FSP300 problems - replacement recommendation?
  • yyonline
    • Jul 2009
    • 692
    About 2 years ago, I assembled some computers for a client. I dropped by for a checkup visit, and was very surprised to see bulging capacitors on the motherboard. These were UCC KZE and KZG. I know KZG has low tolerance to heat, but I suspected more might be going on here. The power supplies were Sparkle FSP300, which I was under the assumption was a pretty reliable model. I opened up the power supplies and on 2 of the 3 machines and found a bunch of leaking Fuhjyyu and Jamicon caps. One of the large Fuhjyyu has even popped its top completely and is now visibly hollow.
    I'm a bit concerned here. I've seen FSP300 recommended on this forum, and I've done maybe 20 builds with them. Are they generally safe? Is this a freak occurrence or should I be concerned about my other builds failing on me?
    Finally, what is a recommendation for a decent quality PSU that won't break the bank? I'll need to be replacing these for my client. She'll want something new, with a warranty, so recapping is not an option here, unfortunately. Is there any brand or model out there safe from Fuhjyyu and Jamicon? I don't need super high end, but something reliable at around 300W. Ideas?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: FSP300 problems - replacement recommendation?
    Unfortunately low end FSP/SPI/Sparkle are not all that good. I would just recap them and start using different psu's.
    http://www.newegg.com/Product/Produc...82E16817151086
    High efficiency, APFC, seasonic quality, except for these have been spotted with su'scon caps, not bad but not good.
    http://www.newegg.com/Product/Produc...82E16817707005
    Also a pretty good power supply, ATNG makes good server units. These are populated with all teapo caps, often regarded as ok in power supplies.
    • i4004
      • Oct 2006
      • 2029
      if it has Fuhjyyu inside i wouldn't say it's safe, as your example shows.
      as for "what else is there", delta psus should be good.
      i mean, fortron should be good too, but i didn't know they were putting that crap into some of their models too...uh...fortron i was buying 2 years ago had teapo,ost and capxon, and it's still going strong...
      • yyonline
        • Jul 2009
        • 692
        Thanks for the helpful replies thus far.
        Yes - I know that anything with Fuyjyyu is bad, I just wasn't sure how common it was to find them in the FSP300. Unfortunately, it sounds like this isn't unheard of.
        I've heard good things about Delta PSUs, and I've seen them in lots of name brand machines some rather old and still going strong. However, I'm having trouble finding a place that sells Delta units. Any suggestions there?
        • i4004
          • Oct 2006
          • 2029
          that seasonic 370 linked should be good...corsairs are good...check 400w model price on newegg...
          here it is
          http://www.newegg.com/Product/Produc...-008-_-Product
          if i had that price here i would get 2 right away..and i don't really need new psu...
          i dunno under what badge(brand) can you find cheapest delta in the usa...
          oh yeah, was your psu sparkle, or fortron?
          it seems to me that these still moght be two different factories, no matter if fsp is now the official name of the group.
          this
          http://www.newegg.com/Product/Produc...-915-_-Product
          even the fan grille siggests it's too cheap...heh...that fan has no capacity to keep fuhyu cold anough for 3 years...
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            FSP/SPI has 4 factories actually, all differing greatly in quality due to different suppliers and tooling used.
            Enlight is sold in the US as rebranded delta (you literally just have to peel the enlight label off to see the delta one), as well as almost all antecs, but they are really cheapening the cap quality in antec built deltas.
            http://www.newegg.com/Product/Produc...82E16817373002
            or (out of stock)
            http://www.newegg.com/Product/Produc...82E16817373001
            they even sell a 750W that is in fact a delta
            http://www.newegg.com/Product/Produc...82E16817373008
            • i4004
              • Oct 2006
              • 2029
              yes, i remember you said 4, but we're now discussing one of them, ie sparkle.
              that's definitely not the fortron i know.
              but like you say there are four of them, so it can be hard...hehe...
              i would skip these models with smaller 8cm fan.
              if badcaps are in, it won't last long.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                take a pic of the hollow fuhjyuu if you can. we LOVE pics of catastrophicly destroyed caps. or at least i love them.
                sigpic
                (Insert witty quote here)
                • c_hegge
                  • Sep 2009
                  • 5219
                  Me too. I love seeing pictures of busted caps, especially when they explode completly (i.e. the can goes flying or explodes into 100 peices and leaves rolled up paper and foil on the motherboard).
                  • fluzocapacitor
                    Touchscreen Issues on Samsung Galaxy Tab A: Replacement Problems or Hardware Fault?
                    by fluzocapacitor
                    The touchscreen of my tablet started malfunctioning in a strip about one centimeter wide that stretched across the screen, approximately 5 centimeters from the top edge of the tablet.
                    I bought another touchscreen and replaced it. The issue with the strip disappeared, but on this new screen, the bottom area didn't work, up to about 6 centimeters from the bottom edge of the tablet. The malfunction was quite strange because it only occurred when the first touch was made in that area. In other words, if you touched an area outside the faulty zone and then dragged into...
                    01-01-2025, 03:56 AM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • jean luc ferre
                    laptop hp g72 b52sf screen problems
                    by jean luc ferre
                    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                    i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                    06-07-2025, 03:27 PM
                  • the_rem
                    Unknown transformer : how to find a good replacement part ?
                    by the_rem
                    Hello guys,
                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                    04-23-2025, 01:48 AM
                  • JimBanville
                    Replacement cap recommendation for sub amp?
                    by JimBanville
                    I picked up a KLH SP-90 subwoofer amp it looks suspiciously like the NHT MA-1 amp. There's a board in the KLH that actually has "MA-1" printed on it. Anyway, it powers on and I can hear/feel a slight "noise" from a subwoofer cone attached to the amp, but I get no audio. The two main caps (6800uf 50v 105 degree, 25mm/45mm) are bulged and I measured "OL" on my meter. The leads fell off as I removed them. Can someone recommend a cap that's in-stock somewhere that would be a good replacement? And would these being "bad" cause absolutely no audio? Thanks!...
                    06-02-2021, 10:46 AM
