This is a sticky topic.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Couldn't get that great of a pic with my phone but you can see where I desoldered the CapXon input caps. I should be able to use the holes right next to them? They're on the same trace, just spaced out farther, it's a perfect width for the OST's. Pretty sure it would work but I just wanna get your guys' input (no pun intended)
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      #902
      Yeap, I have done that before with success.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Nice. And the old holes don't need to be filled?
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          #904
          Not really. You could apply some solder to make them look nice though
            master hoarder
            • May 2008
            • 12164
            #905
            YC for me too.
            YC for me three. Of course, if given choice between Ost and YC, I'll definitely take Ost.
            Originally posted by tom66
            CapXon and Teapo are probably honest as they are seen in most consumer stuff too, not cheap power supplies. I don't think you could long get away with lying about capacitance if you were selling to everyone.
            Not quite. It depends.
            In my experience, low-voltage CapXon are indeed honest about their capacitance ratings and like goodpsusearch said, they do meet their specs.
            The high-voltage CapXons aren't as honest, though. I measured a pair of 330uF caps from an old J&C PSU and they both showed 220uF +/- 3uF. IMO, that's too close to 220uF to say that age was the cause for this result.
            And if that's not enough of a reason to avoid CapXon high voltage caps, I have seen at least 3 threads pop up here on badcaps.net where the problem was dried up (and sometimes open-circuited) CapXon high voltage caps. IIRC, those were PSU threads, and in each case the APFC circuit bombarded when the CapXon primary caps died.
            The low-voltage CapXon caps also suck, so I say just avoid CapXon when possible. I only keep a few "good" looking ones for temporarily replacing obviously failed caps.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Yeah I put the OST in. It says 560uF 200V but was exactly to the MM the same size as the 470uF 200V YC. Recapped the whole thing except less than 10uf caps. I wonder if especially changing the input caps with better ones and the secondary will change the output voltage. Before I recapped it (with 1 bulging cap) it was reading 11.7V on the 12V. What you said about high voltage CapXon's not being honest sounds about right. I have a OCZ GameXstream 700W that a friend gave me that has a bulging CapXon primary cap. Granite, it had APFC but it was powering a low load computer. Core 2 Duo, 9800GT, 2 hard drives. If I recall correctly, it claimed to be a 450uF, 400V cap
                ^If anything, PFC puts less stress on primary caps than non-PFC systems. So a CapXon that can't manage a job as a PFC bulk cap is a very poorly made cap.
                I've said it before - I think a lot of these bad cap issues are simply poor quality. Like maybe 5-10% of CapXon fail before their rated lifespan. And the specs are "improved" by the marketing department. It often only takes one bad cap to take a device down.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Really?? I thought it was the other way around. Yeah, I don't think it matters whether these cheap caps are 105C or 85C rated they're going to fail quickly either way it seems..
                  • Wester547
                    • Nov 2011
                    • 1268
                    • USA.
                    #909
                    I was always told that even Passive PFC generates more heat and I've heard of 820uF 200V Teapos dying after 5 years of being in close proximity to a passive PFC - it was suspected that the hot PFC was the reason for their death. Does PFC somehow take stress off primary capacitors even though they're definitely not as stressed as other capacitors in the PSU to begin with? And I would say 105C and 85C capacitors are far and apart in what they can take, all things considered.... (with exception to exceptionally crappy capacitors)
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      #910
                      APFC boosts the voltage on the input caps, that's the reason they use lower uF primary caps when there is APFC. This stresses input caps more than PPFC or no PFC at all. PPFC, I don't know, maybe it generates heat.
                        master hoarder
                        • May 2008
                        • 12164
                        #911
                        I always *thought* APFC stresses the input caps the most because of the large voltage spikes generated by the APFC coil and the high frequency of the circuit. But that's only my logic and I may be wrong.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          That's what I thought too, cause even terrible caps seem to last ages on the primary. The only caps where I've had the primaries fail in a non APFC PSU were Fuhjyyu and Teapo, and a Taicon in a gigabit switch.
                          • Wester547
                            • Nov 2011
                            • 1268
                            • USA.
                            #913
                            What were the specs of the Teapos that failed as input capacitors for you? Usually, unless something is stressing them or literally "toasting" them, they do okay as primary capacitors for a while, at least I thought they would.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4925
                              • New Zealand
                              #914
                              Teapoo are just lame to begin with.
                              -David VanHorn
                              • Wester547
                                • Nov 2011
                                • 1268
                                • USA.
                                #915
                                I know this is a topic discussed upon before in this thread, but I was thinking... if the second diode of a bipolar transistor or MOSFET (TO-220/TO-247 respectively) on the secondary is used as a freewheeling (or flyback) diode in single and two-transistor forward topology (thus not sharing the load evenly and contributing less, hence the lower output rating than the full one of the rectifier), and if it has nothing to do with duty cycle (thus not contributing 30-40% less as those on Hardware Secrets say), how much less would it be than the full rating (or rather, how much percent does the flyback diode contribute, or does it vary drastically)?
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  #916
                                  Going off the top of my head, the typical usage of a double diode in SMPSs with half-wave rectified output is 70%.
                                  A working TV? How boring!
                                  • Wester547
                                    • Nov 2011
                                    • 1268
                                    • USA.
                                    #917
                                    Is that 70% of the whole rectifier or 70% of one of the two diodes?
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      #918
                                      70% of the whole.
                                      • Wester547
                                        • Nov 2011
                                        • 1268
                                        • USA.
                                        #919
                                        So then, if you tried to pull the whole rating of the rectifier in forward topology, would it work (in a stressed manner) or would the unit theoretically shut down since it thinks it exceeded its maximum on whatever rail (if there was OCP/OVP/OPP)?
                                          Well the rectifier doesn't have a current rating, it would just run hotter and have a shorter lifespan. I imagine if you run a rectifier in excess of its current rating for too long it will simply fail.
