"Delta Power" MAX-500ATX 450W power supply (not real Delta)
  • etnietering
    • Apr 2009
    • 379
    Re: "Delta Power" MAX-500ATX 450W power supply (not real Delta)
    Look much better to me!
    I have some more upgrades in the works for my logisys (once my 60W soldering iron and oscilloscope come in ): upgrading the secondary side schottky packs (they're significantly underrated) and adding my delayed fan turn off controller thing from my other thread. I got a ton of schottkys from ON Semiconductor for really cheap. You can get up to 10 different components (max of 5 or 10 of each) for 11 dollars shipping and handling. So for 11 bucks I got 60 schottky packs, 5 30A 450V NPN switchers, and 30 linear voltage regulators. Not bad! The NPNs are almost 4 bucks apiece, if you were to actually buy them!
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      HOW TO DO THIS?
      • etnietering
        • Apr 2009
        • 379
        you have to make a 'myON' account, then when you find what you want, click on 'samples' (not all parts are available for samples) and then you collect them in your cart. Then when you're done you click check-out and put in your info (you have to make up a company), and they send it to you, real speedy fed-ex
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          This could be useful information...
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            not bad. that is probably one the worst units i have seen. the heatsinks are better than the worst which had flat aluminum plates with no fins or stamps, or bends.
            why the new fan? id use the old one until it died and then replace it.
            sigpic
            (Insert witty quote here)
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Ya, but what would happen when it died and you weren't in the room to know it...
              • Newbie2
                • Sep 2005
                • 885
                The fan was generic and I assume it is a low-quality sleeve bearing fan, and this power supply was in use before, so I guessed that the original fan didn't have much life left in it and replaced it.
                It is just a backup power supply that won't see regular use, but if it does need to be used then it's better to be safe than sorry.
                My gaming PC:
                AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                ASUS M4A77TD AMD 770 AM3 Motherboard
                PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                ASUS Xonar DG 5.1 Channel PCI sound card
                Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                Antec Three Hundred Mid-Tower Case
                Microsoft Windows 10 Pro 64-bit
                Microsoft Windows 7 Ultimate SP1 64-bit
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  good point. but ANY part could do that
                  sigpic
                  • Newbie2
                    • Sep 2005
                    • 885
                    At least there's not as high of a chance of the fan failing. If the fan failed the little heatsinks I guess won't be able to sufficiently dissipate the heat generated by the primary and secondary side components, and lead to early failure.
                    My gaming PC:
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Heres what I got
                      MBR4045WTG 40 A, 45 V Schottky Rectifier
                      MBR6045WTG 60 A, 45 V Schottky Rectifier
                      MBRF30L45CTG 30 A, 45 V L-Series Schottky Rectifier
                      MBR3045PTG 30 A, 45 V Schottky Rectifier
                      MBR60L45WTG 60 A, 45 V L-Series Dual Schottky Rectifier
                      MJW18020G Bipolar Power NPN, 30 A, 450 V
                      MJE5852G Bipolar Power PNP, 8 A, 400 V
                      MBR7030WTG 70 A, 30 V Schottky Rectifier
                      MBR60L45CTG 60 A, 45 V L-Series Schottky Rectifier
                      MBR40L45CTG 40 A, 45 V L-Series Dual Schottky Rectifier
                      the reason I got so many similarly rated ones is because some are TO-247, which can dissipate heat better because of larger surface area, and others are TO-220, which a lot of cheaper psu's aren't silkscreened for the larger lead spacing of the TO-247.
                      • etnietering
                        • Apr 2009
                        • 379
                        Nice! the TO-247s are huge! You'll need to get some type of thermal pads to electrically isolate them from the heatsinks - otherwise you're in trouble.
                        And yeah, a fan failure can cause a cascade of other failures...good fannage is important
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          ya, I have a ton of the 30A, 45V TO-247's from propriatary dell newton and lite-on psu's, as well as a huge pile of the thermal pads that go with them.
                          You can also get to-247 thermal pads on digikey in a pack of 100 for $0.41, and 100 to-220 pads for $0.22, which I just might.
                          • linuxguru
                            • Apr 2005
                            • 1564
                            #33
                            Check out the voltage specs on the 6N60 - it's probably not as high as the 2N60, which is good enough for the auxiliary flyback. Likewise, 13007 BJTs and the original secondary rectifiers are also good enough. Everything else seems fine.
