235w agi advice
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    235w agi advice
    i was cleaning out my closet when i found this old agi 235w power supply:
    it came from an old proteva with amd k6-2 350mhz, noname mobo, and lots of other shitty parts. obviously came from a chain smoker:
    see all the nicotine?
    also, notice the second plug in foreground. this was made when at and atx were both in production.
    wimpy heatsinks:
    rubycon primary caps:
    decent amount of secondary caps (sorry this is the last pic- my camera batteries died and im out of aaa's):
    more secondaries on board (total of 10 ones with vents , one of those is tiny (dia 4mm))
    secondary caps su'scon
    no thin wiring
    what should i do with it?
    i could:
    -strip for fan, primary caps, toroid coils, fuse, regulator, and wire
    -recap it
    -leave it as is and use as spare
    ps- what is the potentiometer for? (3rd pic center, left, orange) i have a few with those near the fan. do they control fan speed? if so, which way make the fan go faster?
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: 235w agi advice
    oh, does moving the board into an old bestec box with better ventilation and a spot to mount a second fan help?
    sigpic
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Re: 235w agi advice
      Those are decent sized heatsinks for only a 235W. Not much you could use it with though, so I don't know.
      FYI these old AGI's are bestecs.
      That pot is probably for adjusting the fan or some rail or something...sometimes psu's will have the pots for adjusting the fan's high and low points on a controller board like that.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: 235w agi advice
        i was thinking p3 866, 786mb ram, dvd burne,r cd burne,r 160gb hd, ati 7500 gpu, no oc
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Re: 235w agi advice
          oh, and i once had a newer agi 430w. it was made by hipro
          sigpic
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Re: 235w agi advice
            Older AGI's are bestec.
            I have 2 agi's, one is a AT from a Quantex QP5 pentium, 250W and its a bestec with the same rubycon and su'scon caps, and identical heatsinks.
            The other one is a 300W from a AST adventure, it too is a bestec.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Re: 235w agi advice
              so its kinda pointless to keep it since my slowest machine is that comapaq i mentioned a few posts ago (p3 866)
              should i gut it or not?
              sigpic
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Re: 235w agi advice
                It will probalby do fine with that.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Re: 235w agi advice
                  recap it?
                  sigpic
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    Re: 235w agi advice
                    Judging by model number starting with HP on its label, HP-235ATXAK, that one is also a Hipro build
                    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Re: 235w agi advice
                      i had another HP___ psu that looked simular with the white goo and daughter board with pot. simular vent stamping. it was a compaq one full of g-luxons. still works. has a decent hs though and is rated for 250w
                      but i thought compaq only did ac-bell and delta (deltas are good)
                      sigpic
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        Re: 235w agi advice
                        HP__ model number on Dell power supply
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          Re: 235w agi advice
                          http://cgi.ebay.com/Hipro%2FAGI-HP-2...706137008r6209
                          Yup, Hipro.
                          Recap it if you want to...good little psu then.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Re: 235w agi advice
                            would improving the heatsinks give it more power?
                            sigpic
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              Re: 235w agi advice
                              its only 235W, it dosen't need any more heatsinks than that.
                              Even so, those heatsinks aren't that bad.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Re: 235w agi advice
                                if i dont recap it will it kill stuff since i seen no bad caps inside
                                sigpic
                                • KeriJane
                                  Mac Enthusiast
                                  • Sep 2008
                                  • 681
                                  Re: 235w agi advice
                                  Hi Ratdude
                                  Maybe.
                                  Only an Oscilloscope can tell for sure, and for that you'd want it under load as well.
                                  If you want to recap, Oklahoma Wolf noted an odd thing. (I did too) Sometimes those "Lousy awful cheap Chinese Crapacitors" do OK.
                                  Sometimes better than a nice Japanese Low-ESR replacement.
                                  I noticed this when replacing OST with Nichicon PW and Rubycon MBZ..... The OST looked better on the scope! O.W. thinks that sometimes the circuit design might be optimized for the particular caps the PSU came with.
                                  BTW, what's the Date Code on those caps? The BadCaps plague started around 1998 or so didn't it? Earlier than that might be OK. Of course they could be deteriorated from age.
                                  Have Fun,
                                  Keri
                                  The More You Learn The Less You Know!
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Re: 235w agi advice
                                    i dont know- it is a paperweight until i need it someday
                                    it had been used for a while with no ill effects on anyhting
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Re: 235w agi advice
                                      update: i checked voltages:
                                      3.3- 3.36
                                      5- 5.16
                                      -5 = -4.96
                                      12- 10.66 no fluctuations
                                      is this ok or bad?
                                      sigpic
                                      • linuxguru
                                        • Apr 2005
                                        • 1564
                                        Re: 235w agi advice
                                        It's marginally OK - the +12v rail will probably go higher when the lower rails are loaded a bit. It won't hurt to recap all the secondary Suscons. You may also want to replace any small caps (22-100 uF) on the primary side of the auxiliary (+5Vsb) flyback supply - these are known to degrade with age on several different designs.
