Help needed identify Diode - PSU FSP Hexa 500W
  • spintop
    • Feb 2011
    • 132
    Hi All
    Need help to identify a shorted diode on PSU Hexa 500W.
    Don't know what rating to replace with.
    Shorted diode is D24.
    D24 is located just under the long heat sink (indicated by arrow).
    there is a familiar looking diode at D25
    Main Fuse is also blown.
    Any help is appreciated. Thanks
    Re: Help needed identify Diode - PSU FSP Hexa 500W
    https://www.badcaps.net/forum/attach...7&d=1560567083
    Did you remove it and test it off the board? It is connected in parallel with the resistor R84 (I cannot cleary see the print on the body, but more likely to be a 10 Ohms resistor).
    BTW, that diode/resistor network is for Gate discharge which is connected to Gate of the MOSFET, you should check and see if the MOSFET is OK or not.
    Since the main fuse is blown, you need to check all the power semiconductor devices for shorts.
    • ChanHa
      • Jun 2025
      • 6
      • Vietnam
      Originally posted by spintop
      Hi All
      Hi, can you take a picture R26, my ATX is broken IC TNY 277PN, and R26, but i don't know what is R26. Thanks
        master hoarder
        • May 2008
        • 12175
        I don't have this exact PSU, but I have an FSP500-60APN, which appears to have the same 2315(2) PCB and layout.
        On mine, R26 = 2R00... i.e. 2 Ohm resistor. Not sure of the power rating, but I would suggest you use at least 1/2 Watt -rated resistor, and it should be metal-oxide FUSIBLE type.
        Since your TNY277 IC is dead, also check the state of electrolytic capacitor C47 (100 uF 35V, I think?) before powering up the circuit with a new TNY IC.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8289
          I agree with momaka. Whatever that resistor is, must be something like a very low ohms reading resistor
          • lotas
            • Jan 2016
            • 4708
            • Russia
            Yes, that's right 2R00.
            • ChanHa
              • Jun 2025
              • 6
              • Vietnam
              • ChanHa
                • Jun 2025
                • 6
                • Vietnam
                • ChanHa
                  Help me Resistor on FSP Hexa ATX 500w
                  by ChanHa
                  My ATX FSP HEXA 500W was broken, lost 5vol stand by , ic TNY 277PN is broken, and R26, but i dont know what is R26. Help me...
                  06-04-2025, 08:44 PM
                • hobostove
                  Corsair RM1000e - Help identify 5VSB Zener diode
                  by hobostove
                  Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                  Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                  There's a 22ohm resistor that's melted and open, but it still has the bands.
                  The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                  It looks like the diode connects the source and drain of a TNY284...
                  03-27-2025, 02:25 PM
                • jjne
                  AUO M270QAN01 - identify diode?
                  by jjne
                  I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
                  Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
                  ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
                  01-24-2024, 08:39 PM
                • jezzaaaa
                  Identify replacement diode
                  by jezzaaaa
                  I'm trying to find a replacement diode for one that has gone short.
                  I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
                  I can't find the exact part number for sale. Similar...
                  05-09-2023, 11:26 PM
                • jolivares
                  NEEDED IPAD7 A2197 DIODE MESURAMENTS VCC_MAIN, VCC_BATT, VDD_BOOST
                  by jolivares
                  I sent IPAD 7 WIFI-2019, model A2197 to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
                  This is what i found until this moment:
                  1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
                  2) no short circuit in lines VCC_MAIN, VCC_BATT.
                  3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
                  4) the current draw from the power supply, without battery, is about 26mA from the charging...
                  07-15-2024, 09:24 AM
