Re: LPK12-450W safety capacitor shorted
In that case, if you're just going to use the PSU for occasional testing, then you might as well remove those caps altogether. As mentioned, they are for noise and ripple suppression on the line. Your PSU already doesn't have any input common-mode chokes or X2-class caps. So the amount of RF and noise it's dumping on the line (and vulnerable to as well) will hardly change if you removed those 1 kV caps.
The gain from removing those 1 kV caps is that least there will be nothing to shock you next time.
Ungrounded outlets are not that unsafe. Quite a few pieces of electronic equipment use a 2-prong cord anyways.
Also, you can always replace your non-grounded plugs with GFCI It's not a great method, because you're relying on the GFCI device to cut power, should there be a leakage current from line to ground. But it's better than nothing.
That said, installing GFCI plugs in place of old ungrdounded plugs is the only legal way to have a "legal" 3-prong plug.
