Power Mac G4 Mdd Acbel power supply (not Samsung)
  • CapLeaker
    Leaking Member
    • 8340
    Re: Power Mac G4 Mdd Acbel power supply (not Samsung)
    there you go! The 12V rail is shorted. Trace it back to the diodes mounted on the heat sink. These have 3 legs. Test the middle leg (negative) to the 2 outer legs (positive) with your multi meter in diode mode. If you find a diode shorted, reverse the leads, put the positive probe on the middle pin and probe the 2 outer pins with the negative probe. If you find something questionable, ALWAYS take it out and test the component out of circuit.
    Remember, to pull up the spec sheet of the diode on the internet. You have to know the voltage drop. Schottky diodes have a very low voltage drop @ around 0.2V compared to a regular diode (0.5 to 0.7V)
    • falcontech
      • Oct 2013
      • 484
      • italy
      Perfect
      Can you tell me based on the photo I sent you which are the diodes to try? on the heat sink there are 5 components on one side and 4 on the other. A curiosity, I did the same test on a working ATX common and when off it gives me the short on both red, yellow and orange, why? yet it is functional.
      I'll update you later thanks
      • falcontech
        • Oct 2013
        • 484
        • italy
        I disassembled the heatsink and the diodes do not give any short but also no value, I noticed that the red is still short, despite there are no diodes on the printed circuit
        • falcontech
          • Oct 2013
          • 484
          • italy
          (maybe it will be stupid) but I also noticed that putting the test leads on the red wire and on the output of the transformers gives me the short on all the feet
          • CapLeaker
            Leaking Member
            • 8340
            Look at the MBR3045 look at the symbol below it. There are 2 diodes in one package. The center pin is the cathode. I think there are 4 MBR3045 and 2 other ones in a smaller package. Make sure none of them is shorted with your DMM in diode mode.
            • falcontech
              • Oct 2013
              • 484
              • italy
              #26
              Hello
              I tried but I have no value on any pin, maybe I have to remove it from the heatsink?
              • falcontech
                • Oct 2013
                • 484
                • italy
                #27
                Nothing, it does not give me any value, I also tried with another dmm
                • falcontech
                  • Oct 2013
                  • 484
                  • italy
                  #28
                  I did it, the diodes are ok they don't give me any shorts, and the mosfet is ok too, now what?
                  • falcontech
                    • Oct 2013
                    • 484
                    • italy
                    #29
                    If it can be useful I have a working acbel and it also gives me a short circuit on the red wire, so I think it's normal
                    • CapLeaker
                      Leaking Member
                      • 8340
                      It must be O.K. then. Back to basics: So when you turn the PSU on, do the 3.3V, 5V and 12V rails briefly turn on? What voltage do you measure? You can use the min max function on the DMM, if it has it.
                      • falcontech
                        • Oct 2013
                        • 484
                        • italy
                        #31
                        ok tomorrow I will do this test, please try to be clearer, do I have to measure the output voltages on the psu working? I don't know what this function is on the DMM
                        • CapLeaker
                          Leaking Member
                          • 8340
                          On your very first post, you stated that the LED turns on for a brief second, then fades away. I wonder if all the voltage rails turn briefly on, maybe one rail does not. No you don't have to measure anything right now on the working power supply.
                          • falcontech
                            • Oct 2013
                            • 484
                            • italy
                            #33
                            ok I try to do this test even if it will not be easy, because it gives me that hint of ignition twice after it dies, to make it redo the operation I have to turn off the power leave it off for a while and then do it again, I can tell you, that when the power supply unit also starts, the processor and power supply fan also give a hint
                            • CapLeaker
                              Leaking Member
                              • 8340
                              it's kind of hard to work off of pictures and not having a schematic for it. There is this green little daughter board on the secondary low voltage side. Make sure it is soldered properly / inspect it for cracked solder joints.
                              BTW, do you have a variable constant voltage, constant current power supply?
                              • CapLeaker
                                Leaking Member
                                • 8340
                                so maybe it is shutting down from it thinking it is a over / under voltage condition?
                                • R_J
                                  • 9607
                                  How are you checking for the short? what is the meter range set to and what is the actual resistance?
                                  • falcontech
                                    • Oct 2013
                                    • 484
                                    • italy
                                    #37
                                    the daughter card should take care of the fans I don't think that's the problem, what type of power supply do you say ac or dc? and how many volts?
                                    • falcontech
                                      • Oct 2013
                                      • 484
                                      • italy
                                      #38
                                      now I don't remember I'm not in the laboratory tomorrow I'll let you know
                                      • R_J
                                        • 9607
                                        The reason I ask is that some people use a meter that beeps and assume there is a short.
                                        • falcontech
                                          • Oct 2013
                                          • 484
                                          • italy
                                          #40
                                          however tomorrow I want to try to move the heatsink block with all the diodes in the working one and if it were to give a negative result I want to try to move the transformers I doubt that they are the ones, could it also be the integrated lm ****?
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • cheeky2
                                            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                            by cheeky2
                                            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                            06-15-2025, 05:12 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
