the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Behemot
    • 4845
    • CZ
    #541
    Re: the gutless, bloated, and fried power supply hall of shame
    That's quite normal on those FSP units. There are being various "flying resistor" mods used to get them away from capacitors to stop heating them.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Better than most Sun Pros...At least it has an input filter and PPFC (but no voltage selector) Caps are a mix of Metacon, JEE, Gold Link, and Tongjia. All the filtering caps on the 3.3V/5V/12V and 5VSB are bulged... 13009 switchers, 30A for 3.3V, 16A for 12V, 30A for 5V. My buddy had this thing powering an AMD Phenom and a GTS 250 for a few years, no wonder all the caps died. Surprised the whole thing didn't die but he must not have been doing much gaming. BTW the fan was like that when I cracked it open, completely dry in there! Anyone know what that weird wire next to the bridge rectifier is?
      • dmill89
        • Dec 2011
        • 2534
        Looks like a fuse holder, though I don't know why it would have one there.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Originally posted by dmill89
          Looks like a fuse holder.
          Wired to two pads marked 'sw'. A bodged voltage selector 'switch'?
          BTW, is that a real PFC choke?
          Muh-soggy-knee
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Hmmm, weird. Yes it is a real PFC choke. It's a Sun Pro so had to double check
            • Behemot
              • 4845
              • CZ
              #546
              Is it? Though I haven't found this model, most of newer Raidmax PSUs are made by Andyson.
                master hoarder
                • May 2008
                • 12175
                #547
                ^ It's a Sun Pro for sure. The Te Bao Metallic Plastic fan, Metacon input caps, and the "7700" text on the transformers give it away.
                • Behemot
                  • 4845
                  • CZ
                  #548
                  Man you could fly jet with them eyes of yours
                    master hoarder
                    • May 2008
                    • 12175
                    #549
                    I always wanted to do that!
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      This one was made in 2006. Pretty old! I do like the secondary heatsink, plenty big. Think it could handle more than a 20A rectifier for the 12V?
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        First one of these I have seen (similar one on JG though), manufactured January, 2003. I think it is upgradable, only thing I'm worried about is if I can upgrade the transformer or not, looks like a 28? I think it would be cool to get this thing up to 300W. It has two Fairchild 13007's (probably need to be upgraded) and a C150 transistor on the primary. 470uF CS caps and a 4A bridge rectifier, it needs some input filtering. The caps on the secondary are Fuhjyyu, JPCE-TUR and CS, each rail has 1 pi coil. 3.3V is 20A (ST), 5V is 30A (ST), 12V is 12A (Mospec) i was planning on replacing the 12V which a 20A part. There is a screw hole already on the secondary so I was going to add a fan controller too. Stock, it has a Globe Fan ball bearing fan.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          It is a 2SC3150 transistor. I think that transformer is tad small.
                          Muh-soggy-knee
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            The Premier that was in the JG bargain basement roundup was an ATNG. Can't tell if this one is too (though I am about 99% sure), or is a CWT. Their low end units use very similar designs. Also, I haven't been at this in quite a while .
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              The transformer is pathetic....and yeah JG's was a 300 I'm pretty sure. And yeah you're right, it says ATNG on the label
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                Ha you're right. Also, I just realized I use to have this exact unit. Unfortunately many of them got scrapped (not my decision ) though it may be among the few survivors. Not sure, haven't checked in a while.
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  What a shame! Think I can get it up to 300W or more? (Assuming I can find a transformer for it)
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    I wouldn't trust it for more than 250W for an extended period of time.
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Neither would I.
                                      Nice to have you back, 370.
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        250W with the transformer like it is now?
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          Yes.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
