Dual output power supply 5 and 12 volts (no output)
 Re: Dual output power supply 5 and 12 volts (no output)
 i've 8,2 volts, the capacitor is 47uf-35 voltsComment
 If this is a td3843 the startup threshold is min 7.8v so the ic should be starting. It could be that it is not seeing the current sense pulse as I still don't know if that @#$% resistor is good or bad.
 You also need to check the resistor between pin6 (output) of the ic and the GATE of the mosfet, it could also be open.
 however the resistors have all been replaced, except the smallest ones that look good to the eyeLast edited by R_J; 01-31-2021, 04:40 PM.Comment
 which resistor are you talking about? in the previous message some strange symbols appeared however the ic is now a uc3843, the original was a Td3843Comment
 if you are talking about the resistor you were talking about, which must be connected between the cs of the ic and the source of the mosfet, help me to understand what it could be, I am available, if you want I can make a diagram, on the part of the circuit where there is are the welds to try to understand betterComment
 If you can't trace one resistor between the CS pin and the fet, I can't help you. Go back and see post #13. It is the one in the yellow square.if you are talking about the resistor you were talking about, which must be connected between the cs of the ic and the source of the mosfet, help me to understand what it could be, I am available, if you want I can make a diagram, on the part of the circuit where there is are the welds to try to understand betterLast edited by R_J; 01-31-2021, 05:05 PM.Comment
 ok tomorrow I will try to bring the component diagram on the part of the welds graphically so let's see if you can understand better, in the meantime thanksComment
 I tested the 1kohm and 22ohm resistors, the first seems dead, the second gives me a lower value about 16.9 ohmComment
 tried to replace the big capacitor and the Optocoupler nothing happensComment
 is there any way to test with the tester if voltage arrives at the input of the SM transformer?Comment
 What are you using as a "tester"? If it is a dvm or multimeter, just check the voltage with the ground on the negative lead of the 68µf/400v capacitor and then on the DRAIN of the mosfet.
 Also check and post the voltage on each pin of the ic
 Pin1=
 pin2=
 etc.Last edited by R_J; 02-01-2021, 10:51 AM.Comment
 the lan cable tester also acts as a multimeter, however can I use the yellow one? what voltage should i detect between the two points?Comment
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
 Assuming...7 Photos
			by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
			by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
 I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
 i know that in linear power supply the noise will be very low comparing to SMPS supply....
			by GLISITHi all,
- Loading...
