230VAC PSU connected to 400VAC
  • electroBriedis
    • Aug 2019
    • 4
    • Latvia
    I accidentally connected a 230 VAC to 24 VDC PSU to 400 VAC. After about 5 seconds there was a spark and then the mains circuit breaker tripped. I have added the pictures of how the damage on the PSU looks in the attachments. The PSU's model is PULSE QS10.241.
    I don't have much experience in fixing electronics and no PSUs at all. How should I go about fixing this? The varistor clearly needs to be changed and the big capacitor most likely as well. I don't see anything else visibly damaged, could changing just these 2 parts fix the PSU? Are there any tests that can be done before I connected the PSU to power again?
    • 31090
    Re: 230VAC PSU connected to 400VAC
    you may be lucky,
    the blue thing is a MOV, a device that gets rid of spikes.
    they suicide themselves in these situations causing the fuse to blow.
    you may get away with a new fuse and MOV.
    the cap is probably o.k. - other than the soot-stain on the side!
    most important though - you have to clean that crap off the board / parts because it can be conductive.
    and i would replace the second MOV in the picture too, it looks like it has a hole in it.
    is the fuse glass, or ceramic? either way the replacement should be ceramic.
    • redwire
      • 3910
      I see molten metal on the PCB, hopefully it was the MOV melting. Not arcing to the cap can. I did not see a burnt NTC anywhere.
      You could carefully cut out the MOV's, replace the fuse and try the PSU. The MOV's are for surge and overvoltage protection and the PSU can run without them for doing a test.
        How about showing us the pictures of the whole board?
        I would check the bridge rectifier, diodes, MOSET's, ect. to see if any of them shorted out.
        You do have proper tools for testing and soldering, correct?
        • electroBriedis
          • Aug 2019
          • 4
          • Latvia
          Thank you everyone for your replies! I added more pictures so the board is better visible.
          To answer your questions:
          @stj
          The fuse is ceramic. You can see it in one of the pictures.
          A complete noob question, but can I try to just pull out the fuse or are fuse holders like this meant to be desoldered to replace the fuse?
          @budm
          I have a decent soldering station, solder wick and a multimeter. Do you recommend any other tools?
          • R_J
            • 9558
            That is a pigtail fuse and needs to be unsoldered to be replaced
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              After checking the bridge rectifier, diodes, MOSET's, ect for shorts as budm suggested:
              Replace the fuse with a 60w (or more) incandescent light bulb.
              If the bulb is lit brightly and does not dim when you power it on the PSU is still shorted...
              • survivalbloke
                Acer Predator Helios 300 - will not power up if battery is CONNECTED
                by survivalbloke
                This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                06-25-2025, 12:20 PM
              • beogeek
                820-2915-A Wont power on with battery connected
                by beogeek
                Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
                I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
                After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
                So to cut the long story short I've replaced U7000,...
                02-26-2022, 01:29 AM
              • muhuruu
                PS5 too many USB devices connected
                by muhuruu
                Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
                05-19-2025, 07:14 AM
              • AJ847.63e
                Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                by AJ847.63e
                Hi Folks,
                Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                05-06-2025, 10:37 PM
              • versionlab
                Weird problem, laptop stays on when connected to another pc
                by versionlab
                Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
                Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
                After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
                10-26-2022, 03:43 AM
