2025, 03:54 PM
      • Quantum IC
        Sony KDL-40BX450 LCD. Thermistor gets too hot 10 seconds after turning on the TV
        by Quantum IC
        Hello every one,
        This TV came to me with the problem that it was totally dead.
        The problem was the two MOSFETs and a fuse resistor in the power supply.
        The original MOSFETs were KF7N50F and I repalced them with SLF65R700S2.
        The original fuse resistor was 0.1 Ohm 1/2W. I didn't find a similar fuse resistor and I replaced it with 0.1 Ohm 5W ceramic resistor.
        When I plug the TV the ST-BY LED turns on, when I press the power button on the TV, the ST-BY LED turns off and the TV doesn't turn on until the second time I press the power button is when the TV turns on,...
        01-14-2022, 12:06 AM
      • wasyl
        HH51R AN515-46 LA-M001P cracked MPS2207 MP2845A
        by wasyl
        As I mentioned i have cracked component found many on aliexpress MP2845A but MPS2216 someone know would it fit ?
        Link to aliexpress here...
        09-15-2025, 07:12 AM
