Good catch!
And OUCH, that is seriously bad cost-cutting idiocy there.
Fortunately, I don't think this can make the house wiring burn down. Look at the wires going to the voltage selector switch and also to the IEC plug - they look like AWG 22 at best. Most likely they would smoke and glow for a few seconds in the event of the fuse not working properly, but could eventually act as a secondary "fuse".
Mmmm. The smell of freshly burned PCB.
*cough* *choke* *choke* * cough*
On that note, maybe the PSU above should be overloaded to see what happens.
Actually, if you do that, you should also try to return the PSU to MicroCenter afterwards and say it went bad in your system. Depending on the MC near you, most will take it back and return your money, no questions asked - kind of like Home Depot returns, really. Besides, I don't see a warranty sticker anywhere. Or was there one that needed cutting/removing? If yes, that might complicate the return (or not, if you did a stealthy enough job.
