the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
    master hoarder
    • May 2008
    • 12170
    #1301
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by ruky con
    What are you planing on doing to that PSU? Scrap it? Burn it? Throw it off an cliff?
    While PSUs like this are not worth fixing to power a computer, as an Electronics Hobbyist, I find them to be a goldmine for various projects and repairs.
    I had a PSU back in my first computer that was even more gutless than the above PSU. When I scrapped it for parts (that is, I desoldered everything from it), I used the parts to fix many other PSUs and electronics. And I built almost my entire Senior Project in university with parts from that PSU. So it has been extremely useful and I am glad I had kept it over the years.
    Thus, if you are into learning or playing with electronics (be it as a hobby or a profession), you will likely find crap PSUs like the above very useful over time.
    That transformer is just... Wow!
    Yeah, my thoughts exactly.
    I'll be surprised if it holds past 100-150 Watts of load.
    • Behemot
      • 4845
      • CZ
      #1302
      Well, up to a point. First, parts from such craps are too weak for any decent units. Second, when you have dozens of such, it gets just too much to diassemble everything (and what to do with so many components? ).
      • kevin!
        recapping PCB.
        • Jul 2013
        • 195
        • España
        #1303
        I present the WORST PSU AT I've seen.
        In the photo that I measured the voltage, I almost electrocuted, because of the camera, I did not fix and I did not put the hand correctly with the tip of the multimeter. XD.
        Kids, do not do this at home xD.
        Going back to the subject, I find it VERY regrettable to leave a huge hole where the input of 220V DC ...
        In addition, the primary capacitors bloweds...
        Gaming pc:
        nVidia RTX 3080 TI, Corsair RM750I.
        Workshop PC:
        Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
        Server:
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          #1304
          200W from that? Not with those light weight heatsinks! And with just 220uF input capacitors the hold-up time would be horrible. The thing is over 20 years old, time to send it to the recycler.
          PeteS in CA
          • kevin!
            recapping PCB.
            • Jul 2013
            • 195
            • España
            #1305
            I also think the same.
            This source will probably pull it to the scrapping. But before throwing it I wanted to share photos.
            Gaming pc:
            Workshop PC:
            Server:
            • Behemot
              • 4845
              • CZ
              #1306
              Absolute most of AT configurations won't even ever reach 100 W so the unit does not need to actually provide 200 W. That's why they went away with these craps.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #1307
                that might be worth $0.02 in scrap.
                Originally posted by Dan81
                That might actually be worth a fix.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  #1308
                  it will burn itself soon enough.and the pc,house,whatever its in.
                  nice puddle of brown glue right across the unfused side of the ac input.
                  nice firestarter.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    #1309
                    Basiq 500 recap
                    This was a bitch. It used special-made 8x25 6.3 2200u caps, one wrapped in heatshrink was in particular bad area. I was not able to find any 8 diameter caps for the 6.3's so I had to use 10, and BARELY make it in there, but it was shorter, and I double shrink wrapped it cause it was in tight contact with a fet heatsink
                    Not user serviceable? surre
                    bad 3.3v
                    one of many
                    two extra
                    I love living right next to mouser (Mansfield TX, mouser HQ)
                    double heatshrinked panny
                    looks much better, don't you think?
                    passed
                    and in a C2D system working flawlessly, so there is no problem with handling a pull
                    • Stefan Payne
                      • 1267
                      8mm caps for Voltage Filtering are generally a bad idea...
                      And that FSP Plattform had its problems...
                      Though it looks like a newer revision...
                      • Behemot
                        • 4845
                        • CZ
                        #1311
                        Re: Basiq 500 recap
                        FSP, most likely GLN platform. I can see GLY, yep, pretty much the same.
                        Though my new 1200/16 and 2200/6.3 D8x20 mm Rubycons make any Panasonics just a dogs food. You should consider sourcing some too, I bet I'll be cheaper even with shipping than all those overpriced corporations.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          #1312
                          Re: Basiq 500 recap
                          sourcing?
                          • Behemot
                            • 4845
                            • CZ
                            #1313
                            http://www.thefreedictionary.com/sourcing
                            and than cap stock
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              #1314
                              so I should buy caps from Czechoslovakia?
                              • Behemot
                                • 4845
                                • CZ
                                #1315
                                Wut?
                                • PeteS in CA
                                  • Aug 2005
                                  • 3579
                                  #1316
                                  Show a little grace, Behe. Many Americans are still getting used to Yugoslavia having re-Balkanized.
                                  That reminds me ... would a Yugo now properly be called a Serbo? A Croato? A Bosno? (Please! Not from Herzegovina or Macedonia!)
                                  PeteS in CA
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    #1317
                                    I don't pay shipping for caps, I pay tax because they're bought in-state
                                    I also buy other stuff from them, I got a USB connector for a case, some other parts, a sata connector for a DVD drive controller board
                                    • PCTechnics
                                      • Sep 2013
                                      • 30
                                      • Argentina
                                      #1318
                                      Hi guys, not the worst but for a 2 month old PSU from Corsair model CX650M deserve to be here. Fail description: Short FR157 diode,completely short circuited CEF04N7G Mosfet, short Zener Diode marked ZD4A, 4 blown resistors and destroyed PCB trace. Currently trying to identify values of bown glass zener diode printed ZD4A.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #1319
                                        Yeah this platform is not that great, but if it's only two months old, it is under warranty, no?
                                        • PCTechnics
                                          • Sep 2013
                                          • 30
                                          • Argentina
                                          #1320
                                          Hi Behemot, was purchased in other country so no warranty here,is from a friend that gave it to me, im trying to fix it.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
