I recently rescued a generic PSU from the trash heap and replaced 5 bulging caps with Samxons. I used slightly higher capacities over the originals: I used 1500 ufd for the original 1000 ufd caps and 2200 uf instead of the original 1500 ufd. I put it in my old but working 1.2 GHz desktop and it did run without any problem. Except that my digital multimeter reads 5.25 volts on the 5 volt rail. It is exactly the acceptable 5% above the rated voltage on that rail. Is this OK or would I have a problem down the road?
Is 5.25 v acceptable for the 5 v rail?
Re: Is 5.25 v acceptable for the 5 v rail?
It's fine, just watch it to make sure it dosen't get too high. 1.2ghz sounds like a 5v based athlon or p3. May have too low of a 12v load, try plugging in a couple old hard drives and see if it goes down.
What he said makes sense.
If adding load on +12v doesn't bring +5v 'in' then it's still probably okay for a while but I'd be afraid it would drift further out over time.
Very possible some component has drifted off it's rated value.
[Like for example a resistor that drifts up or down in resistance due to age/heat.]
If it's drifted it make keep drifting.
If you aren't into the idea of checking voltages frequently [weekly for a while then monthly] then it's probably a good idea to fix it or look for a good deal on a better PSU. It's not like urgent but don't put it off and forget.
Replacing with better one is the easy way to be done with it.
If you are into the whole TS&R thing then you can trace out all the circuits and most likely correct the problem but your system will be down while you're tinkering.
Which is better depends on your priorities.
.Mann-Made Global Warming.
- Dr Seuss
This is interesting. I have 2 PSUs that will not fire up an Athlon board running at 1333Mhz. They both turn the board "on" including processor fan and hard drives, but no POST. When measured they check out fine except the 12v rail which is 11.68/11.48 respectively on each PSU. So my 12v is well below what it needs to be to get the board to post (I ended up using a PSU that did work)Originally posted by 370forlifeIt's fine, just watch it to make sure it dosen't get too high. 1.2ghz sounds like a 5v based athlon or p3. May have too low of a 12v load, try plugging in a couple old hard drives and see if it goes down.
Where would I look on the PSUs to correct this 12v problem? Does it sound like a MOFSET issue? The 5v and 3.3v are right in line. I fixed an older PSU once like this by jumping the MOFSET chip, it just lost the ability to shut itself down and hibernate but not standby so I added a hard switch like an AT design on the front of the case.Comment
You have a problem but 12v voltage isn't it.
PSU's don't regulate well until you have enough load on them.
When you check volts with no load it's rarely going to be in the middle of the +/- range but it should be at least somewhere in the range.
[And yours look to be given the probable tolerance of your voltmeter.]
As you add load the voltages should move closer to the middle of their ranges.
+12v low and +5v high is pretty typical of an unloaded PSU.
Your symptoms sound like maybe a dead mobo chipset.
- Dr Seuss
Agree with the other comments. Check the (2?) 12v output caps at the pi filter. Perhaps the one on the input side is weak. Parallel a good cap across it on the underside and see if the voltage pulls up.veritas odium paritComment
I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
Well, my decice specs are the following:
Model: Acer Nitro 5 AN517-54-55T5
CPU: Intel Core i5-11400H
GPU: NVIDIA GeForce GTX 1650
Motherboard: GH51G LA-L181P Rev:1c
The symptom:
When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...05-26-2025, 10:49 AM -
by lefetylorantHello Everyone,
Long story short, I got this unit for very cheap.
I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
I've performed some measurements:
- 20V rail perfectly... -
by bimoleHi,
A colleague gave me an apparently ill CORSAIR CX600.
He told me that he heard a banging noise, and smelt the magic smoke.
After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
It's another story on the 3.3V rail...
I have some devices to test deeply PSUs (scope, AC source, electronic load)... -
by Nagy DanielHi, I'm Daniel, and I'm new to the world of repairing motherboards.
I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
So, I generated a table with AI so I can... -
by mkdjDear all,
I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
I have checked resistance across each of the 4 MOSFETS. I have the following readings:
Both N-Channel Mosfets: nothing odd
P-Channel MOSFET number 1:
source - drain : 117 kOhm
source - gate: 96 Ohm
gate - drain: 117 kOhm
P-Channel MOSFET... - Loading...
