Please help identify unmark glass diode
  • debugtimog
    • Jul 2018
    • 30
    • Malaysia
    Hi Guys,
    Please help identify this diode, as shown in the diagram below. I have check in the microscope, it really does not have any marking at all. It is used in power regulator unit.
  • R_J
    • 9623
    Re: Please help identify unmark glass diode
    maybe pictures of the board or a model number might help, If its not a zener, I would guess a 1n4148 would work
      If that circuit is correct, then yes, 1N4148 should be fine.
      Is it tested bad?
      • debugtimog
        • Jul 2018
        • 30
        • Malaysia
        It is missing on my board, but the other similar board still have it. I need to order but I dont know the PN. Thanks you all. I will go for 1N4148 then.
        • MHTSOS
          • Jun 2014
          • 17
          • Greece
          Why would it have a reverse biased diode in the ISENSE pin of UC3854?
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            thermal tracking ?
            • MHTSOS
              • Jun 2014
              • 17
              • Greece
              I don't know. In the darasheet of UC3854 is doesn't say anything about it. In other ICs (i.e. Cm6800) I have seen zener diodes reverse biased to Isense pin in order to protect the IC in case the primary mosfet shorts and you get a huge current through the current sense resistor and a very big voltage drop across it. I have a psu with CM6800, the mosfets were shorted, there was no zener in parallel with the sense resistor even though the darasheet shows it, the sense resistor was open/blown and the Isense pin of CM6800 got 380V and as a result it was blown too. I made some tests and I installed a 12V zener in parallel to the sense resistor. During the tests one mosfet blew again but this time only the mosfet and the zener died before the fuse blew. That's why a zener diode would make more sense to me in that place.
              • hobostove
                Corsair RM1000e - Help identify 5VSB Zener diode
                by hobostove
                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                There's a 22ohm resistor that's melted and open, but it still has the bands.
                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                It looks like the diode connects the source and drain of a TNY284...
                03-27-2025, 02:25 PM
              • jjne
                AUO M270QAN01 - identify diode?
                by jjne
                I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
                Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
                ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
                01-24-2024, 08:39 PM
              • jezzaaaa
                Identify replacement diode
                by jezzaaaa
                I'm trying to find a replacement diode for one that has gone short.
                I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
                I can't find the exact part number for sale. Similar...
                05-09-2023, 11:26 PM
              • gurj1979
                Ubiquitiu 24 port POE. Help Identify Diode 3pin)
                by gurj1979
                Hi again guys.
                Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
                I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
                Anyone help me identify the model of this Diode ?...
                08-23-2023, 08:39 AM
              • rddube
                Asus C423N motherboard - trying to identify diode
                by rddube
                Can anyone point me in the right direction as I am trying to identify which diode this is as in the red square.
                Many thanks!
                Ray...
                06-24-2023, 08:08 PM
