Repairing a FSP250-60GTV (PF)
  • Leopard
    • Mar 2008
    • 109
    • Finland
    I will be doing a complete recap on this one, minus the 2.2uF and 1uF caps.
    [ORIGINAL CAPS]
    - 2x 470uF 200V Teapo [LXK] Input caps
    - 2x 3300uF 10V Teapo [SEK] +3.3V rail
    - 1x 3300uF 10V Teapo [SEK]
    - 1x Jamicon 1000uF 10V [TM] +5V rail
    - 1x 2200uF 16V Fuhjyyu [TMR] +12V rail
    - 1x 100uF 25V Jamicon [TK] -5V rail
    - 1x 100uF 25V Jamicon [TK] -12V rail
    - 1x 100uF 25V Jamicon [TK] +5VSB output
    - 2x 47uF 50V Teapo [SEK]
    - 1x 470uF 25V Jamicon [TK] Part of +5VSB
    I'm also thinking of desoldering the +12V load resistor (seen in the second pic next to the huge pink +5V load resistor) and adding a capacitor in its spot because the PSU is only silkscreened for one +12V filtering capacitor. I'll also mount the +5V load resistor to the heatsink, away from the caps. Any comments?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Repairing a FSP250-60GTV (PF)
    Unit only supports 13 amps on +12.
    I don't think a second cap is worth the trouble but you might up the single to 3300uF [or more].
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      BTW: Might wanna add diameters but other than that it's great to see good documentation.
      - Dr Seuss
      • Leopard
        • Mar 2008
        • 109
        • Finland
        Oh yeah, the diameters! Forgot those.
        The large output caps are all 10mm. It'll be a really tight fit, but I think I can fit a 12.5mm cap for the 12V to get the desired 3300uF and to remove the need to desolder the load resistor.
        The largest value 10mm 16V low ESR cap I was able to find was only 1500uF, and that's a no go since this is going into a P4 system.
        The 470uF cap part of the +5VSB is 8mm, but theres plenty of space around it so a 10mm cap should not be hard to fit.
        47uF and 100uF caps are all 6mm (or 6.5mm).
        Input caps are 22mm. Quality caps of that diameter and 470uF 200V are hard to find. There is no space for larger caps, C1 is blocked by the bridge rectifier and C2 by the heatshrinked Y caps between the input caps.
        • Leopard
          • Mar 2008
          • 109
          • Finland
          All right, I'm working on this again. Going to order replacement caps at the end of the week.
          I have a "gutless wonder" power supply lying around. I was thinking if I could replace the Fortrons +12V schottky rectifier with the +5V schottky rectifier of the gutless supply. The part number is of the SB3040PT.
          Datasheet
          Fortron part SB1660 datasheet
          • etnietering
            • Apr 2009
            • 379
            It looks to me like you might not be able to easily transplant the diode. The fortron on is just a single diode, and the package only has 2 pins, while the replacement part has 2 diodes in it and has 3 pins. I don't know the specifics of the unit though, so maybe the original part is completely undersized and it has room for the big one. Just make sure to be careful when putting the new one in to make sure the polarity of the diodes are correct. A backwards diode will cause all sorts of problems.
            About the caps - the only problem you might run into when replacing an 8mm with a 10mm is lead spacing. I believe most 8mm caps have lead spacing of 3.5mm, where 10mm caps have 5mm lead spacing. There might be some caps with the other lead spacing for applications like this, it's something to watch for when picking caps. Otherwise you can just bend the leads.
            • andero
              • Mar 2010
              I'v got FSP250-60GTV.
              Can you please measure resistance between 5V rail and GND(can be even on molex). I've got burned +5V load resistor too, and it seems to have only 7 Ohms resistance. What is right value.
