I have a laptop charger that is not working. I have tested it and the capacitor is storing high voltages around 600v. Both transistors are reading ok as well as all the diodes including the bridge diode. I replaced the C139 cap on output mosfet (it was cracked). All the resistors test ok in circuit. Am I missing something? D32 has a partial short reading in circuit but with one pad removed it has correct diode readings. The model of the board is adp-45fe bb.
Toshiba laptop charger power supply problems
Re: Toshiba laptop charger power supply problems
I am saying it is storing voltage, it is not going to the secondary or output side. I am measuring in AC so that might be why the number is high. Whatever the case, the cap stores voltage and when I use a lightbulb (serial bulb circuit) to test, it shows no short. However, if I don't discharge the cap with my meter and I touch the board cap area, I am shocked very badly.Comment
Remove all the white gunk from the board and post some nice clean photos.
Also, the most left cap ( c102? ) on the secondary side looks like a goner to me. Oh, and keep in mind that shocking yourself with a capacitor is not always the best way to check if it is ok or not.Comment
what multi-meter do you have ? i want one that does thatComment
I am thinking that this person is just seeing the capacitor slowly discharging
Because I also seem this myselfComment
Speaking of notebook chargers, is it safe to remove Y cap from my Notebook charger (Lenovo Ideapad)? there is only one. I think it's connected to neutral-ground to filter EMI
However I'm using a surge suppressor with 2 Y caps
The Y cap in question on the charger is ce472m STE Y2 4700pF (quite high right?)Comment
what could other benefit of a Y cap like 4700pF have on a Notebook charger?Comment
Those can be quite useful to discharge capacitors unless the capacitor is really large.
(If it is then the PTC's inside the meter will heat up and the resistance increases so they discharge much slower).
Some more details here: https://www.badcaps.net/forum/showth...076#post886076Last edited by Per Hansson; 01-04-2021, 02:28 PM."The one who says it cannot be done should never interrupt the one who is doing it."Comment
Electrolytic caps can only store a DC charge. Therefore, you should measure the DC voltage on that cap.
Not that I think this would reveal anything about the issue at this point.
Since the mains cap stays charged, I'm leaning more towards shorted output wires. Some PWM chips have crowbar protection and will latch down / stop all switching on primary until adapter is unplugged. So that's how the primary cap can stay charged for a long time.
But it's not recommended, though, for EMI/RFI suppression purposes, as you noted.
Also, it isn't necessarily connected Neutral to ground. If the Y-cap is near the switching transformer and connected between ground on the secondary and some part on the primary, that part is probably the negative (-) lead of the bulk cap.
Why not?
I've done it a few times too (a couple on purpose too.) It's not dangerous as long as the discharge path is only through parts on one hand. Now if you discharge such cap across your body, that would be a lot more painful and dangerous.
I think you meant to say Joules of energy instead of Amps?Comment
I doubt it. It appears to be United Chemicon brand. Unlikely to be bad, even in hot adapters like these.
I have two acer PSUs ( one for laptop, the other for a portable pc ).. both work fine, both are visually the same, have the same output V, but probably the PC one was a little bit more powerful ( if I remember correctly ).. anyway - the laptop one has a discharge resistor for the main cap, the other one - does not and keeps charge for hours even days after disconnected from the mains.Comment
It's not unsafe.
4700pf would cause more noise in the neutral or ground than no Y cap at all. Let's assume this cap is connected between line and ground... this is ultra unsafeComment
[Live]--------||-------[Ground]-------||--------[Neutral]
But in cheaper/smaller power adapters, it's also not uncommon to not have the two Y2 class caps mentioned above and instead have only one Y2 cap between negative (-) primary bus (the negative of the primary cap) and ground / secondary-side ground/return.
It's not if the cap is certified Y2 (or Y4) by safety agencies - meaning, it should go open-circuit in case it fails for whatever reason.Last edited by momaka; 01-09-2021, 09:20 PM.Comment
I've tested nearly everything on this and it is either a bad ic31 chip or the small smd resistors feeding into it. Or a bad ic131 on the output side, I don't have these ic or resistors in my junk collection so have abandoned the repair.Comment
by flat-eartherThe charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
Windows also shows ''Plugged in'' when charger is not connected.
This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
If I let battery run out and say it has 3% Windows will... -
Assuming...7 Photos -
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
Highly Integrated Narrow VDC Battery Charger for Notebook Computers
The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
Narrow VDC applications where the system power source is
either the battery pack or the regulated output of the charger.
This makes the max voltage to the system equal to the max
battery voltage instead of the max adapter voltage. Operating
at lower system voltage can improve...-
Channel: Common Parts Library - Datasheets
11-05-2024, 04:43 PM -
- Loading...
