This is a sticky topic.
Anything with 13007 in the name is MJE13007 copy, everyone and their mom makes them. Just like 13009 = MJE13009.
Man, just look at how they threw those silpads on there. Those rectifiers could short together anytime. But hey, at least it has a thermal fan controller.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Will add some rectifiers in parallel, hopefully it will also reduce heating and together with 12cm fan the tiny heatsink will be enough. Than rectifier instead of diodes, transistors are enoguh for 350 W hopefully. Also add all missing pieces
I think the efficiency will rise at least 5 %Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
I've never been able to pull more than 300W from a PSU with 13007s, and that's on a good day. Usually it's more like 250W.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Your ruining me guysWhy is that? Aren't they rated for 8 A? Considering 325 V, its 1,077 A to get 350 W. Even just 340 W, considering some 10 W is supposed to go through +5V SB
The primary voltage isn't gonna be anywhere near 325v under load. Plus, in half bridge, the primary voltage swings between +/- 1/2 of the input voltage measured across the primary caps, because the caps form a divider and the transformer is hooked to the midpoint of this divider.
Hence the instant peak current in either transistor is double the current drawn from the AC line, because they swing the transformer primary between half the input rectified mains voltage (the midpoint between the two primary caps), and the + or - of the rectified mains, in turn.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Also the crappy drive circuits used in these PC power supplies means high switching losses.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
So, with power factor of 0,7, poor efficiency of 70 % and losses, the load will be more than 8 A? Damnit.
Well, will have a look for two 400+ V/10+ A NPN transistors, could have some arround…Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
What about two Fairchild 13009 switching transistors with two 470uF/200v (85C) primary capacitors, and a PSU otherwise based on half-bridge topology (definitely no PFC in this case)? Does that sound like a 300W continuous to anyone or is it more like 250W continuous, 300W max? ^^;Comment
350W continuous 400W max should be comfortably within limits. Efficiency might be a bit low.
(The article in that link shows efficiency at less than 110V in. It will be much better, even 80%+, with 240V.)
But according to inspection: it is OK, the values on casing are just peak ones, manufacturer cannot expect you will connect it somewhere else than ordinary computer so it does not need to provide the wattage specified for longer period of timeLast edited by b700029; 06-26-2012, 08:39 PM.Comment
http://www.hardwaresecrets.com/print...ply-Review/557
And I agree that it's hard to use more than 200W without a beefy graphics card or many, many add-in cards, (or likewise, USB devices), or without overclocking heavily.Comment
Originally posted by b700029This is also partly the reason why so many would be satisfied with a $15 "650W" Powmax or similar low-end Deer/L&C: their systems never draw more than ~150-180W at full load, and idle much lower (50-60W), which is well within the capabilities of even those gutless wonders.
One of my friends was building an i5 last month for another friend. For some reason, the computer wasn't working properly (would turn on and then turn off after 10 seconds... and occasionally display the BIOS boot screen then turn off). We tried different RAM, different graphics card, different CPU... basically everything. Narrowed it down to either motherboard or PSU. The PSU he had inside was a 750W Corsair, so it was unlikely that that was the problem. Regardless, we decided to try another PSU. Since he didn't have any other PSUs, we took the computer to my house to try it with one of mine. I hooked it up to my 300 Watt Inno Power (Macron Power) MPT-301. He didn't believe me that my PSU would even run - but it did. The symptoms were exactly the same as before... Next week he got a board replacement (another Gigabyte UD3) and everything worked so it was the board that was causing the problem, as we confirmed after trying my PSU.
The point of the story, however, is that even my old Macron could run that PC with its onboard video. And the 12V rail on my Macron didn't even dip below 12V (nor was the 5V too high). Considering the CPU is 95W TDP, I think it did pretty well. Moreover, the PSU didn't even blow any hot air, and my room was at close to 86F/30C that day.
Speaking of which, I don't think I ever posted pictures of that PSU. It was recapped long time ago and used for testing quite a bit. Works great with both 5V and 12V -heavy PCs.Last edited by momaka; 06-27-2012, 01:03 AM.Comment
Well, can change inputs in one 350W Fortron (Fuhjyuus 680 uF/200 V ATM) for Chemi-Cons and even repair it when I will be doing it(again, it does not eat small caps, probably ESR related stuff) and use Fuhs in here. The thing is, I will have to rise price for the Forton at least 50 % and sell this crap for more than 1 CZK/W
My dear pricey Chemi-Cons are safe! I realized I got another dead Colorshit arround. Its 350 W (actuall wattage is lower) and not really worth the repair. But has 680uF input caps which I can take…Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Got quite a few to share with you guysI paid $12 total for all of the following PSU's. Up first is this Allied I picked up. The guy at the computer shop wanted $10 for it (LOL) but I showed him there were bad caps through the vent and bargained him down to $3. I'm actually surprised by it! It's manufactured July, 2002. All the failed caps are DON.
I know they are YC's but for the low wattage and being 680uf, 200V they should be just fine. Oh wait...what is that?! A full transient filter on an Allied? WHAT?!
Look at those pathetic caps haha. They couldn't have puked any harder. I have some caps, I'm actually going to recap this thing. The caps on the secondary are DON, 1 Jun Fu, some G-Luxon and a brand I can't see until I desolder it. PWM controller is a DR-C2002. I have some UCC KY's that are the same uf and Voltage, but shorter and fatter, should they work to replace the DON and Jun Fu?
Up next is this LiteOn unit. I paid $8 for it, and I'm glad I did. It looks great! look at those beefy heat sinks!!!!And gotta love the PFC
Primary and Secondary caps are NCC, the rest are Taicon, Ltec, and I think a Teapo hiding down there.
So I went into this computer store and I asked if they had any power supplies that they didn't want. The guy said "Yeah we got some dead ones here that we are going to throw away" I asked to go through it and found this Antec! They just let me have it. Unfortunately they cut off all the wiresWell, I can just solder on some new ones from one of my other PSU's. All it has is ONE dead OST on the secondary! Primary cap is a Hitachi. Semi modular.
This FSP I got from the same guys. This thing is HEAVY. Like 6 lbs....Holy balls, look at that 5V.
Secondary caps are Teapo
Those are some badass Primary caps!!!
Is this thing worth soldering wires to or just salvaging it? What do you guys think of the others?Last edited by Pentium4; 06-29-2012, 04:40 AM.Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