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              The parts on the secondary at least are probalby no where near 450W, but probalby really pushing it for 300W, and their labeled ratings are probalby what they can do at 25C. Heat em up to 40C and you are probalby looking at 2/3 the capacity as at 25C. Thats why its good to overbuild them. Also puts the voltages more closer to their specs. Thats why the allied 500W on the JG review kept the 5v at 5.1 until just before it puked its guts out, it had 60A of capacity for it.
                              • everell
                                • Jan 2009
                                • 1514
                                I can understand why you changed the 13007 switching transistors to 13009. But I don't understand the need to change the 2N60 2A transistor to a 6A transistor.
                                The 2N60 transistor is one of two transistors in the 5vsb circuit. Two amps at 320 volts should be plenty for anything the 5vsb circuit is going to do. But a 6 amp transistor????? What about the little black transistor next to it that drives it? Will it be able to handle the extra drive power requirements? And will that itty bitty 5vsb transformer be able to accomodate the extra current capability?
                                I am eyewitness to what happens when the 5vsb circuit EXPLODES and puts chunks of transistor into orbit!
                                Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3112
                                  I know in my yuelin when I changed that 3rd transistor on it's heatsink to the 6A one from the CWT, it just blew the fuse. Not just popped it, but blew it. I put the original 2A back in, and it fired right up. There was no shorts or anything.
                                  I wonder why it worked for this sunpro?
                                  • Newbie2
                                    • Sep 2005
                                    • 885
                                    Do you know what the model numbers are for the original transistor and the transistor that came out of the CWT?
                                    I didn't know that the 2N60 MOSFET was for the +5VSB circuit, if I knew then I wouldn't have upgraded it.
                                    It does work though, and I already have it in there. I don't think it will decrease reliability, since it's just a higher-rated MOSFET.
                                    My gaming PC:
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #38
                                      Read everell's post again.
                                      What he's saying is that when you put a higher-rated MOSFET, you also need more current to turn it on. But if the small transistor that drives this higher-rated MOSFET can't provide enough current, then it could either overheat and die or the MOSFET just won't be fully turned on (which means poor efficiency and more heat - if I remember correctly, MOSFETs are most efficient when either fully on or fully off). I think I read this somewhere else as well.
                                      So overall it is possible to decrease the reliability.
                                      These cheap power supplies were never meant to do anything over 300 watts, so no matter what you put on the secondary side, they'll just blow up.
                                      In fact, this is exactly what many cheap manufacturers do - they look at how much each schottky diode on the secondary can handle, then they calculate the wattage for each rail, add them up and slap that number on the label - and that's just wrong.
                                      What should be done instead is look at how much the primary side can handle and write that wattage on the label. From there, they can overbuild the secondary as much as they like, just as long as they state that the wattage for all the rails cannot combine or exceed over the rating for the primary.
                                      Of course if those manufacturers did that, all these cheap power supplies will have a rating of no more than 250 watts. From a sales point of view, it makes much more sense to put an astronomically-high value on the label and call it "peak" or "max" power.
                                      • Newbie2
                                        • Sep 2005
                                        • 885
                                        The new P6NK60Z MOSFET I installed has a lower RDS(on) than the original 2N60 MOSFET, 1Ω vs. 5Ω. The gate source voltage (VGSS) of both parts are the same, ±30V. The typical input capacitance (Ciss) on the P6NK60Z MOSFET is higher than the 2N60, 905pF vs. 270pF, but this shouldn't affect performance by very much.
                                        I think the 6A MOSFET, while very overkill, should be fine.
                                        My gaming PC:
                                        • i4004
                                          • Oct 2006
                                          • 2029
                                          #40
                                          >Any more comments?
                                          it's peculiar to put godo components to these crap psus.
                                          nest up it'll blow the main switcher, then you swap that too.
                                          after that transformer will melt, will you fix that too?
                                          hehe...you get the point...
                                          what you did helps it somewhat, but only real help for it is garbage dumpster.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            07-01-2024, 06:34 AM
                                          • dragon3x
                                            >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                                            by dragon3x
                                            Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                                            that is still quite new, as it worked OK for some months until it failed.
                                            At the time I was not into power supply electronics; it was put
                                            aside and a new power supply installed inside the computer. Also at the time
                                            power supplies were half the price of today's.
                                            On the PCB there are a D339 and 7500B chips.
                                            I have found that schematics with these 2 chips (see included file).
                                            Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                                            Some measurements,...
                                            06-05-2024, 03:34 PM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • Gentian
                                            Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
                                            by Gentian
                                            I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
                                            09-27-2025, 11:03 PM
