bad problems with hiper hpu-4s730
  • raikkonen
    • Nov 2009
    • 11
    hi guys,
    my psu is 6 months old, and hiper is cracked...so no warranty...
    the problem is:
    i start the pc, everything goes fine.
    then i start to play something.
    5 to 30 minutes, and the pc restarts itself, no freezes, no strange images, just restart.
    I tried with another psu(with much less power and quality) and it works fine.
    I opened it, but everything seems fine, caps are teapo.
    What should I do?Should I recap?
    I have oscilloscopes, probes, everything, just tell me what to do, I want my psu back to work!
    Thanks a lot in advance guys, and sorry for my english, I'm italian...
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: bad problems with hiper hpu-4s730
    When it is running, check the temp coming out the back. It may have thermal shutdown.
    Also, teapo is notorious for going bad without showing it.
    • Toasty
      • Jul 2007
      • 4171
      Welcome Aboard!
      "sorry for my english, I'm italian"
      No worries, I'm American and I don't speak Italian one bit.
      When you can, please update your profile to show your location.
      >>hiper is cracked<<
      What does this mean? That you opened it and broke the seal?
      I Googled the unit. Impressive looking. I like the connectors, just not their position.
      System Specifics Please -
      - What is connected to it in your system?
      - What brand & model of mobo
      - CPU
      - # of fans
      - # of drives & types
      - video card(s) & type
      - are you overclocking?
      - any other peripherals?
      Have you contacted the manufacturer with the problem?
      Could it be the motherboard? Certain P5xxx Asus boards do that with the higher end 115w Prescotts(?) 640-650-660.
      How hot is the CPU when it shuts down? Do you have monitoring software that creates a temperature log file?
      Have you removed the CPU HSF, cleaned it, and reapplied an excellent thermal compound -correctly-? Arctic Silver 5 or better such as Shin-Etsu X23-7783D.
      It also be un-balanced loading of the rails. Need more info.
      If you have opened the case, then post us back some info and some pics. We are a bunch voyeurs.
      Toast
      veritas odium parit
      • raikkonen
        • Nov 2009
        • 11
        ok, thanks guys.
        first, my pc:
        cpu intel e8400
        mobo dfi x48 t3rs
        ram: cellshock ddr3 1600 2x1gb cl7
        hdd: 2x samsung spinpoint f1 320gb raid0
        video: hd3870
        there is a 20% OC on the cpu.
        Well, with "hiper is cracked" i mean the company is "out of business", so my warranty has gone...
        Temperatures: no problems at all, system is watercooled(cpu, nb, vga), temps are never over 30°C, i used everest to log them.
        Case is always open...I will show you this evening if i can upload a couple of pics...
        Fans, 2 nanoxia 120mm, 1 crappy 80mm.
        There is also a swiftech mcp350 pump, it's a 7w pump connected to the 12v rail.
        If you need more info, please ask, otherwise, remember that with a lower power cheaper psu, the pc works fine, so the psu is the problem from my side...
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          You may be overloading one or more of the rails on the power supply. With multi-rail psu's I usually put the video card on it's own rail, typically the pci-connectors are on their own rail, the motherboard on it's own, the motherboard connector usually shares the rail with one of the rails for the molex/sata connectors. The cpu power connector usually has it's own rail, also can share the same rail as some molex/sata connectors too.
          I don't know if the rails are labeled as to what cables they go to on this unit, but if it is it should be fairly straight forward.
          • raikkonen
            • Nov 2009
            • 11
            well, there are 4 lines 12V 18A, and double vga connector, it's quite hard from my side to overload them...
            molex for the 2 sata drives and pump are separate, just to be sure...
            damn, i need time to open it again and see the caps values...
            • Toasty
              • Jul 2007
              • 4171
              Hi Raikkonen,
              My questions were aimed at exactly what 370forlife said; an unbalanced load on the rails. But, your explanation and list of components does not indicate that at all. Thanks for listing them!
              I have read some other posts in other boards reporting the same problem you have. i.e.-system won't stay running with this PSU but, put a stock 350w unit in and it never has a problem.
              I concur with your conclusion, that there is some issue with the PSU. It may or may not be a cap problem.
