imac G5 psu component level question/challenge.
  • finndigg
    • Sep 2009
    • 8
    I was hoping to help my friend repair her iMac G5 17" 1.6g Rev A computer by changing the caps in the Power Supply and Logic Board. But when removing the caps on the power Supply I noticed a broken zener diode and feel it may be useless to continue until I identify and change that component first. The diode in question is labeled ZD4 on the circuit board itself. (I have a picture but I'm not sure how to post it)
    And while I was able to find an Apple service manual for the model online it is of little help in that it doesn't address component level repairs.
    Would anyone be able to help me accurately identify this component so I can replace it?
  • etnietering
    • Apr 2009
    • 379
    Re: imac G5 psu component level question/challenge.
    I'm sure somebody here (maybe me, maybe not) would be able to help you. To upload a picture:
    Below the text window for posting, under 'additional options' there is a button that says 'Manage Attachments' Click this, and the window that comes up will let you upload a picture. To insert the picture into your post, right click the link to the picture you just uploaded and select 'copy link' or 'copy link location' Then click the icon of a mountain in front of a yellow sky, and paste the link you just copied into the box. It will automatically tag it for you. I find it useful to click the 'preview post' button to make sure I did it right before submitting my post.
    • finndigg
      • Sep 2009
      • 8
      Ok. Here's a few pics, though I doubt they will be very helpful. The first (zd4) is one I took with the camera on my laptop. The second is the best picture I could find on the internet - and I made some marks pointing to the component. I used a magnifying glass to look closely at the component beneath a good light but I couldn't read anything besides the ZD4 printed on the board itself. The model is iMac G5 17" 1.6g Rev A.
      • finndigg
        • Sep 2009
        • 8
        Oh forgot to mention, the caps are removed in the first picture.
        • Toasty
          • Jul 2007
          • 4171
          3.3v, 1w
          veritas odium parit
          • finndigg
            • Sep 2009
            • 8
            Thanks Toasty!
            A few follow up Questions:
            I heard somewhere that one should get something called a "temperature
            compensated" diode for the purpose served here. Is there anything to
            this?
            Further, As with capacitors some brands are favored while others
            are advised to be avoided. So with diodes, are any particular brands recommended over others? - any brands to especially avoid?
            And finally any recommended places to purchase? Thanks.
            • Toasty
              • Jul 2007
              • 4171
              Please state source of information/reference.
              I heard somewhere that Elvis is still alive....
              1N4728A - Fairchild, ON, TI - any reputable maker.
              Wherever you get the caps* for this is fine - DigiKey, Mouser, Newark
              *You'll need 13 without the mains, or 15 with.
              Toast
              veritas odium parit
              • finndigg
                • Sep 2009
                • 8
                This may be a silly question but I don't know much about diodes. When I looked up 1N4728A at Mouser I noticed that the zener current varies by component. Some are listed as 76 mA while others as .2A and yet others as 276 mA. Which of these would be preferable, if any?
                • etnietering
                  • Apr 2009
                  • 379
                  Well power = voltage * current
                  so if power = 1W, and voltage = 3.3v, then you can calculate the current:
                  1W / 3.3v = 303mA, so I'd go with the 276mA one.
                  • Toasty
                    • Jul 2007
                    • 4171
                    None - see below* for a correction. I had to grab one and test it and examine the surrounding components.
                    The series resistor is a 1mm chip @ 240 ohms.
                    The current your looking for is the zener holding current. At there and above, it holds the voltage constant.
                    * I'm going to recommend going to a 1/2 watt zener (500mw). The holding current necessary for my original recommendation is too high for the 1/10watt chip resistor. Instead go to this one which holds at 10ma:
                    Mouser #: 583-1N5226B-B // Manuf. #: 1N5226B-B
                    http://www.mouser.com/ProductDetail/...FPb2G3UpTEc%3d
                    At that current, the resistor is handling 24mW; 1/4 of its power rating.
                    Toast
                    veritas odium parit
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      congrats on catching a broken diode. most people would not notice it and go straight for caps.
                      buy a few diodes... in case it blows up and your up the creek or you mess the first one up. besides, its cheaper in most cases.
                      dont forget to check your polarity on both diodes and caps. always take pics before you go in case the silkscreen is wrong/confusing/non-existent. you seem to have already so another thumbs up on that.
                      keep up the good work! feel free to ask questions- look for the member junk parts and read his signature... the mark twain quote is the truth so when in doubt, ask.
                      sigpic
                      (Insert witty quote here)
                      • finndigg
                        • Sep 2009
                        • 8
                        Thanks for testing, Toasty.
                        • finndigg
                          • Sep 2009
                          • 8
                          I put in the diode and new caps on the power supply last night. But I would like to test it before hooking the mother board to it. I have a pin read-out diagram for the unit that I found. I did a search on this forum and there was some talk of using a jumper (jumper the plug)? but I couldn't find anything specific on what was meant by this. I just want to do the right thing before I plug it in - any help kicking me in the right direction would be appreciated.
                          • finndigg
                            • Sep 2009
                            • 8
                            Well as best I could tell, what was meant by "jump" was 15 to ground so I used a snipped cap leg to bridge it - held my breath and plugged her in: no smoke and flames. My test results were normal except pin 4,6,20 and 21 read as 5v rather than 5.1v and pin 22 looked closer to 26v than 24. Are these variations normal/to be expected?
                            • Player2
                              • Aug 2009
                              • 98
                              That sounds reasonable to me. 5v/5.1v is pretty negligible. The 24v should be for the backlight inverter, and with a load it should read closer to 24v. Congrats on getting it working!
                              • hobostove
                                Corsair RM1000e - Help identify 5VSB Zener diode
                                by hobostove
                                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                There's a 22ohm resistor that's melted and open, but it still has the bands.
                                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                It looks like the diode connects the source and drain of a TNY284...
                                03-27-2025, 02:25 PM
                              • jezzaaaa
                                Identify replacement diode
                                by jezzaaaa
                                I'm trying to find a replacement diode for one that has gone short.
                                I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
                                I can't find the exact part number for sale. Similar...
                                05-09-2023, 11:26 PM
                              • gurj1979
                                Ubiquitiu 24 port POE. Help Identify Diode 3pin)
                                by gurj1979
                                Hi again guys.
                                Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
                                I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
                                Anyone help me identify the model of this Diode ?...
                                08-23-2023, 08:39 AM
                              • vjsmoreira
                                Trying to identify PWM controller on a Netapp PSU (model ym-2751a) the component on the picture
                                by vjsmoreira
                                It must be the PWM controller on a Netapp PSU (model ym-2751a)
                                Also include a picture where is he location.
                                I believe it has 7 pins and starts by TOP.
                                06-16-2025, 01:46 PM
                              • Tr0ll
                                by Tr0ll
                                Original T-con:
                                First replacement T-con:
                                10-07-2023, 07:48 PM
