Smart Charger 29 volts @ 1 amp how do I change it 25 volts
    • Jul 2011
    • 6046
    I bought these chargers to charge 24 volt li-ion battery packs I could not find one that would be at 25 volts and the close I could come up with is this
    What resistors would I have to change to make it work at 25 volts not 29 volts
    The ic chip that is KTG3646 has a logo of ( IG ) I can not find a data sheet for it
  • redwire
    • 3910
    Re: Smart Charger 29 volts @ 1 amp how do I change it 25 volts
    It's very cheap power supply - there is no opto-coupler+voltage reference (i.e. TL431) to provide feedback to the SMPS IC and control the DC output voltage.
    It might just regulate from the aux winding, not the output. That leaves only R5, R6 and the top resistor by EC2 to tinker with.
    In other words, it is regulating the voltage on EC2 which is proportional to Vout, on the mains side.
    The LM358 and all those parts are just for the LED. You'd have rto find the IC datasheet and sketch the schematic a little, but I would not use it for lithium ion battery charging because it will always have poor regulation and it's not really a 29W power supply. The parts would overheat.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Use a step down buck converter. That is the safest thing.
      • R_J
        • 9557
        The ic maker is Kintago, This may or may not help
          • Jul 2011
          • 6046
          Thank you for finding the data sheet for me it very hard to read the part number on the ic chip
          This is helps a lot at
          I now understand how this switching power supply is suppose to work
          From what I read it might not make a difference but I will have try it and see how it works
          Now what I could limit the current more than it is set to now this is just a thought at this point
            • Jul 2011
            • 6046
            One note
            I would be charging these batteries with a BMS protection board
            • R_J
              • 9557
              If you could not read the numbers clearly, It could also be a KTG3546
              • gabiz_ro
                • Mar 2011
                • 167
                • Romania
                That 24 volt li-ion battery packs how are made?
                In most cases (for tools example) are in multiple of 3.6 or 3.7V
                18V ones are formed by 5 elements,
                3.6V x 5 elements = 18V
                but fully charged
                4.2V x 5 elements = 21V
                So depending on number of elements voltage may be higher than 24V
                  • Jul 2011
                  • 6046
                  It has 4.2 X 6 elements = 25.2 volts —> before the BMS protection board ends the charging cycle which is really 4.1 X 6 elements = 24.6 volts
                    • Jul 2011
                    • 6046
                    You have the right part number the second digit was the one that I could not really make out for sure what it is
                      • Jul 2011
                      • 6046
                      I did run a test on this battery charger controller
                      On a scale of ONE board does not work at all TEN board works perfectly
                      I give it a 2.5 and this might be too high of a rating
                      Here is why
                      One note the battery voltage was at 3.3 volts per cell
                      Yes it will charge the batteries however after about five minutes the temperature of the case goes to a temperature of 128*F at this point I stopped the charging of the batteries
                      You were right about it would over heat but I want to test it myself and see just how bad it could get
                        • Jul 2011
                        • 6046
                        Now I have found a way to use the secondary side of this power supply based on this reply
                        I did have to add more resistance to LED lights circuit so the LED lights would not burn up
                        It only takes 10 milliamperes to active the current sensing circuit LED light and 0 milliamperes
                        for the other LED to be lighting
                        ( the circuit works at voltage of about 13 volts and higher to about 30 volts I think I read in the data sheet)
                        I cut the circuit board and separate the primary from the secondary and use that part of this circuit to let know when the battery pack is fully charged
                        The primary side of the circuit is going to used for a low level LED module but I have to work on this circuit when I have some time for this project
                        • BTubbs200
                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                          by BTubbs200
                          Dell Latitude 5420 P137G
                          Board: LA-K491P REV A01
                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                          Board seems to have no shorts, all power rails are fine and show high resistance.
                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                          01-24-2025, 08:15 PM
                        • dbuergi
                          DIY: Modified smart charger for all types of batteries
                          by dbuergi
                          sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                          Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                          My first work was to bring my Samsung watch battery back to life with was not recognized...
                          07-18-2025, 03:17 AM
                        • motormayhem
                          Lenovo T460 Only Charges on One Charger
                          by motormayhem
                          Laptop Question
                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                          05-12-2023, 01:46 PM
                        • ktmmotocross
                          ACER Spin 5 SP514-51N after usb-c controller ic change no reaction to charger - must it be programmed first?
                          by ktmmotocross
                          Hello.
                          Have this ACER Spin 5 SP514-51N that have only 5V on usb-c charging ports and usb-c comtroller CYPD5225-96BZXI heats up. so i order new controller and replace it. now u have no reaction to charger. must be this ic programmed first and if yes than how...
                          06-17-2025, 12:11 AM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