              Please post pics of the PSU insides when you open it up. This is a rare PSU to see and I'm interested in how (well) it's put together. Hopefully it's internals are as good as its outside appearance would indicate.
              Please list all the caps with the following info:
              capacitance/voltage - diameter x height (in mm) - brand/series
              Example: 1000/6.3 - 8x20 - Teapo/SC
              [EDIT: Can you also measure each of the voltages and report those too? ]
              Toast
              veritas odium parit
              • raikkonen
                • Nov 2009
                • 11
                Yes mate, i just need an hour of free time to do the job, hope this evening, but who knows...
                PSU is very crowded internally, full of coils and extra vertical boards with soic chips...it really scares me!i'm used to see few cheap chinese components...
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Remember when PSU is open and powered the heatsinks can be much more than line voltage.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Hiper has been criticized for poor soldering work.
                    - Dr Seuss
                    • raikkonen
                      • Nov 2009
                      • 11
                      This is true, the first thing i've done after opening was re-soldering, but it doesn't help...
                      • raikkonen
                        • Nov 2009
                        • 11
                        hi guys, here's very late, but output capacitors are 3300uf, 16V, 10mm x 30mm teapo electrolytics. Which kind of replacement can I use?I think there's no panasonic fc with these dimensions...
                        • Wizard
                          • Mar 2008
                          • 2296
                          I once had a PSU would not self-start at all, no shorts or open circuits years ago when I checked all over even I tried or probably mis-remembered changing ICs in a AT SMPS (same size as current SMPS cases). That what stuck in my mind about it and what I remembered is back then I did not have ESR meter. Now, I don't have SMPS anymore. Pitched it long ago.
                          Cheers, Wizard
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Teapo usually last in PSU's. Sure they need changed?
                            FC isn't good enough for main OP filters anyway.
                            Only [available & probably reliable] 10mm 16v 3300uF I know of is Samxon RS series.
                            Any other 'good' brands only have them in 12.5mm and up.
                            Those Saxon RS are a custom ordered size but this site sells them if you are in the US or Canada and outside the US/Canada this member sells them.
                            https://www.badcaps.net/forum/member...tposter&t=5956
                            - Dr Seuss
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              topcat ships worldwide now, FYI
                              sigpic
                              (Insert witty quote here)
                              • raikkonen
                                • Nov 2009
                                • 11
                                well guys, i really don't know if they need to be changed.
                                I simply know that electrolytic caps are one of the main fail on atx psu, so i want to try to change them.
                                Moreover, I've heard teapos tend to dry without showing any sign.
                                If you have any ideas about how to test the caps or about how to test the psu(and know where is located the damage), this will be very helpful for me!
                                • Oklahoma Wolf
                                  • Dec 2005
                                  • 353
                                  Unlikely to be the PSU at fault - could be, but more likely it's a driver issue. Depending on what OS this is, you need to disable restart on system failure so you can actually see the bluescreen you currently cannot because of the instant restarting.
                                  • raikkonen
                                    • Nov 2009
                                    • 11
                                    mate,
                                    there is no more issue when i swap the psu with another one...
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      Per favore inserisci la tua fotos.
                                      How was that??
                                      veritas odium parit
                                      • raikkonen
                                        • Nov 2009
                                        • 11
                                        hey toasty, are you learning italian language?
                                        sorry but i haven't taken pictures yet...
                                        i'll do it, this weekend i'm completely free...
                                        ok, i've taken out the three 3300uf caps, measured:
                                        1) 3300uf
                                        2) 3300uf
                                        3) 3200uf
                                        Well, a friend told me can be tolerance, but it's not strange that only one cap has lower capacitance?
                                        Do you think i should change them?
                                        I've contacted Joe for the caps right now...
                                        • mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                          by mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                          11-25-2024, 05:22 PM
                                        • CapLeaker
                                          Dell ATX PSU won’t start, but forcing it works fine?
                                          by CapLeaker
                                          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                          10-28-2024, 06:59 PM
                                        • emil_t
                                          RTX3090 working fine but fans not spinning
                                          by emil_t
                                          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                          04-12-2024, 06:54 AM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