              • mlr_1120
                • Aug 2015
                • 3
                • philippines
                hello there, am also trying to repair my old FSP250-60GTV psu. nothing seems to be burnt, i've retraced the +5v rail on that big pink resistor but i get no power... the fan just starts spinning briefly for a second or so, and then it stops... when i try to short the "ps on" line and ground, fan spins for a second and then nothing happens after that.. i've checked all my caps and they seem ok.. no buldging/leaking/burnt whatsoever...
                thanking you guys in advance...
                  • 31017
                  the caps dont need to bulge or leak to be bad - specially on something that old.
                  your description makes me think you have something shorted or the small caps are bad.
                  • everell
                    • Jan 2009
                    • 1514
                    Look at the circuit trace under the circled resistor. The resistor has very little support, and the slightest movement can cause the circuit trace under it to break causing an open circuit. I fixed one of these by repairing the trace under this resistor.
                    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                    • mlr_1120
                      • Aug 2015
                      • 3
                      • philippines
                      @stj
                      @everell
                      Thanks for the reply guys, i resoldered the big resistor's connections and added wires to the path. All is working now but i dont quite have the right vvoltage. For the 12v rail, it only registers 11.1v and at the 5v rail, i only got about 4.2v. I tested this without any loads yet. Hope you guys could help me with this. Thanks in advance...
                      • mlr_1120
                        • Aug 2015
                        • 3
                        • philippines
                        How will i determine if those small caps are bad? Aside from physical appearances...
                          • 31017
                          esr meter.
                          go on ebay and search "mega328 esr meter"
                          • Behemot
                            • 4845
                            • CZ
                            If you want something better, say entry-level professional, I have ESR Micro v4.0si with relay protection from charged capacitors (and HV in general).
                              • 31017
                              and more importantly, it's cased.
                              • Dan81
                                SNES-powered
                                • Oct 2013
                                • 1865
                                • Romania
                                If you're at it,you may want to replace or just remove the 5v load resistor.
                                I have a FSP300-60GTP and while I was fixing it I removed the scorched 5v load resistor because it was scorched as hell. PSU works fine now,powers a Dual Core LGA775 setup I have as my main rig.
                                Main rig:
                                Gigabyte B75M-D3H
                                Core i5-3470 3.60GHz
                                16GB DDR3-1600
                                Samsung SH-224AB DVD-RW
                                Delux MG760 case
                                • Behemot
                                  • 4845
                                  • CZ
                                  Sure and now has better probes too. English manual and warranty (we all know how it's with chinese and warranty, after the protection period from ebay or paypal runs out).
                                  Dan81: or make flying-resistor mod. I suggest not messing with +3,3/+5 V resistor if you are going to use +12 V hungry system as it will put only a light load on those rails.
                                  • Nagy Daniel
                                    Lowest possible resistance on laptop motherboard rail - Guide Table request
                                    by Nagy Daniel
                                    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                    So, I generated a table with AI so I can...
                                    03-04-2025, 08:24 AM
                                    by momaka
                                    03-15-2023, 10:17 PM
                                  • Victor Moreira Silva
                                    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                    by Victor Moreira Silva
                                    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                    Well, my decice specs are the following:
                                    Model: Acer Nitro 5 AN517-54-55T5
                                    CPU: Intel Core i5-11400H
                                    GPU: NVIDIA GeForce GTX 1650
                                    Motherboard: GH51G LA-L181P Rev:1c
                                    The symptom:
                                    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                    05-26-2025, 10:49 AM
                                  • lefetylorant
                                    Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                                    by lefetylorant
                                    Hello Everyone,
                                    Long story short, I got this unit for very cheap.
                                    I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                                    I've performed some measurements:
                                    - 20V rail perfectly...
                                    09-14-2023, 05:05 AM
                                  • bimole
                                    Weird behavior on 3.3V rail of a CORSAIR CX600
                                    by bimole
                                    A colleague gave me an apparently ill CORSAIR CX600.
                                    He told me that he heard a banging noise, and smelt the magic smoke.
                                    After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                                    I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                                    It's another story on the 3.3V rail...
                                    I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                                    02-13-2025, 04:49 AM
