Re: replacing schottky diodes on a AV power supply
the sr320 looks fucked for a schottky - thats far too much voltdrop
probably damaged - just not as much as the other one.
test on V mode while power on.
while take off from board, these are the reading on diode mode
sr320 - 0.343v
sr340 - 0.164vLeave a comment:
i dont understand where you got the numbers,
test the diodes with your diode-test on the meter - both directions.Leave a comment:
What happen if you test the SR340 and compared to the SR320 with you meter?Leave a comment:
I tried the following.
1 piece of SR340
2 piece of SR340
1 piece of SR320 and 1 piece of SR340
None works. If i pull all and put only 1 piece of SR320, it works. SighsAttached Filesif you find these attachements useful please consider making a small donation to the site
Its a home theaters SMPS. I know, it doesn't makes any sense either. But i dont know, i took out the old one, put in 2 new SR340, power on, no power. Pull out again, put in the old SR320 diode, its working and i was like LOLLast edited by DjKrish; 08-28-2020, 07:55 PM.Leave a comment:
higher voltage is fine - infact with schottky's you really want 10x the running voltage.
https://www.badcaps.net/forum/showthread.php?t=54038Leave a comment:
6A 20V, noted, will try that. Cause i fitted the 3A 40V diodes, no power at all. When i fit back the single 3A 20V, its working again.Leave a comment:
neither, your going to need 6A at 20v, not 3A at 40v
parallel diodes double the current, not the voltage
if you check my Ryobi charger thread, i replace a couple of diodes with a 25A to220 package partLeave a comment:
Hi guys, i have a power supply with a shorted SR320 schottky diodes which is in parallel. Only 1 shorted while another is ok. So i removed the faulty one, the power supply is working fine now. SR320 is 3A 20V. I was thinking can i remove both diodes and replace SR340 as 1 diode as it is 3A 40V? Because i dont have SR320. Or can i replace both with SR340?Last edited by DjKrish; 08-28-2020, 01:33 AM.Tags: None
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
Assuming...7 Photos -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
