Dang, what a piece of garbage!
I also have never quite seen a design like this before.
It's flyback, of course. And it appears to have feedback, as evident from the optocoupler. But generally designs like that use 2 transistors: a bigger one for driving the transformer and a smaller one for driving the bigger transistor. This one has only ONE transistor doing everything on the primary side. I initially even confused it with one of those single-transistor oscillator designs with no feedback. Then again, it appears there is no difference between this one and the one-transistor oscillator designs when it comes to regulation... or lack thereof, I mean.
If the output caps are good and that thing is still only outputting only 3V with ~100 mA load, then it surely belong to the scrap pile. I mean, with such poor loading, you'll be lucky if you can power more than a few LEDs with this thing. Heck, if you remove the case LEDs, you can probably almost double the adapter's output capacity.
I think the second "+5V" column is for the -5V output.
), "RLE2"
Then again, given the obviously bad fakery, it looks like they didn't try very hard to begin with.
. I was actually hoping to find which part had exactly burned up but no luck.
Case is quite crappy and made of rather cheap, thin plastic. Input filtering is… where?
Half of the computer problems is caused by bad contacts
