LPK12-450W safety capacitor shorted
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: LPK12-450W safety capacitor shorted
    Originally posted by Taruga
    Don't worry
    My nephiew got new power supply, this one is/will not be used by him. It's for me, and when I need to use it, it will be mainly to test and repair noisy computer fans.
    I have much better spare power supplies to put inside computers.
    In that case, if you're just going to use the PSU for occasional testing, then you might as well remove those caps altogether. As mentioned, they are for noise and ripple suppression on the line. Your PSU already doesn't have any input common-mode chokes or X2-class caps. So the amount of RF and noise it's dumping on the line (and vulnerable to as well) will hardly change if you removed those 1 kV caps.
    The gain from removing those 1 kV caps is that least there will be nothing to shock you next time.
    Originally posted by raider988
    I don't really understand how could it be legal to rent/sell house without outlets properly grounded.
    Ungrounded outlets are not that unsafe. Quite a few pieces of electronic equipment use a 2-prong cord anyways.
    Also, you can always replace your non-grounded plugs with GFCI It's not a great method, because you're relying on the GFCI device to cut power, should there be a leakage current from line to ground. But it's better than nothing.
    That said, installing GFCI plugs in place of old ungrdounded plugs is the only legal way to have a "legal" 3-prong plug.
      • 31246
      the real threat is an old house with grounded outlets that arent.
      old houses that had the earth bonded to the pipes and later-on the incoming lead or iron pipe was replaced with plastic.
      i'v seen that a number of times - a dead givaway - no pun intended, is people getting tingles or small shocks from the taps.
      • dmill89
        • Dec 2011
        • 2534
        At least in the US bonding ground to pipes isn't that uncommon even in "newer" houses. My house was built in 1988 and it has the ground bonded to the incoming water main (though it also has a grounding rod as a sub-panel was later installed and they added a grounding rod as well when it was installed), and my mom used to have a townhouse that was built in 2006 and it had the ground bonded to the incoming water main as well. In both cases it is copper pipe right before it goes into the ground so even if the city main was replaced unless they replaced it all the way into the building (in which case they "should" notice the grounding clamp and re-root it to a rod) it should still have a ground.
        Ungrounded outlets themselves aren't "that" unsafe, but ungrounded outlets usually go hand in hand with knob and tube, or at best cloth wrapped romex (some very late ungrounded had early plastic wrapped romex, but only the last few years before grounded wiring became common) which both may have been safe when installed but are known to deteriorate over time and likely aren't still safe 60+ years after they were installed, and any knob and tube (most were 60 amp service at most) is unlikely to have enough capacity to handle modern appliances and electronics.
        • reessi
          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
          by reessi
          Hello:
          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
          I started on the ACER:
          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
          10-29-2024, 11:31 AM
        • Yanleb
          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
          by Yanleb
          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
          D608, good
          D618 RF101L4S, good (See warning 1 below)
          D619 RF101L4S, good (See warning 1 below)
          D865 RF101L4S, shorted (See warning 1 below)
          IC464 Inverter HA MC74HC1G14, shorted...
          03-09-2020, 12:00 AM
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
        • BalkanBoy
          Dead Razer Blade 14 2022, shorted CPU?
          by BalkanBoy
          today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
          Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
          I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
          Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
          I removed coil and injected 0.7V, it draw around...
          09-27-2024, 12:44 PM
        • barry101
          Apple 820-3662 VCore shorted to ground.
          by barry101
          Hi, Would appreciate some help.
          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
          Get charger light but no fan spin or chime. No liquid damage.
          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
          06-24-2025, 07:34 AM
